armclub 发表于 2026-11-5 10:03
银河电力GalaxyPower 储能控制板PCB文件
   GP26-2520WV-4P1HDR-TH_4P-P2.54-V-F-R1-C41
FANCN2CONN-TH_2P-P2.50_HCTL_XH-2A-X1
LCDCN3CONN-TH_XH2.50-4P1
NTCCN5CONN-TH_2P-P2.50_HCTL_XH-2A-X1
ZMM3V6D1LL-34_L3.5-W1.5-RD1
MM1Z5V1WD2SOD-123F_L2.7-W1.7-LS3.7-RD-11
T4D3SOD-323_L1.8-W1.3-LS2.5-RD1
DSS310D4SOD-123FL_L2.7-W1.8-LS3.8-RD1
SS310D5, D7, D8, D9SMA_L4.3-W2.6-LS5.2-RD4
DC005_C431533DC1DC-IN-TH_DC0051
40AF1, F240A32V2
XF-508P-AFH1, FH2FUSE-TH_L19.8-W7.0_XF-508P-A2
2.54-1*4P母H1HDR-TH_4P-P2.54-V-F1
K2-3.6×6.1_SMDKEY1, KEY2KEY-SMD_2P-L6.2-W3.6-LS8.02
100uHL2IND-SMD_L8.0-W8.0_SMNR80401
60uHL31
19-217/BHC-ZL1M2RY/3TLED1LED0603-R-RD1
LEDLED2LED0603-RD1
CSD19505KCSQ3, Q4TO-220-3_L10.0-W4.5-P2.54-L2
SI2306Q5SOT-23-3L_L2.9-W1.6-P1.90-LS2.8-BL1
10kΩRN1, RN2RES-ARRAY-SMD_0603-8P-L3.2-W1.6-BL2
返回SW1KEY-TH_4P-L7.5-W6.8-P4.50-LS7.21
左SW2KEY-TH_4P-L7.5-W6.8-P4.50-LS7.21
右SW3KEY-TH_4P-L7.5-W6.8-P4.50-LS7.21
选择SW4KEY-TH_4P-L7.5-W6.8-P4.50-LS7.21
LP2992 3V3U1SOT23-51
INA226AIDGSRU2, U11MSOP-10_L3.0-W3.0-P0.50-LS5.0-BL2
5U3SOT-223-3_L6.7-W3.7-P2.30-LS7.0-BR1
XL7005AU4SOIC-8_L5.0-W4.0-P1.27-LS6.0-BL-EP2.01
IR2104U5SOIC-8_L4.9-W3.9-P1.27-LS6.0-BL1
BATU7CONN-TH_2P-P9.50_DBT50G-9.5-2P1
PVU9CONN-TH_2P-P9.50_DBT50G-9.5-2P1
测试环U121
B6B-XH-A(LF)(SN)U13CONN-TH_6P-P2.50_B6B-XH-A-LF-SN1
ESP32-SU14WIRELM-SMD_ESP32-S1
AF 10.0 HC6.3USB1, USB2USB-A-TH_AF-10.0-HC6.32
maomao_11 发表于 2026-11-5 14:45
看看再说
sym21ic 发表于 2026-11-5 15:21
bidinghong 发表于 2026-11-5 16:42
Redmin 发表于 2026-11-6 08:04
谢谢分享
io357 发表于 2026-11-6 08:15
bidezhi7777 发表于 2026-11-6 08:21
caodiren 发表于 2026-11-6 08:24
good good study, day day up
cy19840 发表于 2026-11-6 08:34
学习学习
liao0418 发表于 2026-11-6 08:36
谢谢分享
页: [1] 2 3
查看完整版本: 银河电力GalaxyPower 储能控制板PCB文件
