RK_EVB1_RK3576_LP4XD200P132SD6_V12(LPDDR4X) PCB 原理图共享下载
本帖最后由 sisi9000 于 2024-7-12 21:34 编辑PCB 原理图一起打包。回复可见下载
ANT6400SMA_1P4G_ANT5_SMA_ST_EM1_SMA-J-P-H-RA-TH1SMA-J-P-H-RA-TH1ANT5_SMA_ST_EM1
ANT6401SMA_1P4G_ANT5_SMA_ST_EM1_SMA-J-P-H-RA-TH1SMA-J-P-H-RA-TH1ANT5_SMA_ST_EM1
ANT6402ANT_1P2G_ANT_JACK_ANT_JACKANT_JACKANT_JACK
CON460061082-08_2_CNN80M_0R80_61082_61082-0861082-08CNN80M_0R80_61082
CON470061082-08_2_CNN80M_0R80_61082_61082-0861082-08CNN80M_0R80_61082
CON5000LCD_HITACHI_TX05D99VM1AAA_2_CNN30_1R00_FP05SL_V_MIPI/LVDS_PANEL_CON0MIPI/LVDS_Panel_CON0CNN30_1R00_FP05SL_V
CON650061082-061402LF_CNN60M_0R80_61082_61082-061402LF61082-061402LFCNN60M_0R80_61082
CON7700DIGITALAUDIO_HS_MB_30_CNN40_0R80_61082_AUDIO_61082-041402LF_AUDIO61082-041402LF_AudioCNN40_0R80_61082_AUDIO
CON9300CON3_2X3_CNN6M_2R54_H_DIP_CNN6M_2R54_H_DIPCNN6M_2R54_H_DIPCNN6M_2R54_H_DIP
CON9301CON3_2X2_CNN4M_2R54_H_DIP_CNN4M_2R54_H_DIPCNN4M_2R54_H_DIPCNN4M_2R54_H_DIP
CON9304CON4_1X4_CN4M_2R54_V_DIP_CN4M_2R54_V_DIPCN4M_2R54_V_DIPCN4M_2R54_V_DIP
CON9600CON4_1X4_CN4M_2R54_V_DIP_NC/CN4M_2R54_V_DIPNC/CN4M_2R54_V_DIPCN4M_2R54_V_DIP
CON9700POWERMEASUREMENT_CNN60_0R80_B406_POWERMETERAGEPowerMeterageCNN60_0R80_B406
CON9900CON4_0_CN4M_2R54_V_P_DIP_CN4M_2R54_VCN4M_2R54_VCN4M_2R54_V_P_DIP
D2000DIODE_DO_214AB_SS32SS32DO_214AB
D2300DIODEZENER2_ESD0603_PSUR1610DNV07PSUR1610DNV07ESD0603
D2301DIODE_SOD_323_B5819WSB5819WSSOD_323
D2400DIODEDOUBLE_SOT_23_BAT54CBAT54CSOT_23
D5600DIODE_SOD_123_B5819WB5819WSOD_123
D5601DIODE_SOD_323_B5819WSB5819WSSOD_323
D9100DIODE_SOD_523_RB520S-30RB520S-30SOD_523
D9800DIODE_SOD_523_RB520S-30RB520S-30SOD_523
ED2500DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2501DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2502DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2503DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2504DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2505ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034DESD73034DSON10_2R50X1R00X0R50
ED2506DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2507ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034DESD73034DSON10_2R50X1R00X0R50
ED2508DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
ED2509DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
ED2510DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
ED2511DIODEBI_DIR TRIG_ESD0402_ESD5311XESD5311XESD0402
ED2512DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2513DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED2514ESD56161D24_DFN3_2R00X2R00X0R65_ESD56161D24ESD56161D24DFN3_2R00X2R00X0R65
ED4201DIODEBI_DIR TRIG_ESD0402_ESD5471XESD5471XESD0402
