查看: 377|回复: 48
[Allegro17.4以下] 18层PCB Altera Arria 10 GX 10AX115F1932C 原理图和PCB文件
  • 打卡等级:常住青年
  • 打卡总天数:15
  • 打卡总奖励:36
  • 最近打卡:2026-07-16 23:13:38
3518
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖原创先锋奖灌水天才奖新人进步奖社区明星最爱沙发
发表于 2026-9-4 17:41 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
ALTERA_A10GX_PCIE_E3-1_22Jul15_0855.7z
6.83 MB, 下载次数: 10, 下载积分:金币 -5 枚
售价: 1 枚金币  [记录] [购买]
A10GX_PCIE_E3P1_DSN.7z
1.05 MB, 下载次数: 10, 下载积分:金币 -5 枚
售价: 1 枚金币  [记录] [购买]
D1LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D2LED_WURTH_LED_0603_GREEN_LEDGREEN_LEDLED_0603
D3BILED_0_LITE-ON_LTST-C195GEKT_LLED_GRLITE-ON_LTST-C195GEKT
D3982401646_WURTH_MSOP8_8240164682401646WURTH_MSOP8
D40LT1389_SO8_LT1389LT1389SO8
D4182401646_WURTH_MSOP8_8240164682401646WURTH_MSOP8
D42LTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDDFN12_EPAD
D43LTC4352CDD_DFN12_EPAD_LTC4352CDLTC4352CDDDFN12_EPAD
D44D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D45D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D46D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
D47D-SCHOTTKY_0_SOD323_CMDSH-3CMDSH-3SOD323
F1FUSE_0805_500MA,  RESETTABLE500mA,  Resettable805
FB1INDUCTOR_805_120OHM,  800MA120ohm,  800mA805
J110X40_VITA57_10X40_ASP_VITA57_AASP-134486-0110X40_ASP_VITA57
J210X40_VITA57_10X40_ASP_VITA57_AASP-134486-0110X40_ASP_VITA57
J3MICRO_USB_CONN_MOLEX-MICRO-USB-MICRO_USB_CONNMOLEX-MICRO-USB-47589-001
J42X4_PCIE_ATX_MLX_SD-5569_8POS_RPCIe  2x4 ATXMLX_SD-5569_8POS_RA
J5DISPLAYPORT_POST_CONN_MOLEX_SD-472720024MOLEX_SD-47272-0024
J6SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J7SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J9HFJ11-1G02E_RJ45_HFJ11-1G02EHFJ11-1G02ERJ45
J10LCD_HEADER_NEWHAVEN_LCD_LCD_HEALCD_HEADERNEWHAVEN_LCD
J12SFP+_AND_CAGE_SAMTEC_SFP_MECT20SFP+_AND_CAGESAMTEC_SFP_MECT20
J13CUI_PD-40S_CUI_PD-40S_4PIN-DIN-PD-40SCUI_PD-40S_4PIN-DIN-JACK_RA
J14EMI_HLS-180324-B-12_ISI_HILO-SKHLS-180324-B-12ISI_HILO-SKT_324-KEYED
J15SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J16SMA_SMA_LTI-SASF546-P26-X1_LTI-LTI-SASF546-P26-X1SMA_LTI-SASF546-P26-X1
J172X5_HDR2X5_100MIL_SMT_2X5_100MI2X5_100milHDR2X5_100MIL_SMT
J18QSFP_AND_CAGE_0_TYCO_QSFP_38_QSQSFP_AND_CAGETYCO_QSFP_38
J19CON2_MLX_22_23_2021_MLX_22_23_222_23_2021MLX_22_23_2021_VRT_HDR_2P
J20BNC_VERTICAL_4POST_LIGHTHORSE_SSMBLIGHTHORSE_SMB_JACK_VERT_SMT
J21BNC_VERTICAL_4POST_LIGHTHORSE_SSMBLIGHTHORSE_SMB_JACK_VERT_SMT
J22PCIE_BRACKET_X8_PCIX-8PORT_PCIEPCIE_SlotPCIX-8PORT
J232X5_HDR2X5_100MIL_SMT_DNIDNIHDR2X5_100MIL_SMT
J242X6HDR_2X6HDR-2MMX2MM_2X6HDR2x6HDR2X6HDR-2MMX2MM
L5BEAD_FERRITE_SM_0603_120  OHM FB120  Ohm FB603
L6BEAD_FERRITE_SM_0603_DNIDNI603
L7BEAD_FERRITE_SM_0603_120  OHM FB120  Ohm FB603
L8BEAD_FERRITE_SM_0402_DNIDNI402
L9BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L10INDUCTOR_0402_3.9NH3.9nH402
L11INDUCTOR_0402_5.6NH5.6nH402
L12INDUCTOR_0402_3.9NH3.9nH402
L13BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L14BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L15BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L16INDUCTOR_SM_1008_IND_4.7UH4.7uHSM_1008_IND
L17INDUCTOR_SM_1008_IND_4.7UH4.7uHSM_1008_IND
L19INDUCTOR_IND_WURTH_74479775210_1.0uHIND_WURTH_74479775210
L20INDUCTOR_IND_WURTH_74479775210_1.0uHIND_WURTH_74479775210
L21INDUCTOR_IND_WURTH_74479775210_1.0uHIND_WURTH_74479775210
L22BEAD_FERRITE_SM_0402_BLM15AG221BLM15AG221SN1402
L24BEAD_FERRITE_SM_IND_WURTH_7427910A,  RDC 4mOhmIND_WURTH_74279223560
L25INDUCTOR,  DISCRETE_IND_744301020.25uHIND_744301025
L26INDUCTOR,  DISCRETE_IND_744301020.25uHIND_744301025
L27INDUCTOR,  DISCRETE_IND_744301020.25uHIND_744301025
L28INDUCTOR,  DISCRETE_IND_744301020.25uHIND_744301025
