gaoxiuzhang 发表于 2014-12-24 20:33
HDE_200C量产PCB+DSN  (TMS320DM642+LXT971ALC+MP1580+MT48
****************以下信息由管理员 @老吴   整理补充*******************
板子有以下主要元件和封装库,如有需要可以下载提取使用。
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEC1CAP NP_ET0603C_0.1UF0.1uFET0603CC2CAP NP_C3216_10UF10uFC3216C3CAP NP_C3216_10UF10uFC3216C4CAP NP_ET0603C_0.1UF0.1uFET0603CC5CAP NP_ET0603C_0.1UF0.1uFET0603CC6CAPPOL_C3216_10UF/10V10uF/10VC3216C7CAP NP_ET0603C_0.1UF0.1uFET0603CC8CAP NP_ET0603C_0.1UF0.1uFET0603CC9CAPPOL_C3216_10UF/10V10uF/10VC3216C10CAPPOL_C3216_10UF/10V10uF/10VC3216C11CAPPOL_C3216_10UF/10V10uF/10VC3216C12CAP NP_ET0603C_0.1UF0.1uFET0603CC13CAP NP_ET0603C_0.1UF0.1uFET0603CC14CAP NP_ET0603C_0.1UF0.1uFET0603CC15CAPPOL_C3216_10UF/10V10uF/10VC3216C16CAP NP_ET0603C_0.1UF0.1uFET0603CC17CAP NP_ET0603C_0.1UF0.1uFET0603CC18CAP NP_ET0603C_0.1UF0.1uFET0603CC19CAP NP_ET0603C_0.1UF0.1uFET0603CC20CAPPOL_C3216_10UF/10V10uF/10VC3216C21CAP NP_ET0603C_0.1UF0.1uFET0603CC22CAP NP_ET0603C_0.1UF0.1uFET0603CC23CAP NP_ET0603C_0.1UF0.1uFET0603CC24CAPPOL_C3216_10UF/10V10uF/10VC3216C25CAP NP_ET0603C_0.1UF0.1uFET0603CC26CAP NP_ET0603C_0.1UF0.1uFET0603CC27CAP NP_ET0603C_0.1UF0.1uFET0603CC28CAP NP_ET0603C_0.1UF0.1uFET0603CC29CAP NP_ET0603C_0.1UF0.1uFET0603CC30CAP NP_ET0603C_0.1UF0.1uFET0603CC31CAPPOL_C3216_10UF/10V10uF/10VC3216C32CAP NP_ET0603C_0.1UF0.1uFET0603CC33CAP NP_ET0603C_0.1UF0.1uFET0603CC34CAP NP_ET0603C_0.1UF0.1uFET0603CC35CAP NP_ET0603C_0.1UF0.1uFET0603CC36CAP NP_ET0603C_0.1UF0.1uFET0603CC37CAP NP_ET0603C_0.1UF0.1uFET0603CC38CAP NP_ET0603C_0.1UF0.1uFET0603CC39CAP NP_ET0603C_0.1UF0.1uFET0603CC40CAP NP_ET0603C_0.1UF0.1uFET0603CC41CAP NP_ET0603C_0.1UF0.1uFET0603CC42CAPPOL_C3216_10UF/10V10uF/10VC3216C43CAP NP_ET0603C_0.1UF0.1uFET0603CC44CAP NP_ET0603C_270PF270pFET0603CC45CAP NP_ET0603C_0.1UF0.1uFET0603CC46CAP NP_ET0603C_1NF1nFET0603CC47CAP NP_ET0603C_1NF1nFET0603CC48CAP NP_ET0603C_1NF1nFET0603CC49CAP NP_ET0603C_270PF270pFET0603CC50CAP NP_ET0603C_22PF22pFET0603CC51CAP NP_ET0603C_22PF22pFET0603CC52CAPNP_ET0603C_103/10NF103/10nFET0603CC53CAPPOL_D_7473_47UF/6.3V47uF/6.3VD_7473C54CAPPOL_D_7473_100UF/16V100uF/16VD_7473C55CAP NP_ET0603C_0.1UF0.1uFET0603CC56CAPNP_CAP-E-1210_22UF/25V22uF/25VCAP-E-1210C57CAPNP_ET0603C_104/0.1UF104/0.1uFET0603CC58CAP NP_ET0603C_2NF2nFET0603CC59CAP NP_ET0603C_100PF100pFET0603CC60CAPNP_ET0603C_103/10NF103/10nFET0603CC61CAPPOL_D_7473_100UF/16V100uF/16VD_7473C62CAP NP_ET0603C_0.1UF0.1uFET0603CC63CAPPOL_D_7473_47UF/6.3V47uF/6.3VD_7473C64CAPNP_CAP-E-1210_22UF/25V22uF/25VCAP-E-1210C65CAPNP_ET0603C_104/0.1UF104/0.1uFET0603CC66CAP