ED4202DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED4203DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED4204DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED4205DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED4206DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED4207DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED5600ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034DESD73034DSON10_2R50X1R00X0R50
ED5601ESD_ESD73034D_SON10_2R50X1R00X0R50_ESD73034DESD73034DSON10_2R50X1R00X0R50
ED5602DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED5603DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED5604DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED5605DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED5606DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED6700DIODEBI_DIR TRIG_ESD0402_NC/ESD5341NNC/ESD5341NESD0402
ED9003DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
ED9300PSM712_SOT_23_PSM712PSM712SOT_23
ED9302DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
ED9303DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
ED9600DIODEBI_DIR TRIG_ESD0402_ESD5471XESD5471XESD0402
ED9601DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED9602DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED9800DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED9801DIODEBI_DIR TRIG_ESD0402_ESD5341NESD5341NESD0402
ED9802DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
ED9803DIODEBI_DIR TRIG_ESD0402_ESD5451NESD5451NESD0402
F2000FUSE_F8050_JK-SMD150LJK-SMD150LF8050
F9900FUSE_R1206_JK-NSMD035JK-nSMD035R1206
FB7400BEAD_L0603_120R-100M120R-100ML0603
FB7401BEAD_L0603_120R-100M120R-100ML0603
FB7402BEAD_L0603_120R-100M120R-100ML0603
FB7403BEAD_L0603_120R-100M120R-100ML0603
GND9900GND_GATE_CON2_1X2_5R08_DIP_GND_GATEGND_GATECON2_1X2_5R08_DIP
GND9901GND_GATE_CON2_1X2_5R08_DIP_GND_GATEGND_GATECON2_1X2_5R08_DIP
GND9902GND_GATE_CON2_1X2_5R08_DIP_GND_GATEGND_GATECON2_1X2_5R08_DIP
GND9903GND_GATE_CON2_1X2_5R08_DIP_GND_GATEGND_GATECON2_1X2_5R08_DIP
GND9904GND_GATE_CON2_1X2_5R08_DIP_GND_GATEGND_GATECON2_1X2_5R08_DIP
H9900HOLE_HOLE_C3R20_C6R00_HOLE_3R20HOLE_3R20HOLE_C3R20_C6R00
IR9100IRM_3638_IJ3_IRM_3638_IRM_3638IRM_3638IJ3_IRM_3638
J2000DCJACK_3P_DC3_DC_0007_5P_DC-0007-5PDC-0007-5PDC3_DC_0007_5P
J2300JM_0_OPEN_JMJMOPEN
J2301JM_0_OPEN_JMJMOPEN
J2302JM_0_OPEN_JMJMOPEN
J2303JM_0_OPEN_JMJMOPEN
J2304JM_0_OPEN_JMJMOPEN
J2305JM_0_OPEN_JMJMOPEN
J2306JM_0_OPEN_JMJMOPEN
J2307JM_0_OPEN_JMJMOPEN
J2400CON_BATTERY-20MM_BAT_CR1220_CR1220-3VCR1220-3VBAT_CR1220
J2500USB30_TYPE-CRECEPTACLE_0_TYPEC30_24P_SD-2012670005_USB30_TYPE-C RECEPTACLEUSB30_TYPE-CReceptacleTYPEC30_24P_SD-2012670005
J2501USBA_4_USB30_AF_SMT_THF_USB30_AF_SMT_THFUSB30_AF_SMT_THFUSB30_AF_SMT_THF
J4200TFCARD_SOCKET_TF9_TFP09-2-12B_TFP09-2-12BTFP09-2-12BTF9_TFP09-2-12B
J5600HDMI_A_HDMIA19_HDMI_01A_HDMI_AHDMI_AHDMIA19_HDMI_01A
J6700HR911130C_RJ45_HR911130C_HR911130CHR911130CRJ45_HR911130C
J6800HR911130C_RJ45_HR911130C_HR911130CHR911130CRJ45_HR911130C