Q3PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q23FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q24PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q25FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q26PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q27FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q28PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q29FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q30PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q31FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q32PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q33FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q34PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q39FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q40FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q41FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q42FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q43FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q44FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q45FDMC8878_4_PG-TDSON-8_BSC050NE2BSC050NE2LSPG-TDSON-8
Q46FDMC8878_4_PG-TDSON-8_BSC010NE2BSC010NE2LSIPG-TDSON-8
Q47PWRMOSFET_EN_GSD_0_SOT23_2N70022N7002SOT23
Q48PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q49PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q50FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q51FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q52FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
Q53PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q54PWRMOSFET_EN_GSD_0_SOT23_FDV305FDV305NSOT23
Q55FDMC8878_VER2_FDMC8878_VER2_FDMFDMC8878FDMC8878_VER2
RN1RES_PACK_0_RES_PACK_8_S1+S2+S3+10KRES_PACK_8
S1TS-A02SA-2-S100_0_WURTH_6X3P5_TPB  SwitchWURTH_6X3P5_TACT_SWITCH
S8TS-A02SA-2-S100_0_WURTH_6X3P5_TPB  SwitchWURTH_6X3P5_TACT_SWITCH
SW1SW_SLIDE_DPDT_EG2207_SW_SLIDE_DSW_SLIDE_DPDTEG2207
SW276SB08_DIPSWITCH_SMT_OCTAL_DIPSDIPSWITCH8DIPSWITCH_SMT_OCTAL
SW3SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW4SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW5SPST4_DIPSWITCH_SMT_QUAD_DIPSWIDIPSWITCH4DIPSWITCH_SMT_QUAD
SW6SPST5_DIPSWITCH_SMT_TEN_DIPSWITDIPSWITCH5DIPSWITCH_SMT_TEN
SW7DIPSW06_DIPSW06_DIPSW06DIPSW06DIPSW06
U1CY7C68013A_56QFN_QFN56_CY7C6801CY7C68013A_QFNQFN56
U2MAX811_SOT-143_MAX811MAX811SOT-143
U4PC28FXXXP30B85_1_F64_10X8_PC28FPC28F00AG18F64_10X8
U5PC28FXXXP30B85_1_F64_10X8_PC28FPC28F00AG18F64_10X8
U9EN6360QI_1_QNF68_EN6360QIEN6360QIQNF68
U10EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76
U13FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U14SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMQFN24
U1588E1111_0_BCC96_88E111188E1111BCC96
U165M2210ZF256_3_F256_(S1+S3+S4),S5M2210ZF256F256
U17FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U20EN6347_QFN38_EN6347QIEN6347QIQFN38
U22FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U23EN6347_QFN38_EN6347QIEN6347QIQFN38
U24EN6360QI_1_QNF68_EN6360QIEN6360QIQNF68
U25LTC3025-1_0_DFN6-2X2_EPAD_LTC30LTC3025-1DFN6-2X2_EPAD
U26SI5338A_0_QFN24_SI5338A-CUSTOMSi5338A-CUSTOMQFN24
U27FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U2810AX115F1932C_3_F1932_(S1+S2+S310AX115F1932CF1932
U29EPCQL_24TBGA_T-PBGA-24_6X8MM_EPEPCQ1024LT-PBGA-24_6X8MM
U31EN63A0QI_QFN-76_EN63A0QIEN63A0QIQFN-76
U35FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U36LT3082_DFN8_EPAD_LT3082LT3082DFN8_EPAD
U39FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U40M22544_QFN24_M22544M22544QFN24
U41M22468_MLF-16_M22468M22468MLF-16
U42SI53301_11_QFN32-FTDI_SI53301_1Si53301_11QFN32-FTDI
