| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| BT1 | BATTERY_BATTERY_18650_BATTERY | BATTERY | BATTERY_18650 |
| D1 | DIODESCHOTTKY_1_SOD-123_SMF6.0A | SMF6.0A | SOD-123 |
| D4 | LED_1_LED_0402_LED_GREEN | LED_GREEN | LED_0402 |
| D5 | LED_1_LED_0402_LED_RED | LED_RED | LED_0402 |
| D6 | DIODESCHOTTKY_1_SOD-123F_DS36W 3A | DS36W3A | SOD-123F |
| D7 | LED_1_LED_0402_LED_GREEN | LED_GREEN | LED_0402 |
| D8 | LED_1_LED_0402_LED_RED | LED_RED | LED_0402 |
| D9 | 1N5819HW-7-F_SOD-123_NSMD150 | nSMD150 | SOD-123 |
| D23 | DIODESCHOTTKY_1_LL-34_LL4148 | LL4148 | LL-34 |
| H1 | MECHANICAL_0_HOLE_NOPAD_4P8_MM_MECHANICAL | mechanical | HOLE_NOPAD_4P8_MM |
| H2 | MECHANICAL_0_HOLE_NOPAD_4P8_MM_MECHANICAL | mechanical | HOLE_NOPAD_4P8_MM |
| H3 | MECHANICAL_0_HOLE_NOPAD_4P8_MM_MECHANICAL | mechanical | HOLE_NOPAD_4P8_MM |
| H4 | MECHANICAL_0_HOLE_NOPAD_4P8_MM_MECHANICAL | mechanical | HOLE_NOPAD_4P8_MM |
| J2 | MOTOR_PIN2_BAT_CON2P_1R2_2R54_MOTOR_PIN2 | MOTOR_PIN2 | BAT_CON2P_1R2_2R54 |
| J3 | MOTOR_PIN2_BAT_CON2P_1R2_2R54_MOTOR_PIN2 | MOTOR_PIN2 | BAT_CON2P_1R2_2R54 |
| J4 | MOTOR_PIN2_BAT_CON2P_1R2_2R54_MOTOR_PIN2 | MOTOR_PIN2 | BAT_CON2P_1R2_2R54 |
| J5 | MOTOR_PIN2_BAT_CON2P_1R2_2R54_MOTOR_PIN2 | MOTOR_PIN2 | BAT_CON2P_1R2_2R54 |
| J6 | A2541HWV-1X4P_CONNECT_4P_2R54MM_A2541HWV-1X4P | A2541HWV-1x4P | CONNECT_4P_2R54MM |
| J7 | TYPC_C_16PIN_TYPE_C_16PIN_TYPC_C_16PIN | TYPC_C_16PIN | TYPE_C_16PIN |
| L3 | INDUCTOR_2520_WPN252012H2R2MT | WPN252012H2R2MT | 2520 |
| L4 | INDUCTOR_2520_WPN252012H3R3MT | WPN252012H3R3MT | 2520 |
| P1 | 5P_1_TEST4_1R2_2R54_CON4_2.54MM | CON4_2.54mm | TEST4_1R2_2R54 |
| Q11 | NPN_0_SOT23-3_SS8050IC=0.5A_ | SS8050Ic=0.5A | SOT23-3 |
| Q13 | SS8550_SOT23-3_SS8550 | SS8550 | SOT23-3 |
| SW1 | GPS_0_SS-12D16_SS-12D16 | SS-12D16 | SS-12D16 |
| TP1 | TP_SMD_TESTC_1R2_TP_100_SMD_ | tp_100_smd | TESTC_1R2 |
| TP4 | TP_SMD_TESTC_1R2_TP_100_SMD_ | tp_100_smd | TESTC_1R2 |
| TP5 | TP_SMD_TESTC_1R2_TP_100_SMD_ | tp_100_smd | TESTC_1R2 |
| TP7 | TP_SMD_TESTC_1R2_TP_100_SMD_ | tp_100_smd | TESTC_1R2 |
