RK3576+GSV6127+LT7911C+ADV7180+ALC5640 做的机顶盒PCB文件共享6层设计 UMG700_V10
**** Hidden Message *****
REFDESCOMP_DEVICE_TYPESYM_NAME
C3844CAPNP_C0201_100NFC0201
CN1HDMI_TYPEA_HDMI_HDMI_A_FEMAL_SMDHDMI
CN3TFCARD_SOCKET_3_SD3_SD3SD3
CON1AV_2_AV_5_AVAV_5
CON2M-DIN_2_S-VIDEO_S-VIDEOS-VIDEO
CON3DIODEZENER_1_R0402_NC/SD05CR0402
CON4TMP_151315_2PIN1_25-ME_FAN2PIN1_25-ME
D2DIODEZENER2_ESD0603_PSUR1610DNV07ESD0603
D3DIODE_SOD_323_B5819WSSOD_323
D4DIODEDOUBLE_SOT_23_BAT54CSOT_23
D8DIODE_SOD-323N_IN5819SOD-323N
D9DIODE_1_SOD_323_T4SOD_323
D10DIODE_DO_214AB_SS32DO_214AB
D11DIODE_1_SOD-123_SS54SOD-123
D12DIODE_1_SOD-123_SS54SOD-123
D13DIODE_SOD-323N_IN5819SOD-323N
D14SD107WS_0_SOD_323_NC/SD103CWSSOD_323
D15SM340A_0_SOD_323_1N5819SOD_323
D16RCLAMP0524P_SLP2510P8_BTRD10D01SLP2510P8
D17RCLAMP0524P_SLP2510P8_NC/RCLAMP0524PSLP2510P8
D18RCLAMP0524P_SLP2510P8_NC/RCLAMP0524PSLP2510P8
D24DIODE_2_SOD-323N_RB751VSOD-323N
D25DIODEZENER_1_ESD0402_NC/ESDESD0402
D42DIODEZENER_1_ESD0402_NC/ESDESD0402
D43DIODE_SOD_323_B5819WSOD_323
D44DIODE_SOD_323_B5819WSSOD_323
D45DIODE_SOD_523_RB520S-30SOD_523
D46DIODEDOUBLE F_SOT-23A_BAT54SWSOT-23A
D47DIODEDOUBLE F_SOT-23A_BAT54SWSOT-23A
D48DIODEZENER_1_SOD_323_MMPZ5233BPT/18VSOD_323
D49DIODEZENER_1_SOD_323_MMPZ5233BPT/6.8VSOD_323
D50BAT54S_SOT-23_BAT54SSOT-23
D51BAT54C_SOT-23_BAT54CSOT-23
D52ESD_DFN1006-2L_JEB05DFCSDFN1006-2L
ED1DIODEZENER_1_ESD0402_NC/ESDESD0402
ED2DIODEZENER_1_ESD0402_NC/ESDESD0402
ED3DIODEBI_DIR TRIG_ESD0402_ESD5451NESD0402
ED4DIODEBI_DIR TRIG_ESD0402_ESD5451NESD0402
ED5DIODEBI_DIR TRIG_ESD0402_ESD5451NESD0402
ED6DIODEBI_DIR TRIG_ESD0402_ESD5451NESD0402
ED7DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED8DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED9DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED10DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED11DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED12ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034DSON10_2R50X1R00X0R50
ED13ESD56161D24_DFN3_2R00X2R00X0R65_ESD56161D24DFN3_2R00X2R00X0R65
ED14DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED15ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034DSON10_2R50X1R00X0R50
ED16DIODEBI_DIR TRIG_ESD0402_ESD5311XESD0402
ED17DIODEBI_DIR TRIG_ESD0402_ESD5311XESD0402
ED18DIODEBI_DIR TRIG_ESD0402_ESD5311XESD0402
