重要提示:PCB作品文件展下载说明
慧荣SM768挂两个DDR3L +MS1826 +3个RT6213+GSV2201D +VL171做的多功能系统板PCB文件支持多个视频输入和3屏显示
版号BJYP-Z3-PRO-MB-V1.3
BJYP-Z3-PRO-MB-V1.3.7z
2.2 MB, 下载次数: 3, 下载积分:金币 -5 枚
售价: 30 枚金币 [记录] [购买]
| Name | Part Type | PCB Decal | Value | | +3_3V | TEST_POINT_0 | TESTTP | TEST_POINT | | CON1 | FTC-30P-0.5MM-SMD | FTC-30P-0.5MM-SMD-L | FTC-30P-0.5MM-SMD(TZ同轴线插座) | | CON2 | FTC-30P-0.5MM-SMD | FTC-30P-0.5MM-SMD-L | FTC-30P-0.5MM-SMD(TZ同轴线插座) | | CON3 | FTC-30P-0.5MM-SMD | FTC-30P-0.5MM-SMD-L | FTC-30P-0.5MM-SMD(TZ同轴线插座) | | CON4 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON5 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON6 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON7 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON8 | HDMI-MINI-CB0.8MM-19P-SMD | HDMI_MINI-BS-SMD/DIP-DWZ | HC-BF1G00-001 HDMI C TYPE不沉板,CH3.3 L8.0 | | CON9 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON10 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON11 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON12 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CON13 | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM-DIP-DEBUG | CON-4P-2.0MM/NC | | CW4 | CAP_NP_8 | C0402 | 104 | | D1 | SMA | SOD123 | DS34W | | DK1 | BAT54CW-F | SOT-23 | BAT54C | | DP1 | SM340A_4 | SOD123 | DS34W/NC | | DP2 | SM340A_4 | SOD123 | DS34W | | DP7 | BAT54CW-F | SOT23 | BAT54C | | EC1 | CAP-E | CAP3528/B/H=2.0 | 10UF/25V/NC | | EC2 | CAP-E | CAP3528/B/H=2.0 | 10UF/25V/NC | | EC7 | CAP-E | CAP3528/B/H=2.0 | 10UF/25V/NC | | EC9 | CAP-E | CAP3528/B/H=2.0 | 100UF/10V钽电容 | | ESD17 | BAV99_0 | ESD0402A | WE05DGCF-B | | ICD1 | CH340E_5 | MSOP10 | MSUSB30 | | ICD2 | CH340E_5 | MSOP10 | MSUSB30 | | ICD3 | CH340E_4 | MSOP10 | MSUSB30 | | ICD7 | HD3SS460_0 | MQFN28_36X46 | VL171 | | ICESD3 | CS4334_1 | DFN10P | WS05-4R2P | | ICESD4 | CS4334_1 | DFN10P | WS05-4R2P | | ICESD5 | CS4334_1 | DFN10P | WS05-4R2P | | ICESD12 | CS4334_1 | DFN10P | WS05-4R2P | | ICESD13 | CS4334_1 | DFN10P | WS05-4R2P | | ICM1(DP) | SOIC8/P1.27/7_0.98 | SOP8-S-L | ZB25VQ80ATIG-低(带加密) | | ICM2(VGA) | SOIC8/P1.27/7_0.98 | SOP8-S-L | ZB25VQ80ATIG-低(带加密) | | ICM3(HDMI) | SOIC8/P1.27/7_0.98 | SOP8-S-L | ZB25VQ80ATIG-低(带加密) | | ICP1 | LC3312B_0 | SOT23-6 | TMH7001B | | ICP2 | LC3312B_0 | SOT23-6 | TMH7001B | | ICP3 | LC3312B_0 | SOT23-6 | TMH7001B | | ICS1 | RT6213_LQ128_20 | LQFP156_040_220X160X014MM | RTD2556VD-CG | | ICS2 | RT6213_LQ128_20 | LQFP156_040_220X160X014MM | RTD2556VD-CG | | ICS3 | RT6213_LQ128_20 | LQFP156_040_220X160X014MM | RTD2556VD-CG | | ICW1 | GLI8024-48_1 | PWQFN42 | ASW3642 | | ICW3 | GLI8024-48_1 | PWQFN42 | ASW3642 | | ICW4 | GLI8024-48_1 | PWQFN42 | ASW3642 | | IMONA | TEST_POINT_0 | TESTTP | TEST_POINT | | IMONB | TEST_POINT_0 | TESTTP | TEST_POINT | | J2 | TYPEC-24P-BS-QCHT | TYPEC-24P-BS-QCHT | TYPE-C前插后贴 24P板上型 广业品牌 | | J3 | TYPEC-24P-BS-QCHT | TYPEC-24P-BS-QCHT | TYPE-C前插后贴 24P板上型 广业品牌 | | JP4 | DIP6_2.54 | CON-6P-2.0MM-DIP-DEBUG | DIP6_2.0MM/NC | | JU1 | CON-4P-1.25MM-SMD | CON-4P-1.25MM-SMD-L-R | 1.25-4P卧贴超薄H=1.85镀金 | | K5 | TS-1111C | TS-1806 | ONE | | L1 | IND_SLF125 | SMD2520 | 2.2UH/2A | | L2 | IND_SLF125 | SMD2520 | 2.2UH/2A | | L3 | IND_SLF125 | SMD2520 | 2.2UH/2A | | L4 | IND_SLF125 | SMD0420 | 4.7uH/3A | | L5 | INDUCTOR_IRON-A | L0805 | 0R/0805 | | L6 | IND_SLF125 | JLSHC0630 | 10uH/4A | | L7 | IND_SLF125 | SMD0420 | 4.7uH/3A | | L8 | INDUCTOR_IRON-A | L0402 | 100R/1A | | L9 | INDUCTOR_IRON-A | L0805 | 100R/3A | | L10 | INDUCTOR_IRON-A | L0805 | 0R/0805 | | L11 | INDUCTOR_IRON-A | SMD0420 | 3.3UH/3A | | L12 | INDUCTOR_IRON-A | L0805 | 0R/0805 | | L13 | IND_SLF125 | SMD0420 | 4.7uH/3A | | L14 | INDUCTOR_IRON-A | L0805 | 100R/3A | | L15 | INDUCTOR_IRON-A | SMD0420 | 3.3UH/3A | | L16 | INDUCTOR_IRON-A | L0805 | 0R/0805 | | L17 | INDUCTOR_IRON-A | L0805 | 0R/0805 | | L18 | INDUCTOR_IRON-A | L0805 | 0R/0805 | | L19 | IND_SLF125 | SMD0420 | 3.3UH/3A | | L20 | INDUCTOR_IRON-A | SMD0420 | 3.3UH/3A | | L21 | INDUCTOR_IRON-A | L0805 | 100R/3A | | L22 | IND_SLF125 | SMD0420 | 3.3UH/3A | | L23 | IND_SLF125 | SMD0420 | 3.3UH/3A | | L24 | IND_SLF125 | SMD0420 | 3.3UH/3A | | L25 | INDUCTOR_IRON-A | SMD0420 | 3.3UH/3A | | L26 | INDUCTOR_IRON-A | L0603 | 100R/2A | | L27 | INDUCTOR | 2520L | 4.7uH/2.5A | | L28 | IND_SLF125 | JLSHC0630 | 10uH/4A | | L30 | INDUCTOR_IRON-A | L0402 | 0R/0402 | | L31 | BCMFL | TEF1210 | HSF2012F2SF-900T04 | | L32 | INDUCTOR_IRON-A | L0402 | 100R/1A | | L33 | BCMFL | TEF1210 | HSF2012F2SF-900T04 | | L37 | INDUCTOR_IRON-A | SMD0420 | 3.3UH/3A | | L38 | INDUCTOR_IRON-A | SMD0420 | 3.3UH/3A | | L44 | IND_SLF125 | JLSHC0630 | 10uH/4A | | LED1 | LED-1206-CD | LED1206_CD | Hi-1204QBC侧,红蓝 | | LP_VMON_UFPA | TEST_POINT_0 | TESTTP | TEST_POINT | | LP_VMON_UFPB | TEST_POINT_0 | TESTTP | TEST_POINT | | PMOS6 | PMOSFET_SOT23 | SOT23 | PE3407 | | Q1 | 2N7002S | SOT23 | 2N7002 | | QD10 | PNP_0 | SOT23 | MMBT3906 | | QG1 | JMTQ3010D_1 | SOP8-M | LX4805 | | QG3 | JMTQ3010D_1 | SOP8-M | LX4805 | | QG4 | JMTQ3010D_1 | SOP8-M | LX4805 | | QG5 | JMTQ3010D_1 | SOP8-M | LX4805/NC | | QH1 | NPN(BEC)_0 | SOT23 | MMBT3904 | | QH3 | NPN(BEC)_0 | SOT23 | MMBT3904 | | QP6 | NMOSFET_SOT-23_1 | SOT23 | PE2N7002 | | QP28 | NMOSFET_SOT-23_0 | SOT23 | 2N7002 | | QP35 | NMOSFET_SOT-23_0 | SOT23 | 2N7002 | | QR1 | NPN/SOT23_1 | SOT23 | MMBT3904 | | QR3 | NPN/SOT23_1 | SOT23 | MMBT3904 | | QR5 | NPN/SOT23_1 | SOT23 | MMBT3904 | | QR6 | PNP_0 | SOT23 | MMBT3906 | | RD62 | 1.0K-1/16W-5%-0603 | R0402 | 10K | | RG1 | R_13 | RES0402 | 100K | | SM768_RST# | TEST_POINT_0 | TESTTP | TEST_POINT | | SW5 | MDS-1302B | MDS-1302B | MDS-1302B三向拨轮开关 | | T1 | P-CHANNEL | SOT23 | CJ3407 | | TCK | TEST_POINT_0 | TESTTP | TEST_POINT | | TDI | TEST_POINT_0 | TESTTP | TEST_POINT | | TDO | TEST_POINT_0 | TESTTP | TEST_POINT | | TMS | TEST_POINT_0 | TESTTP | TEST_POINT | | TP1 | T_POINT_R_PAD | TP_SMT | TPAD | | TP2 | T_POINT_R_PAD | TP_SMT | TPAD | | TP3 | TESTPOINT_0.5MM | TESTTP | TestPoint_1mm | | TP7 | T_POINT_R_PAD | TP_SMT | TPAD | | TP8 | TESTPOINT_0.5MM | TESTTP | TestPoint_1mm | | TVS1 | BAV99_4 | DFN2020-3L | SES2411P4 | | TVS2 | BAV99_4 | DFN2020-3L | SES2411P4 | | U1 | BGA425 | BGA425 | SM768_AB_final | | U2 | RT8097CHGB | TSOT23-5 | TMI3113B | | U3 | GSV2201D | QFN48_6X6 | GSV2201D | | U3(USB30) | MX25L512COI-12G | SOP8-S-L | ZB25VQ40ATIG(RED) | | U4 | L7808_9 | TSOT23-5 | DS8562-25S5/NC | | U5 | L7808_9 | TSOT23-5 | DS8562-25S5/NC | | U6 | RT8097CHGB | TSOT23-5 | TMI3113B | | U7 | L7808_9 | TSOT23-5 | DS8562-25S5/NC | | U8 | RT8097CHGB | TSOT23-5 | TMI3113B | | U9 | RT8097CHGB | TSOT23-5 | TMI3113B | | U10 | RT8097CHGB | TSOT23-5 | TMI3113B | | U11 | L7808_9 | TSOT23-5 | DS8562-25S5 | | U12 | MAX811 | SOT143 | MAX811_EUS-T_3.08/NC | | U13 | RT8097CHGB | TSOT23-5 | TMI3113B | | U14 | RT8097CHGB | TSOT23-5 | TMI3113B | | U15 | RT8097CHGB | TSOT23-5 | TMI3113B | | U16 | RT8097CHGB | TSOT23-5 | TMI3113B | | U17 | SOP8-S-L | SOP8-S-L | ZB25VQ64ASIG | | U18 | LA1314D | UDFN2X3-8 | LA1314D | | U19 | CS8580E | ESOP10L | CS8580E | | U20 | FP6809 | SOT23 | FP6809-29NS3G/NC | | U21 | LA1314D | UDFN2X3-8 | LA1314D | | U22 | VL817S_QFN-76_HUB | QFN76L-9X9X0.85MM | HL817 | | U23 | MS1826 | HLQFP256-28X28X04P-EP | MS1826B | | U26 | BGA13X9MM_14X8MM | BGA13X9MM_14X8MM | K4B4G1646E-BYMA/BGA13X9MM_14X8MM | | U27 | BGA13X9MM_14X8MM | BGA13X9MM_14X8MM | K4B4G1646E-BYMA/BGA13X9MM_14X8MM | | U32 | STM32F103RCT6 | LQFP64-10X10X05P | HC32F460 | | U33 | SPI | SOP8-S-L | P25Q40/NC | | U34 | RT8097CHGB | TSOT23-5 | TMI3113B | | U35 | RT8097CHGB | TSOT23-5 | TMI3113B | | U36 | RT8097CHGB | TSOT23-5 | TMI3113B | | U37 | RT8097CHGB | TSOT23-5 | TMI3113B | | U40 | LA1314 | SOP8-DC | LA1314 | | UART_RX | TEST_POINT_0 | TESTTP | TEST_POINT | | UART_TX | TEST_POINT_0 | TESTTP | TEST_POINT | | VMONA | TEST_POINT_0 | TESTTP | TEST_POINT | | VMONB | TEST_POINT_0 | TESTTP | TEST_POINT | | XT19 | XTAL_0.5 | Y_4P_SMD3225 | 24MHz | | XT20 | XTAL_0.5 | Y_4P_SMD3225 | 24.576MHz | | Y1 | CRYSTAL_0 | SMD3225 | 14.318MHz | | Y2 | CRYSTAL_0 | SMD3225 | 14.318MHz | | Y3 | CRYSTAL_0 | SMD3225 | 14.318MHz | | Y4 | CRYSTAL_0 | SMD3225 | 25MHz | | Y5 | CRYSTAL_0 | SMD3225 | 24.0MHz | | Y6 | CRYSTAL_0 | SMD3225 | 8MHz/NC | | Y8 | CRYSTAL_0 | SMD3225 | 25MHz |
重要提示:PCB作品文件展下载说明
