- 打卡等级:初入少年
- 打卡总天数:2
- 打卡月天数:0
- 打卡总奖励:7
- 最近打卡:2025-11-23 12:45:13
- 291
Allegro_SKILL_Code.zip
480 KB, 下载次数: 140, 下载积分:金币 -1 枚
3d_length.il
addpinuse.il
add_device_label.il
add_symbol.il
align_sym.il
ASSEMBLY.IL
Associate_Components.il
autosilkUtils.il
Auto_Balancing.il
bbv_xsection.zip
bdct.tar.Z
build_ver.il
cds2f.il
cdwIsPointInsideCircle.il
cdw_axlLineXLine.il
checkWidth.il
check_short_segs.il
CLINECUT.IL
cnv_height.il
component_changes.il
component_height.il
comp_hght_rep.il
CONV.IL
Create_Thermal_Flash.il
cutshape.il
CWIDTH.IL
dangling_lines.il
datasheet.zip
defineclass.tar.Z
del_fp_prop.il
del_ood_shapes.il
del_unconn.il
dfa_assembly.il
dh_dummy_net.il
dp_rep.il
draw_targets.il
DRC_WALK.IL
etch_visibility.il
fcircle.il
FILESLIST111.TXT
film_reorder.il
Find_Component.il
find_dlines.il
Find_DRC.il
flare_conn.il
HEIGHT.IL
height_check.il
highlight_connected.il
highlight_padstack.il
HL_NPE.IL
HL_NTP.IL
hps.il
IPC_356.IL
jbhEditBoard.il
killallxdrc.il
lfsViewReports.il
list1esc_length.il
LISTRATT.IL
mirrorvia.il
Mirror_Text.il
MKDEV.IL
mot_find_stubs.il
myredraw.tar.Z
nclegend_list.il
NCP_drc.il
net_editor.il
NO_DRC.IL
ood_shapes.il
padinshape.tar.Z
PDI_VIS.IL
PICKDATA.IL
place_list.il
place_symbols.il
PRTOBJ.IL
qfp_pitch.il
Rename_Ref_Des.il
replace_via.il
REPLAY.IL
rep_bom_ignore.il
rep_ucshape.il
rm_nc_via.il
RULER.IL
runalgrplt.il
save_shape_drc.il
scalpel.il
set_refdes.il
shape_push.il
show_height.il
show_library.il
single_pin_net_check.il
slots.il
smd_pad_count.il
solder_paste.il
strip_bad_fillet_props.il
Symbol_Check.il
tekTechFileXML.zip
text_add.il
THERMAL.IL
upd_fe_height.il
utl_distance.il
utl_ptaccur.il
utl_sclass.il
vclistbuilder.zip
vc_SetOrigin.zip
via_pcs_check.il
via_prop.il
zrconnections.il |