ED19DIODEBI_DIR TRIG_ESD0402_ESD5311XESD0402
ED20DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED21DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED22DIODEBI_DIR TRIG_ESD0402_ESD5471XESD0402
ED23DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED24DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED25DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED26DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED27DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED28DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED29ESD_ESD73034D_SLP2510P8_ESD73034DSLP2510P8
ED30DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NESD0402
ED70DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED71ESD_ESD73034D_SLP2510P8_ESD73034DSLP2510P8
ED72DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED74DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED75DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
ED76DIODEBI_DIR TRIG_ESD0402_ESD5341NESD0402
F3FUSE_F8050_JK-SMD150LF8050
FB1BEAD_L0603_120R-100ML0603
FB11BEAD_L0402_220R-100ML0402
FB19INDUCTOR_0_L0402_FB60RL0402
FB20BEAD_L0603_220R-100ML0603
FB21FERRITBEAD_L0603_FB120RL0603
FB22FERRITBEAD_L0603_FB120RL0603
FB23FERRITBEAD_L0603_FB300R/NCL0603
FB24FERRITBEAD_L0603_FB120RL0603
FB25FERRITBEAD_L0603_FB120RL0603
FB26BEAD_L0603_120R-100ML0603
FB27BEAD_L0603_120R-100ML0603
FB28FERRITBEAD_L0603_FB120RL0603
FB29BEAD_L0603_120R-100ML0603
FB30BEAD_L0603_120R-100ML0603
IR1IRM_3638_IJ3_IRM_3638_IRM_3638IJ3_IRM_3638
J1CON_BATTERY-20MM_CAPFL_CR1220-3VCAPFL
J5TESTPOINT_TP_TPTP
J6Y83989MIPI LCD_0_FPC_30PIN_0R5_FPC30-05FPC_30PIN_0R5
J7Y83989MIPI LCD_2_FPC_30PIN_0R5_FPC30-05FPC_30PIN_0R5
J8CON3X1X254MM_0_CON2X1X254MM_CON2X1X254MMCON2X1X254MM
J10CON_BATTERY-20MM_BAT2032_CR1220-3VBAT2032
J12TESTPOINT_TP_TPTP
J13PHONEJACKSTEREO SW_10_PJ-326-2_PHONEJACKPJ-326-2
J14PHONEJACKSTEREO SW_9_PJ-326-2_PHONEJACKPJ-326-2
J15HR911130C_RJ45_HR911130C_HR911130CRJ45_HR911130C
J16AUDIO_SPK_JACK_1_2PIN1_25-ME_AUDIO_SPK_JACK_2P_V2PIN1_25-ME
J17AUDIO_SPK_JACK_1_2PIN1_25-ME_AUDIO_SPK_JACK_2P_V2PIN1_25-ME
J18USB30_TYPE-CRECEPTACLE_3_TYPE-C-24P-QCHT_USB30_TYPE-CTYPE-C-24P-QCHT
J19USBA_4_USB30_AF_SMT_THF_USB30_AF_SMT_THFUSB30_AF_SMT_THF
J20PHONEJACKSTEREO SW_10_PJ-326-2_PHONEJACKPJ-326-2
J21HDMI_A_HDMI_HDMI_AHDMI
