allegro17.4转PADS9.5,遇到的报错,请问怎么解决
ERROR: Techfile conversion failed!WARNING: layer BOTTOM not found in layer table.Check the Allegro cross-section!
WARNING: layer TOP not found in layer table.Check the Allegro cross-section!
WARNING:No route border found, bounding box used!
ERROR: no data issued for clearance DEFAULT
WARNING: layer SOLDERMASK_TOP not found in layer table.Check the Allegro cross-section!
WARNING: layer SOLDERMASK_BOTTOM not found in layer table.Check the Allegro cross-section!
WARNING: layer PASTEMASK_TOP not found in layer table.Check the Allegro cross-section!
WARNING: layer PASTEMASK_BOTTOM not found in layer table.Check the Allegro cross-section!
WARNING: layer FILMMASKTOP not found in layer table.Check the Allegro cross-section!
WARNING: layer FILMMASKBOTTOM not found in layer table.Check the Allegro cross-section!
ERROR: Unable to issue shapes for padstack PAD19 - layer problems
ERROR: Unable to issue shapes for padstack PAD20 - layer problems
ERROR: Unable to issue shapes for padstack PAD45 - layer problems
ERROR: Unable to issue shapes for padstack PAD14 - layer problems
ERROR: Unable to issue shapes for padstack PAD32 - layer problems
ERROR: Unable to issue shapes for padstack PAD34 - layer problems
ERROR: Unable to issue shapes for padstack PAD4 - layer problems
ERROR: Unable to issue shapes for padstack PAD5 - layer problems
ERROR: Unable to issue shapes for padstack PAD24 - layer problems
ERROR: Unable to issue shapes for padstack PAD1 - layer problems
ERROR: Unable to issue shapes for padstack PAD33 - layer problems
ERROR: Unable to issue shapes for padstack PAD27 - layer problems
ERROR: Unable to issue shapes for padstack PAD28 - layer problems
ERROR: Unable to issue shapes for padstack PAD26 - layer problems
ERROR: Unable to issue shapes for padstack PAD30 - layer problems
ERROR: Unable to issue shapes for padstack PAD29 - layer problems
ERROR: Unable to issue shapes for padstack PAD31 - layer problems
ERROR: Unable to issue shapes for padstack PAD21 - layer problems
ERROR: Unable to issue shapes for padstack PAD43 - layer problems
ERROR: Unable to issue shapes for padstack PAD44 - layer problems
ERROR: Unable to issue shapes for padstack PAD22 - layer problems
ERROR: Unable to issue shapes for padstack PAD16 - layer problems
ERROR: Unable to issue shapes for padstack PAD35 - layer problems
ERROR: Unable to issue shapes for padstack PAD36 - layer problems
ERROR: Unable to issue shapes for padstack PAD6 - layer problems
ERROR: Unable to issue shapes for padstack PAD7 - layer problems
ERROR: Unable to issue shapes for padstack PAD23 - layer problems
ERROR: Unable to issue shapes for padstack PAD3 - layer problems
ERROR: Unable to issue shapes for padstack PAD38 - layer problems
ERROR: Unable to issue shapes for padstack PAD39 - layer problems
ERROR: Unable to issue shapes for padstack PAD40 - layer problems
ERROR: Unable to issue shapes for padstack PAD25 - layer problems
ERROR: Unable to issue shapes for padstack PAD8 - layer problems
ERROR: Unable to issue shapes for padstack PAD37 - layer problems
ERROR: Unable to issue shapes for padstack PAD46 - layer problems
ERROR: Unable to issue shapes for padstack PAD48 - layer problems
ERROR: Unable to issue shapes for padstack PAD47 - layer problems
ERROR: Unable to issue shapes for padstack PAD41 - layer problems
ERROR: Unable to issue shapes for padstack PAD42 - layer problems
ERROR: Unable to issue shapes for padstack STANDARDVIA - layer problems
WARNING: layer internal_pad_def not found in layer table.Check the Allegro cross-section!
WARNING: layer ~TSM not found in layer table.Check the Allegro cross-section!
WARNING: layer ~BSM not found in layer table.Check the Allegro cross-section!
WARNING: layer ~TPM not found in layer table.Check the Allegro cross-section!
WARNING: layer ~BPM not found in layer table.Check the Allegro cross-section!
WARNING: layer ~TFM not found in layer table.Check the Allegro cross-section!
WARNING: layer ~BFM not found in layer table.Check the Allegro cross-section!
WARNING: layer ~ALV not found in layer table.Check the Allegro cross-section! 你这个直接Allegro转的?
回 冷心 的帖子
冷心:你这个直接Allegro转的?(2023-04-26 13:50) images/back.gif
https://blog.csdn.net/Ammon_Zhang/article/details/102975753?utm_medium=distribute.pc_relevant.none-task-blog-2~default~baidujs_baidulandingword~default-1-102975753-blog-88381356.235^v32^pc_relevant_default_base3&spm=1001.2101.3001.4242.2&utm_relevant_index=4 按照这个操作的 坎坎坷坷快快快
