kkw117 发表于 2026-8-24 09:55
PWESD-5VSDE ESD静电保护管与同系列5V器件对比:电容0.7pF,适用于最高速接口[链接:系列选型对比表]
PWESD-5VSDE ESD 防护器件宣传页产品概述PWESD-5VSDE a 5.0V bi-directional TVS diode, utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making his device an ideal solution for protecting voltage sensitive high-speed data lines. The PWESD-5VSDE has a low capacitance with a typical value at 0.7pF,and complies with the IEC61000-4-2(ESD) standard with ±30kV air and ±30kV contact discharge. It is assembled into a leadfree SOD-323 package. The small size, low capacitance and high ESD surge protection make PWESD-5VSDE an idea choice to protect cell phone, wireless systems, and communication equipment.主要特性· Working Voltage 5.0V· Ultra Low Capacitance 0.7 pF· Low leakage current: nA Level· IEC 61000-4-2 (ESD Air): ±30kV· IEC 61000-4-2 (ESDContact): ±30kV· IEC61000-4-5(Lightning 8/20μS): 18A典型应用· High- speed data lines· Smart phones· USB Ports· Wireless Systems· Ethernet 10/100/1000 Base T关键参数
查看完整版本: PWESD-5VSDE ESD静电保护管与同系列5V器件对比:电容0.7pF,适用于最高速接口[链接:系列选型对比表]
