FH8626V100 FH8810 网络摄像头开发板PCB文件
摄像头模块板在这里 https://bbs.ntpcb.com/thread-239682-1-1.html
BT1BATTERY_CR1220_DISCRETE_CR1220CR1220CR1220
BT2BATTERY_IV01E_DISCRETE_NC/XH414NC/XH414HG-IV01EIV01E
CN1HEADER10X2_JTAG_10X2PIN 2.54MM10X2Pin2.54mmJTAG
CN2PHONE_JACK,3.5MM,90D,DIP_5P_PHOPHONE_JACKPHONE_JACK
CN4PHONE_JACK,3.5MM,90D,DIP_5P_PHOPHONE_JACKPHONE_JACK
CON1RJ45_LED_RJ45_LED-1_RJ45_LEDRJ45_LEDRJ45_LED-1
D1BV03CESD73031ND0402
D2BV03CESD73031ND0402
D3BV03CESD73031ND0402
D41N6265/TO_0_RGL55_GL5537-1GL5537-1RGL55
D5DIODE_2_DO-214AC_B250A-13FB250A-13FDO-214AC
D6TVS_DO-214AA_SMBJ15CASMBJ15CADO-214AA
D7LED_0_D0603_LEDREDLEDREDD0603
D8BV03CESD73031ND0402
D9BV03CESD73031ND0402
D12SBD_SOT23_LBAT54CLT1GLBAT54CLT1GSOT23
D13DIODE_1_SOD-323_IN4148WSIN4148WSSOD-323
D14TVS_D0402_ESD5431NESD5431ND0402
D15TVS_D0402_ESD73011NESD73011ND0402
D16TVS_DO-214AA_SPD4200BSPD4200BDO-214AA
D17TVS_DO-214AA_SPD4200BSPD4200BDO-214AA
D18TVS_D0402_ESD5431NESD5431ND0402
D19TVS_D0402_ESD5431NESD5431ND0402
D20TVS_D0402_ESD5431NESD5431ND0402
D23LED_LED0603_LEDGREENLEDGREENLED0603
D24LED_LED0603_LEDGREENLEDGREENLED0603
D25TVS_D0402_ESD73011NESD73011ND0402
D26TVS_D0402_ESD73011NESD73011ND0402
D27TVS_D0402_ESD73011NESD73011ND0402
D28TVS_D0402_ESD5431NESD5431ND0402
J1CON2_GMI6027P-2C_CON2-MICCON2-MICGMI6027P-2C
J2POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J3DCJACK_DC-3_DC-JACKDC-JackDC-3
J4CONNECT2_125MM_HEADER2_125MM_SM1.25T-2-2AHEADER2_125MM_SMD
J5MEC1-120-02-F-D-LC_HEADER20X2_1MEC1-120-02-F-D-LCHEADER20X2_1MM_SMD
J6CON3_SIP3_254MM_SIP3_254MMSIP3_254MMSIP3_254MM
J7CON4_HEADER4_125MM_UARTUartHEADER4_125MM
J8CONNECT2_125MM_HEADER2_125MM_SM1.25T-2-2AHEADER2_125MM_SMD
J9POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J10POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J11CON7_0_SIP4_254MM_SIP4_254MMSIP4_254MMSIP4_254MM
J12JUMP_SIP2_254MM_JUMPJumpSIP2_254MM
J13JUMP_SIP2_254MM_JUMPJumpSIP2_254MM
J14MIC_USB_MICRO_5P_OTG_USB/C91467OTG_USB/C91467MICRO_5P
J16POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J17POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J27SD_0_PROCONN_SD_SDCARDSDCardPROCONN_SD