| U1 | ME4057ASPG_1_SOP-8_EP_150MIL_ME4057ASPG | ME4057ASPG | SOP-8_EP_150MIL |
| U2 | LN3406AFMR-G_1_TSOT23-8_MP2144GJ | MP2144GJ | TSOT23-8 |
| U3 | TC6291_SOT23-6_TC6291/FP6291LR-G1 | TC6291/FP6291LR-G1 | SOT23-6 |
| U4 | CONNECT_8.54MM_CONNECT_9P_2R54MM_CONNECT_9P_2R54MM | connect_9P_2r54mm | CONNECT_9P_2R54MM |
| U5 | CONNECT_7.54MM_CONNECT_40P_CONNECT_2.54MM | connect_2.54mm | CONNECT_40P |
| U6 | CONNECT_9.54MM_CONNECT_9P_2R54MM_CONNECT_9P_2R54MM | connect_9P_2r54mm | CONNECT_9P_2R54MM |
| U7 | CONNECT_10.54MM_CONNECT_9P_2R54MM_CONNECT_9P_2R54MM | connect_9P_2r54mm | CONNECT_9P_2R54MM |
| U8 | CONNECT_5.54MM_CONNECT_6P_2R54MM_CONNECT_6P_2R54MM | connect_6P_2r54mm | CONNECT_6P_2R54MM |
| U9 | CONNECT_5.54MM_CONNECT_6P_2R54MM_CONNECT_6P_2R54MM | connect_6P_2r54mm | CONNECT_6P_2R54MM |
| U10 | CONNECT_5.54MM_CONNECT_6P_2R54MM_CONNECT_6P_2R54MM | connect_6P_2r54mm | CONNECT_6P_2R54MM |
| U11 | CONNECT_6.54MM_CONNECT_3P_2R54MM_CONNECT_3P_2R54MM | connect_3P_2r54mm | CONNECT_3P_2R54MM |
| U12 | CONNECT_6.54MM_CONNECT_3P_2R54MM_CONNECT_3P_2R54MM | connect_3P_2r54mm | CONNECT_3P_2R54MM |
| U13 | CONNECT_6.54MM_CONNECT_3P_2R54MM_CONNECT_3P_2R54MM | connect_3P_2r54mm | CONNECT_3P_2R54MM |
| U14 | CONNECT_6.54MM_CONNECT_3P_2R54MM_CONNECT_3P_2R54MM | connect_3P_2r54mm | CONNECT_3P_2R54MM |
| U15 | CONNECT_6.54MM_CONNECT_3P_2R54MM_CONNECT_3P_2R54MM | connect_3P_2r54mm | CONNECT_3P_2R54MM |
| U16 | STM32F030K6T6_LQFP-32_7X7_STM32F030K6T6 | STM32F030K6T6 | LQFP-32_7X7 |
| U17 | MX1508_SOP16_MX1616L | MX1616L | SOP16 |
| U18 | MX1508_SOP16_MX1616L | MX1616L | SOP16 |
| U19 | CONNECT_11.54MM_CONNECT_5P_2R54MM_CONNECT_5P_2R54MM | connect_5P_2r54mm | CONNECT_5P_2R54MM |
| U20 | CONNECT_11.54MM_CONNECT_5P_2R54MM_CONNECT_5P_2R54MM | connect_5P_2r54mm | CONNECT_5P_2R54MM |
| U21 | CONNECT_6.54MM_CONNECT_3P_2R54MM_CONNECT_3P_2R54MM | connect_3P_2r54mm | CONNECT_3P_2R54MM |
| U22 | MX1508_0_SOP18_8_ULN2803A | ULN2803A | SOP18_8 |
| U23 | CH340C_1_SOP16_CH340C | CH340C | SOP16 |
| Y1 | CRYSTAL_SMD-5032_2P_SMD-5032_2P8M | SMD-5032_2P8M | SMD-5032_2P |