U44LTC2418_SSOP28_NAR_LTC2418LTC2418SSOP28_NAR
U45TPD2EUSB30_DRT_TPD2EUSB30TPD2EUSB30DRT
U46MAX1619_5_QSOP16_MAX1619MAX1619QSOP16
U47LEVEL  TRANSLATOR_QFN-12_ST2149BST2149BQFN-12
U49EPM1270M256_2_M256_(S1+S4),(S2+EPM1270_M256FBGAM256
U50LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U51EN6337_QFN38-ENPIRON_EN6337EN6337QFN38-ENPIRON
U52LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365-1DFN8-EPAD_3X2
U53SL18860DC_TDFN-10_SL18860DCSL18860DCTDFN-10
U54LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U55LTC4357_DFN6_EPAD_LTC4357LTC4357DFN6_EPAD
U57EN6337_QFN38-ENPIRON_EN6337EN6337QFN38-ENPIRON
U58MAX13042_0_UCSP-12_MAX13042MAX13042UCSP-12
U59MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U60MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U61MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U62MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U64MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U65MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U66MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U68MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U69MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U70MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U71MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U7274VCX08BQX_DQFN14_74VCX08BQX74VCX08BQXDQFN14
U73MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U74MAX3378_12UCSP_UCSP-12_MAX3378_MAX3378_UCSPUCSP-12
U75SN74LVC1G08_6PIN_PSON-6-DSF_SN7SN74LVC1G08_6PINPSON-6-DSF
U76MAX13042_0_UCSP-12_MAX13042MAX13042UCSP-12
U79LTC4315_MSOP12_LTC4315LTC4315MSOP12
U80LTC4315_MSOP12_LTC4315LTC4315MSOP12
U81LTC2977_QFN-64_9MMX9MM_LTC2977LTC2977QFN-64_9MMX9MM
U86FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U87LTC4365_DFN_DFN8-EPAD_3X2_LTC43LTC4365-1DFN8-EPAD_3X2
U88FDMC8878_VER2_FDMC8878_VER2_F_1FDMC2514SDCFDMC8878_VER2
U89LTM4620A_BGA-144_REVERSE_LTM462LTM4620ABGA-144_REVERSE
U90LTM4620A_BGA-144_REVERSE_LTM462LTM4620ABGA-144_REVERSE
U91LTC3877EUK_QFN-44_LTC3877EUKLTC3877EUKQFN-44
U95LTC3874IUFD#PBF_QFN-28_LTC3874ILTC3874IUFD#PBFQFN-28
U96LTM4637_LGA-133_LTM4637EV#PBFLTM4637EV#PBFLGA-133
X1SI516_571_XTAL_SI570_SI516_148.Si516_148.5M_148.35MXTAL_SI570
X2635L3C3_XTAL_EG2100_125.0MHZ125.0MHzXTAL_EG2100
X3SI570_ALT1_XTAL_SI570_SI570SI570XTAL_SI570
X4OSC_ALT_0_ECS3525_50MHZ50MHzECS3525
X5OSC_ALT_SM55-OSC_125MHZ125MHzSM55-OSC
X6OSC_ALT_XTAL_SG310_25.00MHZ25.00MHzXTAL_SG310
X7OSC_ALT_SM55-OSC_100MHZ100MHzSM55-OSC
Y1CRYSTAL_SM_13_XTAL_FA-128_24.0024.00MHzXTAL_FA-128
Y2CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzXTAL_FA-128
Y3CRYSTAL_SM_13_XTAL_FA-128_25.0025.00MHzXTAL_FA-128
重要提示:PCB作品文件展下载说明
  • 打卡总天数:341
  • 打卡月天数:24
  • 打卡总奖励:1126
  • 最近打卡:2026-09-24 13:04:51
16
新人进步奖社区居民最爱沙发
发表于 2026-9-4 18:03 | 显示全部楼层
  • 打卡总天数:643
  • 打卡月天数:23
  • 打卡总奖励:2709
  • 最近打卡:2026-09-24 19:19:54
74
发表于 2026-9-4 19:34 | 显示全部楼层
  • 打卡等级:以坛为家I
  • 打卡总天数:81
  • 打卡月天数:21
  • 打卡总奖励:303
  • 最近打卡:2026-09-24 09:00:47
发表于 2026-9-4 20:30 | 显示全部楼层
感谢版主的分享,赞一个
  • 打卡总天数:801
  • 打卡月天数:20
  • 打卡总奖励:2744
  • 最近打卡:2026-09-24 10:36:44
发表于 2026-9-4 23:28 | 显示全部楼层
  • 打卡总天数:228
  • 打卡月天数:23
  • 打卡总奖励:996
  • 最近打卡:2026-09-24 09:00:36
114
发表于 2026-9-5 05:44 | 显示全部楼层
  • 打卡总天数:545
  • 打卡月天数:24
  • 打卡总奖励:3529
  • 最近打卡:2026-09-24 09:00:00
44
1元学习Allegro(230718)
发表于 2026-9-5 07:40 | 显示全部楼层
  • 打卡总天数:776
  • 打卡月天数:24
  • 打卡总奖励:3572
  • 最近打卡:2026-09-24 09:02:41
PADS20220406高级特惠班
发表于 2026-9-5 08:03 来自手机 | 显示全部楼层
  • 打卡总天数:602
  • 打卡月天数:20
  • 打卡总奖励:1943
  • 最近打卡:2026-09-24 09:44:12
发表于 2026-9-5 08:05 | 显示全部楼层
  • 打卡总天数:612
  • 打卡月天数:20
  • 打卡总奖励:2190
  • 最近打卡:2026-09-24 09:02:09
122
终身成就奖特殊贡献奖社区居民忠实会员
发表于 2026-9-5 08:24 | 显示全部楼层
