老吴 发表于 2017-2-21 14:54
Amlogic M802(M801) 平板电脑PCB AP6493+RN5T618
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAME1D1SCHOTTKY_SOD123H14A_B5819WB5819WSOD123H14A1D2DIODENN_SOT-23_BAT54CBAT54CSOT-231D3SCHOTTKY_SOD123H14A_B5819WB5819WSOD123H14A1D4SCHOTTKY_SOD123H14A_B5819WB5819WSOD123H14A1D5SCHOTTKY_SOD123H14A_B5819WB5819WSOD123H14A1J1DC-05-06_DC_SMD_5PIN_DC-SUNTY7.85DC-Sunty7.85DC_SMD_5PIN1L1INDUCTOR_POWER_L5050_1UH_3A_50181uH_3A_5018L50501L2INDUCTOR_POWER_L5050_1UH_3A_50181uH_3A_5018L50501L3INDUCTOR_POWER_L5050_1UH_3A_50181uH_3A_5018L50501L4INDUCTOR_POWER_L4040_2.2UH_2A2.2uH_2AL40401L5INDUCTOR_POWER_L4040_2.2UH_2A2.2uH_2AL40401L6INDUCTOR_POWER_L4040_2.2UH_2A2.2uH_2AL40401Q1MOSFETP_21_SOT-23_WPM2026WPM2026SOT-231SW2BUTTON_7PIN_SW-ST1114RA_NC/RESET_KEYNC/Reset_KEYSW-ST1114RA1TP1CON1_SPAD_CON1CON1SPAD1TP2CON1_SPAD1_CON1CON1SPAD11TP3CON1_SPAD_CON1CON1SPAD1U2RN5T618_QFN48-PT04-6X6MM_RN5T618MRN5T618MQFN48-PT04-6X6MM1U3ZEN056_0_ZEN056_NC/ZEN056NC/ZEN056ZEN0561U4BF1303_SOT23-5_WL2803E12-5WL2803E12-5SOT23-51U5BOOST-SOT236_SOT23-6_SY7208C/SY7152SY7208C/SY7152SOT23-61U6SY8009BABC_SOT23-6_SY8009BABC/2ASY8009BABC/2ASOT23-61U7BF1303_SOT23-5_WL2801E18-5WL2801E18-5SOT23-51U9BF1303_SOT23-5_NC/WL2801E28-5NC/WL2801E28-5SOT23-52J1CON4P_0_CON4-PT2MM-JTAG_NC/CON4PNC/CON4PCON4-PT2MM-JTAG2Y1CRYSTAL_1_XT-MC_146_XTAL_32.768KHZXTAL_32.768KHzXT-MC_1462Y2SMD_CRYSTAL_XT-SMD4P3225_24MHZ_12PF_20PPM24MHz_12pF_20PPMXT-SMD4P32253C13CAPNP_C0603_10UF_6.3V10uF_6.3VC06033TP2T POINTR_TEST08_T\POINT\RT\POINT\RTEST083U4DDR3_96P_16B_2CE_BGA96-0P8MM_H5TQ4G63AFR-PBCH5TQ4G63AFR-PBCBGA96-0P8MM3U5DDR3_96P_16B_2CE_BGA96-0P8MM_H5TQ4G63AFR-PBCH5TQ4G63AFR-PBCBGA96-0P8MM4C1CAPNP_C0402_NC/0.1UFNC/0.1uFC04024C2CAPNP_C0402_NC/1UF_6.3VNC/1uF_6.3VC04024U2EMMC_V50_BGA169-INAND_NC/SDIN7DP2-8GNC/SDIN7DP2-8GBGA169-INAND4U3TSD_FLASH_TSOP-48_NC/TSTS35-04G/NCTSXXX2-04G-08G/TSTS35-04G/NCTSXXX2-04G-08GTSOP-484U424C02A_6_SOIC-8-150MIL_NC/512KBYTE_SPI_NORNC/512KByte_SPI_NorSOIC-8-150MIL4U5NAND-ALL_11_TSOP-48_29F32G08CBACA29F32G