NP_ET0603C_2NF2nFET0603CC67CAP NP_ET0603C_100PF100pFET0603CC68CAP NP_C3216_10UF10uFC3216C69CAP NP_ET0603C_0.1UF0.1uFET0603CC70CAPPOL_C3216_10UF/10V10uF/10VC3216C71CAP NP_ET0603C_0.1UF0.1uFET0603CC72CAP NP_ET0603C_0.1UF0.1uFET0603CC73CAP NP_ET0603C_0.1UF0.1uFET0603CC74CAP NP_ET0603C_0.1UF0.1uFET0603CC75CAPPOL_C3216_10UF/10V10uF/10VC3216C76CAP NP_ET0603C_0.1UF0.1uFET0603CC77CAP NP_ET0603C_0.1UF0.1uFET0603CC78CAP NP_ET0603C_0.1UF0.1uFET0603CC79CAP NP_ET0603C_0.1UF0.1uFET0603CD1LED_0805_LED_LEDLED0805_LEDD2DIODEBREAKDOWN_DIO1210_SK210SK210DIO1210D3DIODEBREAKDOWN_DIO1210_SK210SK210DIO1210J1SIP16_RJ45_LED_H_SIP16SIP16RJ45_LED_HJ2TP_1_TEST_A_TPTPTEST_AJ3TP_1_TEST_A_TPTPTEST_AJ4CON14_1_DIP14X2R54MM_CON14CON14DIP14X2R54MMJP1DIP12_B_17_SMD60PIN_1R27MM_DIP6DIP60SMD60PIN_1R27MMJP2DIP12_B_18_DIP22X1R27MM_DIP22DIP22DIP22X1R27MML1INDUCTOR_1206_C_1UH1uH1206_CL2INDUCTOR_1206_C_1UH1uH1206_CL3INDUCTOR_1206_C_1UH1uH1206_CL4INDUCTOR_1206_C_2.2UH2.2uH1206_CL5INDUCTOR_SMD54INL_150UH150uHSMD54INLL6INDUCTOR_10UH_L_10UH10uH10UH_LQ1NPN BCE_SOT23A_A_90149014SOT23A_AR1R_ET0603C_NOPNOPET0603CR2R_ET0603R_33R33RET0603RR3R_ET0603R_1K1KET0603RR4R_ET0603R_1K1KET0603RR5R_ET0603R_10K10KET0603RR6R_ET0603R_1K1KET0603RR7R_ET0603R_10K10KET0603RR8R_ET0603R_1K1KET0603RR9R_ET0603R_NOPNOPET0603RR10R_ET0603R_2K2KET0603RR11R_ET0603R_2K2KET0603RR12R_ET0603R_1K1KET0603RR13R_ET0603R_1K1KET0603RR14R_ET0603R_100K100KET0603RR15R_ET0603R_10K10KET0603RR16R_ET0603R_10K10KET0603RR17R_ET0603R_0R0RET0603RR18R_ET0603R_0R0RET0603RR19R_ET0603R_0R0RET0603RR20R_ET0603R_51R51RET0603RR21R_ET0603R_0R0RET0603RR22R_ET0603R_1.5K1.5KET0603RR23R_ET0603R_49.949.9ET0603RR24R_ET0603R_49.949.9ET0603RR25R_ET0603R_33R33RET0603RR26R_ET0603R_33R33RET0603RR27R_ET0603R_330R330RET0603RR28R_ET0603R_330R330RET0603RR29R_ET0603R_51R51RET0603RR30R_ET0603R_10K10KET0603RR31R_ET0603R_10K10KET0603RR32R_ET0603R_10K10KET0603RR33R_ET0603R_10K10KET0603RR34R_ET0603R_10K10KET0603RR35R_ET0603R_10K10KET0603RR36R_ET0603R_10K10KET0603RR37R_ET0603R_4.7K4.7KET0603RR38R_ET0603R_18K18KET0603RR39R_ET0603R_1K1KET0603RR40R_ET0603R_18K18KET0603RR41R_ET0603R_10K10KET0603RR42R_ET0603R_10K10KET0603RR43R_ET0603R_7.5K7.5KET0603RR44R_ET0603R_2.2K2.2KET0603RR45R_ET0603R_18K18KET0603RR46R_ET0603R_10K10KET0603RR47R_ET0603R_7.5K7.5KET0603RR48R_ET0603R_33R33RET0603RR49R_ET0603R_1K1KET0603RR50R_ET0603R_1K1KET0603RR51R_ET0603R_1K1KET0603RR52R_ET0603R_1K1KET0603RR53R_ET0603R_33R33RET0603RR54R_ET0603R_33R33RET0603RR55R_ET0603R_1K1KET0603RR56R_ET0603R_1K1KET0603RR57R_ET0603R_1K1KET0603RR58R_ET0603R_1K1KET0603RR59R_ET0603R_1K1KET0603RR60