J23CON4_1X4_CN4M_2R54_V_DIP_CN4M_2R54_V_DIPCN4M_2R54_V_DIP
J24RADIATOR_0_RADIATOR_38RX38RX10R_RADIATOR_38X38RADIATOR_38RX38RX10R
J25DCJACK_0_DC_005B_DC-005BDC_005B
J26CON_BATTERY-20MM_0_4PIN1_25-SMD_BAT_3.7V*24PIN1_25-SMD
J27CON_BATTERY-20MM_0_4PIN1_25-SMD_BAT_3.7V*24PIN1_25-SMD
J28HDMI_TYPE_A_HDMI_HDMIHDMI
J29PHONEJACKSTEREO SW_9_PJ-326-2_PHONEJACKPJ-326-2
J30RADIATOR_FAN_2_RADIATOR_FAN_RADIATOR_FAN_65X65RADIATOR_FAN
J31TESTPOINT_TP_TPTP
J32TESTPOINT_TP_TPTP
J33TESTPOINT_TP_TPTP
L1INDUCTORSOF FERRITE_IND_667028_4.7UHIND_667028
L2INDUCTORSOF FERRITE_IND_404020_2.2UHIND_404020
L3INDUCTORSOF FERRITE_IND_201610_0.47UHIND_201610
L4INDUCTORSOF FERRITE_IND_252012_0.24UHIND_252012
L5INDUCTORSOF FERRITE_IND_201610_0.47UHIND_201610
L6INDUCTORSOF FERRITE_IND_252012_0.24UHIND_252012
L7INDUCTORSOF FERRITE_IND_201610_0.47UHIND_201610
L8INDUCTORSOF FERRITE_IND_252012_0.24UHIND_252012
L9INDUCTORSOF FERRITE_IND_201610_0.47UHIND_201610
L10INDUCTORSOF FERRITE_IND_252012_0.24UHIND_252012
L11INDUCTORSOF FERRITE_IND_201610_0.47UHIND_201610
L12INDUCTORSOF FERRITE_IND_201610_0.47UHIND_201610
L13INDUCTORSOF FERRITE_IND_252010_1.0UHIND_252010
L14INDUCTORSOF FERRITE_IND_252010_1.0UHIND_252010
L15INDUCTORSOF FERRITE_PI43_4.7UH/4026PI43
L16INDUCTORSOF FERRITE_PI43_10UH/4026PI43
L17INDUCTORSOF FERRITE_IND_303015_3.3UHIND_303015
L19FERRITBEAD_L0603_120R/300MAL0603
L20FERRITBEAD_L0603_300R/300MAL0603
L21FERRITBEAD_L0603_120R/1.5AL0603
L22INDUCTORSOF FERRITE_IND_303015_2.2UHIND_303015
L23L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5L0603
L24L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5L0603
L25L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5L0603
L26FERRITBEAD_L0603_120R/300MAL0603
L27L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5L0603
L28L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5L0603
L29INDUCTORCOM_RP2_0405_NCRP2_0405
L30INDUCTORCOM_RP2_0405_NCRP2_0405
L32BEAD_L0603_FB300RL0603
L33L0603-M_BEAD_300R_1A5_CHILISI_0_L0603_300R/1A5L0603
L34INDUCTORSOF FERRITE_L-SH2016_2.2UHL-SH2016
L35INDUCTORSOF FERRITE_L-SH2016_2.2UHL-SH2016
LED3LED_LED0603AC_LED_BLUELED0603AC
LED4LED_LED0603AC_LED_REDLED0603AC
LED5LED_LED0603AC_LED_GREENLED0603AC
LED6LED_LED0603AC_LED_GREENLED0603AC
LED7LED_LED0603AC_LED_BLUELED0603AC
LED8LED_LED0603AC_LED_BLUELED0603AC
LED9LED_LED0603AC_LED_BLUELED0603AC
