查看: 3076|回复: 17
allegro17.4转PADS9.5,遇到的报错,请问怎么解决
发表于 2023-4-26 09:09 | 显示全部楼层 |阅读模式
ERROR: Techfile conversion failed!
WARNING: layer BOTTOM not found in layer table.  Check the Allegro cross-section!
WARNING: layer TOP not found in layer table.  Check the Allegro cross-section!
WARNING:  No route border found, bounding box used!
ERROR: no data issued for clearance DEFAULT
WARNING: layer SOLDERMASK_TOP not found in layer table.  Check the Allegro cross-section!
WARNING: layer SOLDERMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
WARNING: layer PASTEMASK_TOP not found in layer table.  Check the Allegro cross-section!
WARNING: layer PASTEMASK_BOTTOM not found in layer table.  Check the Allegro cross-section!
WARNING: layer FILMMASKTOP not found in layer table.  Check the Allegro cross-section!
WARNING: layer FILMMASKBOTTOM not found in layer table.  Check the Allegro cross-section!
ERROR: Unable to issue shapes for padstack PAD19 - layer problems
ERROR: Unable to issue shapes for padstack PAD20 - layer problems
ERROR: Unable to issue shapes for padstack PAD45 - layer problems
ERROR: Unable to issue shapes for padstack PAD14 - layer problems
ERROR: Unable to issue shapes for padstack PAD32 - layer problems
ERROR: Unable to issue shapes for padstack PAD34 - layer problems
ERROR: Unable to issue shapes for padstack PAD4 - layer problems
ERROR: Unable to issue shapes for padstack PAD5 - layer problems
ERROR: Unable to issue shapes for padstack PAD24 - layer problems
ERROR: Unable to issue shapes for padstack PAD1 - layer problems
ERROR: Unable to issue shapes for padstack PAD33 - layer problems
ERROR: Unable to issue shapes for padstack PAD27 - layer problems
ERROR: Unable to issue shapes for padstack PAD28 - layer problems
ERROR: Unable to issue shapes for padstack PAD26 - layer problems
ERROR: Unable to issue shapes for padstack PAD30 - layer problems
ERROR: Unable to issue shapes for padstack PAD29 - layer problems
ERROR: Unable to issue shapes for padstack PAD31 - layer problems
ERROR: Unable to issue shapes for padstack PAD21 - layer problems
ERROR: Unable to issue shapes for padstack PAD43 - layer problems
ERROR: Unable to issue shapes for padstack PAD44 - layer problems
ERROR: Unable to issue shapes for padstack PAD22 - layer problems
ERROR: Unable to issue shapes for padstack PAD16 - layer problems
ERROR: Unable to issue shapes for padstack PAD35 - layer problems
ERROR: Unable to issue shapes for padstack PAD36 - layer problems
ERROR: Unable to issue shapes for padstack PAD6 - layer problems
ERROR: Unable to issue shapes for padstack PAD7 - layer problems
ERROR: Unable to issue shapes for padstack PAD23 - layer problems
ERROR: Unable to issue shapes for padstack PAD3 - layer problems
ERROR: Unable to issue shapes for padstack PAD38 - layer problems
ERROR: Unable to issue shapes for padstack PAD39 - layer problems
ERROR: Unable to issue shapes for padstack PAD40 - layer problems
ERROR: Unable to issue shapes for padstack PAD25 - layer problems
ERROR: Unable to issue shapes for padstack PAD8 - layer problems
ERROR: Unable to issue shapes for padstack PAD37 - layer problems
ERROR: Unable to issue shapes for padstack PAD46 - layer problems
ERROR: Unable to issue shapes for padstack PAD48 - layer problems
ERROR: Unable to issue shapes for padstack PAD47 - layer problems
ERROR: Unable to issue shapes for padstack PAD41 - layer problems
ERROR: Unable to issue shapes for padstack PAD42 - layer problems
ERROR: Unable to issue shapes for padstack STANDARDVIA - layer problems
WARNING: layer internal_pad_def not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~TSM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~BSM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~TPM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~BPM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~TFM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~BFM not found in layer table.  Check the Allegro cross-section!
WARNING: layer ~ALV not found in layer table.  Check the Allegro cross-section!
  • 打卡总天数:1
  • 打卡总奖励:2
  • 最近打卡:2024-10-24 11:38:14
1元学习Allegro(1期)
发表于 2023-4-26 13:50 | 显示全部楼层
你这个直接Allegro转的?
 楼主| 发表于 2023-4-26 13:56 | 显示全部楼层
  • 打卡总天数:7
  • 打卡总奖励:23
  • 最近打卡:2025-02-22 20:48:13
发表于 2023-5-15 09:03 | 显示全部楼层
发表于 2023-6-30 23:38 | 显示全部楼层
  • 打卡总天数:102
  • 打卡总奖励:366
  • 最近打卡:2025-11-19 16:00:58
发表于 2023-11-13 08:30 | 显示全部楼层
  • 打卡总天数:102
  • 打卡总奖励:366
发表于 2023-11-15 08:24 | 显示全部楼层
  • 打卡总天数:102
  • 打卡总奖励:366
发表于 2023-12-2 09:36 | 显示全部楼层
  • 打卡总天数:2
  • 打卡总奖励:6
  • 最近打卡:2026-07-11 16:34:04
发表于 2023-12-12 10:17 | 显示全部楼层
  • 打卡总天数:2
  • 打卡总奖励:8
  • 最近打卡:2024-11-26 20:52:32
9
终身成就奖原创先锋奖
发表于 2023-12-13 08:49 | 显示全部楼层
