armclub 发表于 2026-5-27 22:58
Infineon Technologies EZ-USB™ FX20开发套件 (DVK) PCB 原理图
英飞凌EZ-USB™ FX20开发套件 (DVK) 配有FPGA夹层卡(FMC)接口,通过将DVK插入任何FMC插座,即可将FX20连接到大多数FPGA开发平台。英飞凌EZ-USB FX20 DVK提供了插头,以便快速访问外围接口,如串行通信模块 (SMB)、GPIO和调试端口。
CC1TPOINT R_SMD_1MM_T POINT RTPOINT RSMD_1MM
CC2TPOINT R_SMD_1MM_T POINT RTPOINT RSMD_1MM
D1BZX84C18/SOT_1_TSSLP2-4__ESD150ESD150-B1-W0201TSSLP2-4
D16BZX84C18/SOT_1_TSSLP2-4__ESD245ESD245-B1-W0201TSSLP2-4
D17BZX84C18/SOT_1_TSSLP2-4__ESD245ESD245-B1-W0201TSSLP2-4
F1FUSE_RESC1608_0603M_PTSLR06036VPTSLR06036V300RESC1608_0603M
FB1INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
FB2INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
FB3INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
FB4INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
FB5INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
FB6INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
FB7INDUCTORFERRITE_SMD0402_220OHM220Ohm@100MHzSMD0402
GNDTPOINT R_TP40X20_T POINT RTPOINT RTP40X20
J1CON3_SAMTEC_HTSW-103-XX-X-S_961961103-6404-ARSAMTEC_HTSW-103-XX-X-S
J2USB-PD_TYPE-C_NEW_8_JAE_DX07S02DX07S024XA8R700JAE_DX07S024XA8R700
J3USB-PD_TYPE-C_NEW_8_GCT_USB4085USB4085-GF-AGCT_USB4085-GF-A
J5CON40A_3M_9140-4500PL_613040218613040218213M_9140-4500PL
J61X5_100MIL_HDR_0_BERG_1X5_PH1-0PH1-05-UABERG_1X5
J7ASP-134488-01_SAMTEC_ASP-134486ASP-134486-01SAMTEC_ASP-134486-01
J8ASP-134488-01_SAMTECH_ASP-13448ASP-134488-01SAMTECH_ASP-134488-01
J9CON3_SAMTEC_HTSW-103-XX-X-S_961961103-6404-ARSAMTEC_HTSW-103-XX-X-S
J10CON3_SAMTEC_HTSW-103-XX-X-S_961961103-6404-ARSAMTEC_HTSW-103-XX-X-S
J12CON3_SAMTEC_HTSW-103-XX-X-S_961961103-6404-ARSAMTEC_HTSW-103-XX-X-S
J13CON3_SAMTEC_HTSW-103-XX-X-S_961961103-6404-ARSAMTEC_HTSW-103-XX-X-S
J14HEADER_1X2_CTST254P1X02_W260_96961102-6404-ARCTST254P1X02_W260
L2INDUCTOR_IND_ASPI-0530LR-1R5M-T1.5uHIND_ASPI-0530LR-1R5M-T2
L3INDUCTOR_INDM7066X400N_2.2UH2.2uHINDM7066X400N
PWRONLED_2_LED_0603_GREEN_VAOL-S6GT4GREENLED_0603
SW2EVQ-PE105K_0_SW_EVQ-PE105K_EVQ-EVQ-PE105KSW_EVQ-PE105K
SW3EVQ-PE105K_0_SW_EVQ-PE105K_EVQ-EVQ-PE105KSW_EVQ-PE105K
TCKTPOINT R_TP40X20_T POINT RTPOINT RTP40X20
TRST_CTPOINT R_TP40X20_T POINT RTPOINT RTP40X20
TRST_MTPOINT R_TP40X20_T POINT RTPOINT RTP40X20
U1FX3G2_52_BGA169C75P13X13_1000X1FX20BGA169C75P13X13_1000X1000X100_CYPS
U2IR3883MTRPBF_4_IR3883MTRPBF_16PIR3883MTRPBFIR3883MTRPBF_16PQFN
U4SPI_FLASH_W25Q80BW_5_COMBINED_SS25FS256SDSNFI000COMBINED_SOC008_WND008_CYPS
U5SPI_FLASH_W25Q80BW_5_COMBINED_SS25FS256SDSNFI000COMBINED_SOC008_WND008_CYPS
U6IR3883MTRPBF_4_IR3883MTRPBF_16PIR3883MTRPBFIR3883MTRPBF_16PQFN
U7BSD23_SOT363-6M_BSD235NH6327XTSBSD235NH6327XTSA1SOT363-6M
U8BSD23_SOT363-6M_BSD235NH6327XTSBSD235NH6327XTSA1SOT363-6M
USB3V18TPOINT R_SMD_1MM_T POINT RTPOINT RSMD_1MM
USER_LEDLED_3_LED_0603_GREEN_VAOL-S6GT4GREENLED_0603
V1P8TPOINT A_CIRCLE1MM_TP_1MMTP_1MMCIRCLE1MM
V3P3STPOINT A_CIRCLE1MM_TP_1MMTP_1MMCIRCLE1MM
V3P3_AUXTPOINT A_CIRCLE1MM_TP_1MMTP_1MMCIRCLE1MM
V3P3TPOINT A_CIRCLE1MM_TP_1MMTP_1MMCIRCLE1MM
V12P0TPOINT A_CIRCLE1MM_TP_1MMTP_1MMCIRCLE1MM
V33TPOINT R_SMD_1MM_T POINT RTPOINT RSMD_1MM
VADJTPOINT R_TP40X20_T POINT RTPOINT RTP40X20
VBUS_CTPOINT A_CIRCLE1MM_TP_1MMTP_1MMCIRCLE1MM
VCCDTPOINT R_SMD_1MM_T POINT RTPOINT RSMD_1MM
VDDDTPOINT R_SMD_1MM_T POINT RTPOINT RSMD_1MM
Y1CRYSTAL_1_OSCCC200X250X65-4N_ECECS-240-8-36CKM-TROSCCC200X250X65-4N
电路PCB爱好者 发表于 2026-5-28 06:28
感谢分享
bidezhi7777 发表于 2026-5-28 07:33
13412678220 发表于 2026-5-28 08:12
飞扬11 发表于 2026-5-28 08:12
感谢分享
io357 发表于 2026-5-28 08:15
danqpm 发表于 2026-5-28 08:28
闪耀的空白 发表于 2026-5-28 08:33
多谢分享
maogege-chen 发表于 2026-5-28 08:37
longxuekai 发表于 2026-5-28 08:42
学习一下的
页: [1] 2 3 4
查看完整版本: Infineon Technologies EZ-USB™ FX20开发套件 (DVK) PCB 原理图
