sii9000 发表于 2026-8-10 18:00
君正T41 方案PCB文件
D1DIODE_WY_SOD323_BZT52C12SBZT52C12SSOD323
D2LED_1_D0603_LED_LEDREDLEDRedD0603_LED
D3ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D4ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D5ESD_DFN1006_D1006WV05C150BTD1006WV05C150BTDFN1006
D6ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D7ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D8ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D9ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D10ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
D11ESD_DFN1006_D1006WV05C150BTD1006WV05C150BTDFN1006
D12ESD_DFN1006_D1006WV05C005BTD1006WV05C005BTDFN1006
F1FUSE_F1812_FUSE1.5AFUSE1.5AF1812
FB1BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402
FB3BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402
FB4BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402
FB5BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402
FB6BEAD_FB0402_1000OHM/250MA1000ohm/250mAFB0402
H1MHOLE1_MHOLE_3D0X2D0_MHOBLMHOBLMHOLE_3D0X2D0
H2MHOLE1_MHOLE_3D0X2D0_MHOBLMHOBLMHOLE_3D0X2D0
H3MHOLE1_MHOLE_3D0X2D0_MHOBLMHOBLMHOLE_3D0X2D0
H4MHOLE1_MHOLE_3D0X2D0_MHOBLMHOBLMHOLE_3D0X2D0
H5MHOLE1_MHOLE_3D0X2D0_MHOBLMHOBLMHOLE_3D0X2D0
H6MHOLE1_MHOLE_3D0X2D0_MHOBLMHOBLMHOLE_3D0X2D0
H8MHOLE1_MHOLE_4D8P_3D2H_MH_4.8MMMH_4.8mmP_3.2mmDMHOLE_4D8P_3D2H
J1DC_005_DC005_DC005POWER JACKDC005Power JackDC005
J2MMC_SD_TFCARD_MICROSD_TFMICROSD_TFTFCARD
J3USB_TYPEC_16P_TYPEC_A90_16P_SMDType-C-16PTYPEC_A90_16P_SMD
J4CON_4X1_CON4-1D0-WT_CON41.0MMCON41.0mm WTCON4-1D0-WT
J5FPCCON_15X2_FPC-CON30-0D5-LT_COCON300.5mm LTFPC-CON30-0D5-LT
J6FPCCON_15X2_FPC-CON30-0D5-LT_COCON300.5mm LTFPC-CON30-0D5-LT
J7HEADER2X1_A_SIP2M_2D54_CON1X2_2CON1X2_2.54PSIP2M_2D54
J8HEADER2X1_A_SIP2M_2D54_CON1X2_2CON1X2_2.54PSIP2M_2D54
J9HEADER2X1_A_SIP2M_2D54_CON1X2_2CON1X2_2.54PSIP2M_2D54
J10RJ45_1X1_LED_RJ45-LED-1A_RJ45WRJ45With LedRJ45-LED-1A
J11CON_2X1_CON2-1D25-LT_CON21.25MCON21.25mm LTCON2-1D25-LT
J12CON_2X1_CON2-1D25-LT_CON21.25MCON21.25mm LTCON2-1D25-LT
J13CON_5X1_CON5-1D5-LT_CON51.5MMCON51.5mm LTCON5-1D5-LT
J14CON_5X1_CON5-1D5-LT_CON51.5MMCON51.5mm LTCON5-1D5-LT
J15HEADER2X1_A_SIP2M_2D54_CON1X2_2CON1X2_2.54PSIP2M_2D54