08CBACATSOP-484U6NAND-ALL_11_TSOP-48_NC/29F32G08CBACANC/29F32G08CBACATSOP-485D1SCHOTTKY_SOD123H14A_B5819WB5819WSOD123H14A5J1B079XAN01_CON36-B079XAN01_B079XAN01B079XAN01CON36-B079XAN015L1INDUCTOR_POWER_L4040_10UH_1.2A10uH_1.2AL40405Q2MOSFETP_21_SOT-23_WPM2026WPM2026SOT-235R1RESISTOR_R0402_10K10KR04025R7RESISTOR_R0805_1.62R_1%1.62R_1%R08055R8RESISTOR_R0402_1.65K_1%1.65K_1%R04025R10RESISTOR_R0402_10K10KR04025R11RESISTOR_R0402_10K_1%10K_1%R04025R12RESISTOR_R0402_100K_1%100K_1%R04025R14RESISTOR_R0402_NC/10KNC/10KR04025R16RESISTOR_R0402_536R_1%536R_1%R04025R17RESISTOR_R0402_47K47KR04025R18RESISTOR_R0402_470K470KR04025R19RESISTOR_R0402_NC/1KNC/1KR04025U2AT1312_0_SOT23-6_SY7200AABCSY7200AABCSOT23-66C1CAPNP_C0402_0.1UF0.1uFC04026C2CAPNP_C0402_1NF1nFC04026C3CAPNP_C0402_1NF1nFC04026C4CAPNP_C0402_NC/10PFNC/10pFC04026C5CAPNP_C0402_1UF_6.3V1uF_6.3VC04026C6CAPNP_C0402_1NF1nFC04026C7CAPNP_C0805_22UF_6.3V22uF_6.3VC08056C8CAPNP_C0603_10UF_6.3V10uF_6.3VC06036C9CAPNP_C0402_1UF_6.3V1uF_6.3VC04026CON1JP_USB-0400ASMT_USB-P0565-H24-0336_MICROUSB PORTMicro USB PortUSB-P0565-H24-03366D8DIODESCHOTTKY_D0402_AZ5725-01FAZ5725-01FD04026FB1FB0805_0_L0805_120R/100MHZ_3A120R/100MHz_3AL08056J1CON-4PIN_SMD_FPC4-PT05-L_FPC-4PINFPC-4PINFPC4-PT05-L6L1L_EXD24CD900U_0_L0805X2_NC/EXD24CD900UNC/EXD24CD900UL0805X26U2TFCARD_TFC-01B_TF_SD_SOCKETTF_SD_SOCKETTFC-01B6U3U_RT9701_2_SOT23-5_SY6280AAACSY6280AAACSOT23-57FM1T POINTR_TEST08_T\POINT\RT\POINT\RTEST087FM2T POINTR_TEST08_T\POINT\RT\POINT\RTEST087J1ANT_0_MS-156_NCNCMS-1567L1INDUCTOR_1_L3030_NC/3.3UH_1ANC/3.3uH_1AL30307M1AP6493_6XXX_QFN44-PT09MM_NC/AP6210NC/AP6210QFN44-PT09MM7Q1MOSFETP_21_SOT-23_WPM2015WPM2015SOT-237Q2T_NPN_SOT-23_PMBT3904PMBT3904SOT-237TP3T POINTR_TEST08_T\POINT\RT\POINT\RTEST087U1EM78P372_1_WF-UM02BS_RTL8188-EUSRTL8188-EUSWF-UM02BS7U4NL27WZU04_SOT23-6_NC/NL27WZU04DTT1GNC/NL27WZU04DTT1GSOT23-67Y2SMD_CRYSTAL_XT-SMD4P3225_NC/26M_16PF_10PPMNC/26M_16pF_10ppmXT-SMD4P32257Y3SMD_CRYSTAL_XT-SMD4P3225_NC/26M_16PF_10PPMNC/26M_16pF_10ppmXT-SMD4P32258FB2