重要提示:PCB作品文件展下载说明
DM-590u+20260603.7z
370.27 KB, 下载次数: 0, 下载积分:金币 -5 枚
| Name | Part Type | PCB Decal | Value | | CJ3 | XRL-MALE-CT3-05M | JACK-XLR-CONNECT-90-MALE-CT3-05M | | | CJ4 | XRL-MALE-CT3-05M | JACK-XLR-CONNECT-90-MALE-CT3-05M | | | CN4 | USB_A1 | JACK-USB-IPOD | | | CON3 | CON5 | SIP5-3.96 | 5PIN_3.96 | | CON4 | CON2 | SIP2-7.92 | 2P_7.92 | | CON5 | CON4 | SIP4-7.92 | 4P_7.92 | | CON6 | CON10 | FFC_10PIN_1.0_1 | FPC_10PIN_0.5 | | CON7 | CON-2 | CON2-P2.0 | 2PIN_2.0 | | CON14A | CON-3-2.54-2.0 | CON3-P2.5 | 3PIN_2.54 | | CON14B | CON-3-2.54-2.0 | CON3-P2.5 | 3PIN_2.54 | | CON15A | CON4 | CON4-2.5 | 4PIN_2.54 | | CON15B | CON4 | CON4-2.5 | 4PIN_2.54 | | CON18A | CON-3-2.54-2.0 | CON3-P2.5 | 3PIN_2.54 | | CON18B | CON-3-2.54-2.0 | CON3-P2.5 | 3PIN_2.54 | | CON19A | CON-FFC-12PIN | CON_12PIN | 12PIN_2.54 | | CON19B | CON-FFC-12PIN | CON_12PIN | 12PIN_2.54 | | CON21 | CON-2 | CON2-P2.0 | 2PIN_2.0 | | CON22 | CON-4 | CON4-P2.0 | 4PIN_2.0 | | CON30 | FPC_30P_1 | FPC_30P | FPC_30P | | CON100 | CON4 | CON4-2.5 | 4PIN_2.54 | | D1 | DIODE | D10 | 1N4007 | | D2 | DIODE | D10 | 1N4007 | | D3 | DIODE | D10 | 1N4007 | | D4 | DIODE | D10 | 1N4007 | | D5 | DIODE | D5_4 | GS1M | | D6 | DIODE | D10 | P6KE200A | | D7 | DIODE | D5_4 | ES1D | | D8 | DIODE | D10 | 1N5819 | | D9 | DIODE | D5_4 | B240A | | D11 | SS34 | DO-214AC | 1N4001 | | D12 | SS34 | DO-214AC | 1N4001 | | D13 | DIODE | D10 | 1N5819 | | D15 | IN4148 | SMD-D | 1N4148 | | D29 | 2.5NPTH | 2.5NPTH | | | D30 | 2.5NPTH | 2.5NPTH | | | D31 | 2.5NPTH | 2.5NPTH | | | D32 | 2.5NPTH | 2.5NPTH | | | D101 | BRIDGE4 | DIODE-BRIDGE(8.3_6.3) | DF02M | | D102 | BRIDGE4 | DIODE-BRIDGE(8.3_6.3) | DF02M | | ED1 | PESD5V0S1 | ESDSUPP-0603-WAVE | | | ED2 | PESD5V0S1 | ESDSUPP-0603-WAVE | | | ED3 | PESD5V0S1 | ESDSUPP-0603-WAVE | | | ED4 | PESD5V0S1 | ESDSUPP-0603-WAVE | | | FB9 | FERRITE | 0805L | 103 100MHz | | FB203 | FERRITE | 0805L | 103 100MHz | | HS2 | CON1 | HEATSINK2 | HS | | HS4 | CON1 | HEATSINK2 | HS | | INSET | SW-PB1 | SWS-8_6 | SWTICH | | K1 | RELAY-SPDT | RELAY-SPDT3(30_13) | G2RL-1-CN 5VDC | | L1 | INDUCTOR | 0805L | 10uH 0805 | | L2 | INDUCTOR | 0805L | 1000ohm/100MHz 0805 | | L3 | INDUCTOR | 0805L | 1000ohm/100MHz 0805 | | L4 | INDUCTOR | SMR63B | 10uH/1A | | L5 | INDUCTOR | SMR63B | 10uH/3A | | L6 | INDUCTOR | 0805L | 10uH 0805 | | L7 | INDUCTOR | SMR63B | 10uH/1A | | L8 | INDUCTOR | 0805L | 10uH 0805 | | L9 | INDUCTOR | 0805L | 10uH 0805 | | L11 | INDUCTOR | 0805L | 1000ohm/100MHz 0805 | | L12 | INDUCTOR | 0805L | 1000ohm/100MHz 0805 | | L13 | INDUCTOR_2 | R3 | 10uH | | L18 | INDUCTOR | 0805L | 1000ohm/100MHz 0805 | | LED-A | CON2 | CON2-2.5 | 2PIN_2.54 | | M1 | MARK | MARK | | | M2 | MARK | MARK | | | NEXT | SW-PB1 | SWS-8_6 | SWTICH | | OPT1 | OPT_OUT_RCA_5PIN | OPT_OUT_RCA_5PIN | JST1583 | | PAUSE | SW-PB1 | SWS-8_6 | SWTICH | | PLAY | SW-PB1 | SWS-8_6 | SWTICH | | POINT | POINT | POINT | | | PRE | SW-PB1 | SWS-8_6 | SWTICH | | Q1 | NPN | SOT23WS | S9014 | | Q2 | NPN | SOT23WS | S9014 | | Q10 | NPN | SOT23WS | S9014 | | Q102 | NPN | SOT23WS | S9014 | | RCA1 | RCA_2L2P | RCA-2L2PIN | | | RY2 | RELAY-10PIN | RLY-10P-A | TQ2-5V | | SOURCE | SW-PB1 | SWS-8_6 | SWTICH | | SW | SW_DPDT | SW-T22205B_115_230_2 | SW DPDT | | SW101 | SW-PB1 | SWS-8_6 | BUTTON | | T1 | TRANS7 | EI-21_17 | EE19 | | T8 | TRANSFORMER-COAX | TRANSFORMER-8P-DIGITAL-TRANS | | | U1 | STC8H8K64_48 | LQFP48_1 | | | U2 | ES9039Q2M | 32QFN | | | U3 | SY8120 | SOT23-6L | SY8120 | | U4 | TLV70033 | SOT_5PIN | TLV70033 | | U7 | TLV70033 | SOT_5PIN | TLV70033 | | U8 | KA7912 | TO220 | L7912CV | | U9 | KA7812 | TO220-V | L7812CV | | U10 | TLV70033 | SOT_5PIN | TLV70033 | | U11 | VOLTREG_1 | TO-220H | LM317T | | U13 | TLV70033 | SOT_5PIN | TLV70033 | | U14 | TNY174-180 | SOP8_7 | TNY175DG-TL | | U15 | OPTOISO1 | OPTOISO | EL817(B)-FV | | U16 | TL431 | TO-92_TL431 | TL431 | | U17 | IRR | IR_1 | KS1838 | | U18 | LMV358M-SO8N | SO8 | TL072CDR | | U20 | LMV358M-SO8N | SO8 | TL072CDR | | U23 | TLV70033 | SOT_5PIN | TLV70033 | | U27 | TPD2E001_ESD | SOP-4 | | | U28 | NC7SZ157 | SC70-6 | NC7SZ157 | | U29 | LP2951 | SOP-8-SMD | LP2951 | | U101 | VOLTREG_1 | TO-220H | LM317T | | U104 | COMPONENT_12 | TO252(DPAK)-1234 | LD1117DT33DPAK | | U204 | ICM74HC04SM1RSO14 | SO14 | MC74HC04A | | USB | CON4 | CON4-2.5 | 4PIN_2.54 | | VOL+ | SW-PB1 | SWS-8_6 | BUTTON | | VOL- | SW-PB1 | SWS-8_6 | BUTTON | | Y1 | XT | XT_5X7 | 100MHZ |
重要提示:PCB作品文件展下载说明
