orcad library builder导出的时候报错
利用orcad library builder 16.6版本 制作原理图库,在最后一步导出的时候软件 提示 :log里面最后几行的信息是:
14:45:05 tcl/tk process exited with output
14:45:05 Export process returned with response
14:45:05 E-
14:45:05 E-Failed to export symbol.
14:58:35 In PDFExtractionForm FormClosing MdiFormClosing
14:58:35 In ScratchPadForm FormClosing MdiFormClosing
14:58:35 In SymbolViewForm FormClosing MdiFormClosing
14:58:35 In MainForm FormClosing UserClosing
14:58:35 In PDFExtractionForm FormClosing UserClosing
14:58:35 In ScratchPadForm FormClosing UserClosing
14:58:35 In SymbolViewForm FormClosing UserClosing
14:58:35 Application run completed 大神求赐教! 最后发现是没有破解完全!
回 huangxiaolove 的帖子
huangxiaolove:最后发现是没有破解完全! (2016-03-19 13:38) images/back.gif请问一下你是怎么破解的啊?我的事16.6的,用阿狸狗破解还是显示和你一样的 我的是这样的...也是没破戒好么?
13:29:09 tcl/tk process exited with output
13:29:09 Export process returned with response
13:29:09 E-Cadence install location not found
while executing
"# Compiled -- no source code available
error "called a copy of a compiled script""
invoked from within
"tbcload::bceval {
TclPro ByteCode 2 0 1.7 8.6
38 0 433 59 0 0 184 0 11 38 38 -1 -1
433
w0E<!-fSs!&-<<!,l4pv,TA9v.lvpv.EW<!e|/=!;Atpv4>UNw<k60%:>o9v`5L..."
(file "D:\\Cadence\\LibraryBuilder\\Scripts\\emaEdaBuilderUtils.enc" line 6)
13:29:09 E-Failed to export symbol. 楼主问题怎么解决的现在遇到同样的问题 1.无法创建或出错是因为更新了,需重新安装(16.6的打开会自动检查更新,请不要更新)
2.破解不成功需要将cl_util.dll重新覆盖掉安装目录的该文件