LED10LED_LED0603AC_LED_GREENLED0603AC
LED11LED_LED0603AC_LED_GREENLED0603AC
LED12LED_LED0603AC_LED_GREENLED0603AC
LED13LED_LED0603AC_LED_GREENLED0603AC
LED14LED_LED0603AC_LED_GREENLED0603AC
M1MARK_MARK_MARKMARK
M2MARK_MARK_MARKMARK
M3MARK_MARK_MARKMARK
M4MARK_MARK_MARKMARK
M5MARK_MARK_MARKMARK
M6MARK_MARK_MARKMARK
P1TP_TP1_TPTP1
Q2MOSFETN_SOT_23_WNM2016-3/TRSOT_23
Q3MOSFETN_SOT_323_WNM2021-3/TRSOT_323
Q11MOSFETP_SOT_23_TSM2301SOT_23
Q12MOSFETP_SOT_23_WPM2341-3/TRSOT_23
Q13NPN_SOT_23_MMBT3904SOT_23
Q14NPN_SOT_23_S8050SOT_23
Q15NPN_SOT_23_S8050SOT_23
Q16MOSFETP_SOT_23_TSM2301SOT_23
Q17MOSFETP_SOT_23_WPM2341-3/TRSOT_23
Q18NPN_SOT_23_MMBT3904SOT_23
Q19MOSFETN_SOT_323_WNM6002-3/TRSOT_323
Q20MOSFETN_SOT_323_WNM6002-3/TRSOT_323
Q23MOSFETN_SOT23_WNM2016-3/TRSOT23
Q24MOSFETN_SOT23_WNM2016-3/TRSOT23
Q25MOSFETN_SOT_323_WNM6002-3/TRSOT_323
Q26MOSFETN_SOT_323_WNM6002-3/TRSOT_323
Q27NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DFPDFN_3X3_8L
Q28NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DFPDFN_3X3_8L
Q29NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DFPDFN_3X3_8L
Q30MOSFETN_SOT_23_SI2302SOT_23
Q31NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DFPDFN_3X3_8L
Q32NP4419_P_ESOP-8_PDFN_3X3_8L_AP20P03DFPDFN_3X3_8L
Q33NP4446_N_ESOP-8_PDFN_3X3_8L_AP68N03DFPDFN_3X3_8L
Q34NP4446_N_ESOP-8_PDFN_3X3_8L_AP68N03DFPDFN_3X3_8L
Q35NPN_SOT_23_MMBT3904SOT_23
Q36MOSFETN_SOT_23_WNM3003-3/TRSOT_23
Q37MOSFETN_SOT_323_2SK3018SOT_323
Q38MOSFETN_SOT_323_WNM6002-3/TRSOT_323
Q39MOSFETN_SOT_323_WNM6002-3/TRSOT_323
Q40MOSFETN_SOT_323_2SK3018SOT_323
Q41MOSFETN_SOT_323_2SK3018SOT_323
Q42MOSFETN_SOT_323_2SK3018SOT_323
Q43MOSFETN_SOT_323_2SK3018SOT_323
Q44NPN_SOT_23_MMBT3904SOT_23
R3804RESISTOR5_NC_R0201_240RR0201
RN1RESARR_IS_4/SO_RP0402X4_47RRP0402X4
RN2RESARR_IS_4/SO_RP0402X4_47RRP0402X4
S3BR-11C-11P62PIN1_25-ME
SW1SW4P_0_SW-SMD-5_2X5_2X1_5_UPSW-SMD-5_2X5_2X1_5
SW15SW4P_0_SW-SMD-5_2X5_2X1_5_DOWN/MICSW-SMD-5_2X5_2X1_5
U1SOC_RK3576_BGA698_16R1X17R2X1R18__RK3576BGA698_16R1X17R2X1R18
U2GD25Q40E/20E_SOP-8_3R90X4R90X1R27_HK25Q40ESOP-8_3R90X4R90X1R27
U3FP6809_SOT-23_FP6809-29NS3GSOT-23
U6TMI3255S_SOT_23_6_TMI3255SSOT_23_6
U7TMI3253SH_SOT_23_6_TMI3253SHSOT_23_6
U8PMIC_RK806S-5_QFN68_7R00X7R00X0R80_T_RK806S-5QFN68_7R00X7R00X0R80_T
U9DCDC_ETA3409_SOT_23_5_TMI3112HSOT_23_5
U10DCDC_ETA3409_SOT_23_5_TMI3112HSOT_23_5