FB0805_0_L0603_120R/100MHZ_0.3A120R/100MHz_0.3AL06038U5MMA8653FC_DFN10-PT04_MMA8653FCMMA8653FCDFN10-PT048U7MMA8452Q_QFN16-PT1-3X3_NC/MMA8452QNC/MMA8452QQFN16-PT1-3X38U8MPU-6885A_QFN24-PT04_NC/MPU-6500ANC/MPU-6500AQFN24-PT049CN1GC0328_FPC24-PT05-R_GC0308-30MGC0308-30MFPC24-PT05-R9D2DIODESCHOTTKY_D0402_AZ5725-01FAZ5725-01FD04029D3DIODESCHOTTKY_D0402_AZ5725-01FAZ5725-01FD04029FB1FB0805_L0603_120R/100MHZ_0.3A120R/100MHz_0.3AL06039J1HDMI_C_HDMI_JSHD_006_HDMI_CHDMI_CHDMI_JSHD_0069Q2MOSFETP_4_SOT-23_WNM2016WNM2016SOT-239Q3MOSFETP_4_SOT-23_WNM2016WNM2016SOT-239U2RCLAMP0524P_ESD-RCLAMP0524P_AZ1045-04FAZ1045-04FESD-RCLAMP0524P9U3RCLAMP0524P_ESD-RCLAMP0524P_AZ1045-04FAZ1045-04FESD-RCLAMP0524P9U4BF1303_SOT23-5_NC/WL2801E15-5NC/WL2801E15-5SOT23-5AFB1FB0805_L0603_0R0RL0603AFB2FB0805_L0603_0R0RL0603AJ1CON5_2_JH-RD-W06_ST-0279D00-061-182ST-0279D00-061-182JH-RD-W06AL+1CON1_SPAD_CON1CON1SPADAL-1CON1_SPAD_CON1CON1SPADAMK1MICROPHONE_0_MIC-6027C_MICROPHONEMICROPHONEMIC-6027CAU2AW8010A_BGA12-PT05_AW8010AFCRAW8010AFCRBGA12-PT05CCA1TF2010A4X_EMI-TF2010A4X_4X0R/TF2010A4X900MT4X0R/TF2010A4X900MTEMI-TF2010A4XCCA2TF2010A4X_EMI-TF2010A4X_4X0R/TF2010A4X900MT4X0R/TF2010A4X900MTEMI-TF2010A4XEC4CAPNP_C0402_1UF_6.3V1uF_6.3VC0402ECN1CON-6PIN_FPC6-PT05-R_CN_TOUCHCN_TOUCHFPC6-PT05-RED1DIODESCHOTTKY_D0402_NC/AZ5725-01FNC/AZ5725-01FD0402ED2DIODESCHOTTKY_D0402_NC/AZ5725-01FNC/AZ5725-01FD0402EFB1FB0805_L0603_120R/100MHZ_0.3A120R/100MHz_0.3AL0603ER1RESISTOR_R0402_1K1KR0402ER2RESISTOR_R0402_NC/0RNC/0RR0402ER3RESISTOR_R0402_NC/4.7KNC/4.7KR0402ER7RESISTOR_R0402_NC/10KNC/10KR0402U1AML-M802_BGA531_0P65_M801M801BGA531_0P65
老吴 发表于 2017-2-21 14:55
论坛这里有一份版本差一个的。这是V07 的。
http://bbs.ntpcb.com/read.php?tid=46816
现在发这个是V08 的。文件总体差不多,有一些小改动而已。
地沟油 发表于 2017-2-21 19:28
佝偻的戒指 发表于 2017-2-21 22:04
佝偻的戒指 发表于 2017-2-21 22:07
学海无涯 发表于 2017-2-22 06:47
sony545154 发表于 2017-2-22 08:50
vagrant_2k 发表于 2017-2-22 09:00
qrfbntel 发表于 2017-2-22 09:06
panups 发表于 2017-2-22 09:20
高端产品,支持一下。
查看完整版本: Amlogic M802(M801) 平板电脑PCB AP6493+RN5T618