J31POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J39POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J90USB-A_USBX1_SMD_USB-AUSB-AUSBX1_SMD
J111POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J112POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
J114POWERSWITCH_SIP3_254MM_SIP3_25SIP3_254MMSIP3_254MM
L1INDUCTOR_L3X3H15_SWPA3015S4R7MTSWPA3015S4R7MTL3X3H15
L2INDUCTOR_L3X3H15_SWPA3015S2R2NTSWPA3015S2R2NTL3X3H15
L3INDUCTOR_L3X3H15_SWPA3015S2R2NTSWPA3015S2R2NTL3X3H15
L4INDUCTOR_L4X4H3_SWPA4030S2R2NTSWPA4030S2R2NTL4X4H3
LED17LED_G_1_LED0603_DISCRETE_LED_RLED_RLED0603
MQ2AF2301P_SOT_23_AF2301PAF2301PSOT_23
Q1NPN_SOT23_2_MMBT3904MMBT3904SOT23_2
Q3MQ_AF2301P_0_SOT_23_AF2301PAF2301PSOT_23
Q4NPNBCE_0_SOT23_2_MMBT3904MMBT3904SOT23_2
Q5NPNBCE_0_SOT23_2_MMBT3904MMBT3904SOT23_2
S1PUSH_BUTTON_1_KEY_2PIN_KEY_2PINkey_2pinKEY_2PIN
S2PUSH_BUTTON_1_KEY_2PIN_KEY_2PINkey_2pinKEY_2PIN
SW1POWERSWITCH_0_PS_3PIN_POWER SWPOWERSWITCHPS_3PIN
U1DC-DC-SY8088AAC_2_QFN10-SGM7229SGM7229YUWQ10G/TRQFN10-SGM7229
U2QFN88_ZT_0_QFN88-ZT-SOCKET_QFN8QFN88_ZTQFN88-ZT-SOCKET
U3A52815_4_SOT23_5_TPS79333DBVRTPS79333DBVRSOT23_5
U4NORFLASH_SO8_200MIL_GD25Q127CSGD25Q127CSIG/W25Q128JVSIQSO8_200MIL
U5W25N01GV_SOP8_127_TH2_GD5F1GQ4UGD5F1GQ4UCYIG/W25N01GVZEIGSOP8_127_TH2
U6DC-DC-SY8120B_SOT23_6_SY8120BSY8120BSOT23_6
U7DC-DC-SY8088AAC_SOT23_5_SY8088ASY8088AACSOT23_5
U8TSX-3225_CRSTALY_3225_SX32Y0240SX32Y024000B91T-U_24MHz9PF 10ppmCRSTALY_3225
U9DC-DC-SY8088AAC_SOT23_5_SY8088ASY8088AACSOT23_5
U10DC-DC-SY8088AAC_SOT23_5_SY8088ASY8088AACSOT23_5
U12A52815_4_SOT23_SGM809-SXN3L/TRSGM809-SXN3L/TRSOT23
U13CON2X4_2_UART_27_5MM_UART_FIX_HUART_FIX_HOLEUART_27_5MM
U14PCF85163T/I_SOP8_PCF85163T/IPCF85163T/ISOP8
U15MC146_MC-146_Q13MC1462000200/32Q13MC1462000200/32.768KhzMC-146
U16AZ6208BM_SOP8_127-620X500_AZ620AZ6208BMSOP8_127-620X500
U18MC146_MC-146_Q13MC1461000600_3Q13MC1461000600_32.768kHz 6pF 20ppmMC-146
U19USR-TCP232-E2_USR-TCP232-E2_USRUSR-TCP232-E2USR-TCP232-E2
U21SWDIP8_3_SW_6X2_127_SMD_SW_6X2SW_6X2_127_SMDSW_6X2_127_SMD
U56PE-68515_1_SOP16_270_50_PPT44-1PPT44-11BPSOP16_270_50
U57IP101GR_QFN32_04_TH_IP101GRIP101GRQFN32_04_TH
:Q:Q:Q:Q:Q:Q:Q:Q:Q 可以可以 哇,非常好的资料 谢谢分享。 666666666666 :):):):):):)