J16SW3_PSW_3P_SW34.45MMSW34.45mmPSW_3P
J17HEADER3X1_SIP3M_2D54_HEADER32.HEADER32.54mmSIP3M_2D54
J18HEADER3X1_SIP3M_2D54_HEADER32.HEADER32.54mmSIP3M_2D54
J19HEADER2X1_A_SIP2M_2D54_CON1X2_2CON1X2_2.54PSIP2M_2D54
L1INDUCTOR_L2520_2.2UH/1.5A2.2uH/1.5AL2520
L2INDUCTOR_L2520_2.2UH/1.5A2.2uH/1.5AL2520
L3INDUCTOR_L4040_4.7UH/2.85A-40404.7uH/2.85A-4040L4040
L5INDUCTOR_L2520_2.2UH/2.1A2.2uH/2.1AL2520
L6INDUCTOR_CPCC_P4_L3216_4P_CW321CW3216L-2-600TFL3216_4P
L7INDUCTOR_P4_L0806_L2012_4P_SDMMSDMM0806U-2-900TL0806_L2012_4P
L8INDUCTOR_CPCC_P4_L3216_4P_CW321CW3216L-2-600TFL3216_4P
L9INDUCTOR_P4_L0806_L2012_4P_SDMMSDMM0806U-2-900TL0806_L2012_4P
Q1P_MOS_SOT23_WPM3401WPM3401SOT23
Q2N_MOS_SOT23_WNM2016WNM2016SOT23
Q3N_MOS_SOT23_WNM2016WNM2016SOT23
Q4N_MOS_SOT23_WNM2016WNM2016SOT23
Q5N_MOS_SOT23_WNM2016WNM2016SOT23
Q6N_MOS_SOT23_WNM2016WNM2016SOT23
Q7NPN_SOT23_MMBT3904MMBT3904SOT23
SW1PUSHBUTTON_SW2_SMD_KEY2_SMDKEY2_SMDSW2_SMD
T1MHOLE2_MHOLE_5D5P3D2H_MECHANICAMechanicalHoleMHOLE_5D5P3D2H
T2MHOLE2_MHOLE_5D5P3D2H_MECHANICAMechanicalHoleMHOLE_5D5P3D2H
T3MHOLE2_MHOLE_5D5P3D2H_MECHANICAMechanicalHoleMHOLE_5D5P3D2H
T4MHOLE2_MHOLE_5D5P3D2H_MECHANICAMechanicalHoleMHOLE_5D5P3D2H
U1SY8088_SOT23-5_TMI3101CTMI3101CSOT23-5
U2SY8120_SOT23-6_TMI3252STMI3252SSOT23-6
U3SY8088_SOT23-5_TMI3101CTMI3101CSOT23-5
U4TMI6030B_SOT23-5_TMI6030B-18TMI6030B-18SOT23-5
U5SY8088_SOT23-5_LN5059CMRLN5059CMRSOT23-5
U6T41_QFN96_QFN96_0D35_T41_T41QFT41QFN96QFN96_0D35_T41
U7SPI_NOR_WSOP8_1D27_ZB25VQ128DSJZB25VQ128DSJGWSOP8_1D27
U8BCT653EGG-TR_QFN24_0D4_BCT653_BBCT653EGG-TRQFN24_0D4_BCT653
U9SZ18201_QFN32_0D5_SZ18201_SZ182SZ18201QFN32_0D5_SZ18201
U11LN5010_SOT23-5_TMI6036-25TMI6036-25SOT23-5
U12CS8302_MSOP8_0D65_CS8302MCS8302MMSOP8_0D65
U13TMI8153_QFN20_3X3_TMI8153_TMI81TMI8153QFN20_3X3_TMI8153
Y1XTAL_P4_CRY_2D0X1D6_24M-201624M-2016CRY_2D0X1D6
qazyxb 发表于 2026-8-10 18:58
谢谢分享
竹青 发表于 2026-8-10 20:12
感谢分享
bidezhi7777 发表于 2026-8-10 20:13
a6682100 发表于 2026-8-10 23:19
我鲲怎么你了 发表于 2026-8-11 01:45
:loveliness::loveliness::loveliness::loveliness::loveliness:
kanxue_nmg 发表于 2026-8-11 03:14
junkyoung 发表于 2026-8-11 06:40
好好地学习。。。
江波波 发表于 2026-8-11 07:30
学习学习
杰克黄 发表于 2026-8-11 07:35
感谢分享
页: [1] 2 3 4 5 6 7
查看完整版本: 君正T41 方案PCB文件