R_ET0603R_1K1KET0603RR61R_ET0603R_4.7K4.7KET0603RR62R_ET0603R_4.7K4.7KET0603RR63R_ET0603R_1K1KET0603RR64R_ET0603R_1K1KET0603RR65R_ET0603R_33R33RET0603RR66R_ET0603R_33R33RET0603RR67R_ET0603R_4.7K4.7KET0603RR68R_ET0603R_1K1KET0603RR69R_ET0603R_1K1KET0603RR70R_ET0603R_4.7K4.7KET0603RR71R_ET0603R_33R33RET0603RR72R_ET0603R_1K1KET0603RR73R_ET0603R_1K1KET0603RRP1RES_1_RP_0402A_10R10RRP_0402ARP2RES_1_RP_0402A_10R10RRP_0402ARP3RES_1_RP_0402A_10R10RRP_0402ARP4RES_1_RP_0402A_10R10RRP_0402ARP5RES_1_RP_0402A_10R10RRP_0402ARP6RES_1_RP_0402A_10R10RRP_0402ARP7RES_1_RP_0402A_10R10RRP_0402ARP8RES_1_RP_0402A_10R10RRP_0402ARP9RES_1_RP_0402A_10R10RRP_0402ARP10RES_1_RP_0402A_10R10RRP_0402ARP11RES_1_RP_0402A_10R10RRP_0402ARP12RES_1_RP_0402A__10R10RRP_0402ARP13RES_1_RP_0402A_10R10RRP_0402ARP14RES_1_RP_0402A_10R10RRP_0402ARP15RES_1_RP_0402A_10R10RRP_0402ARP16RES_1_RP_0402A_10R10RRP_0402ARP17RES_1_RP_0402A_10R10RRP_0402ARP18RES_1_RP_0402A_10R10RRP_0402ARP19RES_1_RP_0402A_10R10RRP_0402ARP20RES_1_RP_0402A_10R10RRP_0402ARP21RES_1_RP_0402A_10R10RRP_0402ARP22RES_1_RP_0402A_10R10RRP_0402ARP23RES_1_RP_0402A_10R10RRP_0402ARP24RES_1_RP_0402A_10R10RRP_0402ARP25RES_1_RP_0402A_10R10RRP_0402ARP26RES_1_RP_0402A_10R10RRP_0402ARP27RES_1_RP_0402A_10R10RRP_0402ASW1SWDIP-2_3_YST-1102US_SW DIP-2SW DIP-2YST-1102USU1TMS320DM642_3_GDK_S_PBGA_N548_DDM642GDK_S_PBGA_N548U2MAX706T_SOIC8_MAX706Tmax706tSOIC8U324C02_0_SOIC8_24C0224C02SOIC8U4MX29LV320B_1_TSOP_48L_MX29LV320MX29LV320TSOP_48LU5LXT971ALC_LQFP_64PIN_LXT971ALCLXT971ALCLQFP_64PINU6TXRX_0_XSFORMER_TXRXTXRXXSFORMERU7HOLE_A_HOLE_6X3R5_HOLE_AHOLE_AHOLE_6X3R5U8HOLE_A_HOLE_6X3R5_HOLE_AHOLE_AHOLE_6X3R5U9HOLE_A_HOLE_6X3R5_HOLE_AHOLE_AHOLE_6X3R5U10HOLE_A_HOLE_6X3R5_HOLE_AHOLE_AHOLE_6X3R5U11HOLE_A_MARK_HOLE_AHOLE_AMARKU12HOLE_A_MARK_HOLE_AHOLE_AMARKU13HOLE_A_MARK_HOLE_AHOLE_AMARKU14HOLE_A_MARK_HOLE_AHOLE_AMARKU15MP1580_SOIC8_MP1580MP1580SOIC8U16MP1580_SOIC8_MP1580MP1580SOIC8U17SDCARD_8_MICRO_SD_SDCARDSDCARDMICRO_SDU18MT48LC4M32_0_TSOP_86PIN_MT48LC4MT48LC4M32TSOP_86PINU19MT48LC4M32_0_TSOP_86PIN_MT48LC4MT48LC4M32TSOP_86PINY1OSC50M_1_QFN45R30X2R00_OSC50MOSC50MQFN45R30X2R00Y2ZTA_1_WR_12MHZ12MHZWRY3OSC50M_1_QFN45R30X2R00_OSC27MOSC27MQFN45R30X2R00
randy1022 发表于 2014-12-24 21:03
谢谢分享!!!!
267101126 发表于 2014-12-25 06:22
谢谢分享
yihong 发表于 2014-12-25 06:52
danqpm 发表于 2014-12-25 08:15
做什么用的,高端产品
kbh2006@163.com 发表于 2014-12-25 08:48
ytian668 发表于 2014-12-25 08:56
好东西,谢谢分享
cy_ygs 发表于 2014-12-25 09:06
好资料,看看
aabb888 发表于 2014-12-25 13:14
谢谢分享!
top 发表于 2017-3-20 17:29
查看完整版本: HDE_200C量产PCB+DSN  (TMS320DM642+LXT971ALC+MP1580+MT48LC4M32)