U11CW3301_LOADSWITCH_WLCSP4_0R80X0R80X0R50_CW3301WLCSP4_0R80X0R80X0R50
U12SWITCH_SY6280_SOT_23_5_SGM2590DSOT_23_5
U13LDO_PT5108_SOT_23_5_TMI6050-33SOT_23_5
U14RTC_HYM8563_TSSOP8_3R10X3R10X1R10_HYM8563TSTSSOP8_3R10X3R10X1R10
U16DCDC_MP1488_SOT-23-6_AP3031SOT-23-6
U17DCDC_SY7069_0_SOT-23-6_CP2121STSOT-23-6
U18LT7911C_0_LT6911C_QFN64_EPAD_LT6911UXE/UXCLT6911C_QFN64_EPAD
U19DCDC_SY8088_SOT_23_5_SY8088AACSOT_23_5
U21INAND_EMMC_153_2L_BGA153_EMMC_EMMC_B153_2LBGA153_EMMC
U2202.ADI_ADV7180_LFCSP32_LFCSP_32P_ADI_ADV7180_LFCSP32LFCSP_32P
U23LDO_PT5108_SOT_23_5_SGM2019SOT_23_5
U24LDO_PT5108_SOT_23_5_SGM2019SOT_23_5
U2507_CRY3225-12M_XTL571300-W79-00_CRY3325_12.288MHZ/NCCRY3325
U2602_0.WOLFSON_WM8960_QFN32_QFN-32P_0_5_5X5_NAU88C22YG/QFN32QFN-32P_0_5_5X5
U27MS7124_SOIC8-1_27-150MIL_MS7124SOIC8-1_27-150MIL
U2827_ALC5640-VB-CG_QFN48B-6X6-040_QFN48B-6X6-040_ALC5640-VB-CGQFN48B-6X6-040
U29ETHERNET_RK631A_QFN40_5R00X5R00X0R90_T_RK631AQFN40_5R00X5R00X0R90_T
U3008_LP5907MFX-3.1/NOPB_SOT23-5_SOT23-5_LP5907MFX-3.1/NOPBSOT23-5
U31LDO_PT5108_SOT_23_5_SGM2019SOT_23_5
U32USB_FUSB302B_MLP14_2R50X2R50X0R80_HUSB311MLP14_2R50X2R50X0R80
U33WS3221_CSP6L_1R25X0R77X0R63_WS3221CCSP6L_1R25X0R77X0R63
U34SWITCH_SY6280_SOT_23_5_SGM2590DSOT_23_5
U35SWITCH_SY6280_SOT_23_5_SGM2590DSOT_23_5
U36SWITCH_SY6280_SOT_23_5_SGM2590DSOT_23_5
U38LDO_PT5108_SOT_23_5_SGM2019SOT_23_5
U42XBM3215_SOT-23-6_BM3215SOT-23-6
U43XBM3215_SOT-23-6_BM3215SOT-23-6
U4412_FR9853TS9_TSOT6-095_0_SOT_23_6_SW2001SOT_23_6
U47SGM2549_SOT-23-6_SGM2549SOT-23-6
U48GSV6127_V0P1_QFN64_8R00X8R00X0R40_GSV6127QFN64_8R00X8R00X0R40
U49RCLAMP0524P_SLP2510P8_RCLAMP0524PATCTSLP2510P8
U50RCLAMP0524P_SLP2510P8_RCLAMP0524PATCTSLP2510P8
U51RCLAMP0524P_SLP2510P8_RCLAMP0524PATCTSLP2510P8
U52DCDC_SY8088_SOT_23_5_BL8028SOT_23_5
U53DCDC_SY8088_SOT_23_5_BL8028SOT_23_5
U3800LPDDR4_1_BGA200_15R00X10R00X0R90_LPDDR4_200PBGA200_15R00X10R00X0R90
W1TMP_0_GH_1_25_6_SMD_LT_A1250-WV-6PINGH_1_25_6_SMD_LT
Y1CRYSTAL_4P_XTAL3_2X2_5_24MHZXTAL3_2X2_5
Y3CRYSTAL_0_CRY2_6R90X1R40X1R30_32.768KHZCRY2_6R90X1R40X1R30
Y507_CRY3225-12M_XTL571300-W79-00_XTAL3_2X2_5_28.6363MHZXTAL3_2X2_5
Y6CRYSTAL_4P_XTAL3_2X2_5_NC/25MHZXTAL3_2X2_5
Y7CRYSTAL_4PIN_CRY_3225_24MHZ/+-20PPMCRY_3225
Y8CRY_SMD3225_CRY_3225_25MHZCRY_3225
原理图发一下 :):):):):) :)谢谢分享 谢谢分享 :victory: 谢谢资料分享! 谢谢分享 :D:D:D:D:D:D ::funk::lol:lol:P;P