J7000AUDIO_JACK_PJ8_B2339J_PJ8_B2339J_AUDIO_JACK_PJ8_B2339JAudio_Jack_PJ8_B2339JPJ8_B2339J
J7400AUDIO_SPK_JACK_2P_CN2M_2R00_V_P_DIP_AUDIO_SPK_JACK_2P_VAudio_SPK_Jack_2P_VCN2M_2R00_V_P_DIP
J7401AUDIO_SPK_JACK_2P_CN2M_2R00_V_P_DIP_AUDIO_SPK_JACK_2P_VAudio_SPK_Jack_2P_VCN2M_2R00_V_P_DIP
J9800USB20_TYPE_C_NEW_TYPEC20_16P_U20401_USB20_TYPE_C_NEWUSB20_TYPE_C_NEWTYPEC20_16P_U20401
J9801CON4_1X4_CN4M_2R54_V_DIP_CN4M_2R54_V_DIPCN4M_2R54_V_DIPCN4M_2R54_V_DIP
J9900RADIATOR_FAN_2_RADIATOR_FAN_65RX65RX13R_RADIATOR_FAN_65X65Radiator_Fan_65x65RADIATOR_FAN_65RX65RX13R
J9901SOCKET_RK3576_EVB_RK3576_65R0X65R0X54R3_S_RK3576_SOCKETRK3576_SocketRK3576_65R0X65R0X54R3_S
J9902RADIATOR_0_RADIATOR_38RX38RX10R_RADIATOR_38X38Radiator_38x38RADIATOR_38RX38RX10R
L2000INDUCTORSOF FERRITE_IND_667028_4.7UH4.7uHIND_667028
L2001INDUCTORSOF FERRITE_IND_404020_2.2UH2.2uHIND_404020
L2300INDUCTORSOF FERRITE_IND_201610_0.47UH0.47uHIND_201610
L2301INDUCTORSOF FERRITE_IND_252012_0.24UH0.24uHIND_252012
L2302INDUCTORSOF FERRITE_IND_201610_0.47UH0.47uHIND_201610
L2303INDUCTORSOF FERRITE_IND_252012_0.24UH0.24uHIND_252012
L2304INDUCTORSOF FERRITE_IND_201610_0.47UH0.47uHIND_201610
L2305INDUCTORSOF FERRITE_IND_252012_0.24UH0.24uHIND_252012
L2306INDUCTORSOF FERRITE_IND_201610_0.47UH0.47uHIND_201610
L2307INDUCTORSOF FERRITE_IND_252012_0.24UH0.24uHIND_252012
L2308INDUCTORSOF FERRITE_IND_201610_0.47UH0.47uHIND_201610
L2309INDUCTORSOF FERRITE_IND_201610_0.47UH0.47uHIND_201610
L2400INDUCTORSOF FERRITE_IND_252010_1.0UH1.0uHIND_252010
L2401INDUCTORSOF FERRITE_IND_252010_1.0UH1.0uHIND_252010
L2500INDUCTORCOM_RP2_0405_NCNCRP2_0405
L2501INDUCTORCOM_RP2_0405_NCNCRP2_0405
L4100INDUCTORSOF FERRITE_IND_252010_1.0UH1.0uHIND_252010
L4101INDUCTORSOF FERRITE_IND_252010_1.0UH1.0uHIND_252010
L6400INDUCTORSOF FERRITE_IND_303015_2.2UH2.2uHIND_303015
L6401INDUCTORSOF FERRITE_IND_303015_2.2UH2.2uHIND_303015
L6700INDUCTORSOF FERRITE_IND_303015_2.2UH2.2uHIND_303015
L6800INDUCTORSOF FERRITE_IND_303015_2.2UH2.2uHIND_303015
L8100INDUCTORSOF FERRITE_IND_404020_2.2UH2.2uHIND_404020
LED9500LED_LED0603_LED_WHITELED_WHITELED0603
LED9501LED_LED0603_LED_YELLOWLED_YELLOWLED0603
LED9502LED_LED0603_LED_GREENLED_GREENLED0603
LED9800LED_LED0603_LED_BLUELED_BLUELED0603
M9900MARK_MARK_MARKMARKMARK
M9901MARK_MARK_MARKMARKMARK
M9902MARK_MARK_MARKMARKMARK
M9903MARK_MARK_MARKMARKMARK
M9904MARK_MARK_MARKMARKMARK
M9905MARK_MARK_MARKMARKMARK
MIC7000MIC_WMM7037AT6_A_MIC4_2R95X3R76X1R10_MIC_WMM7037AT6MIC_WMM7037AT6A_MIC4_2R95X3R76X1R10
Q3800MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23
Q3801MOSFETN_SOT_323_WNM2021-3/TRWNM2021-3/TRSOT_323
Q4100MOSFETP_SOT_23_WPM2015-3/TRWPM2015-3/TRSOT_23
Q4101NPN_SOT_23_S8050S8050SOT_23
Q5000MOSFETP_SOT_23_WPM2341-3/TRWPM2341-3/TRSOT_23
Q5001NPN_SOT_23_S8050S8050SOT_23
Q5002NPN_SOT_23_S8050S8050SOT_23
Q5600MOSFETN_SOT_323_WNM6002-3/TRWNM6002-3/TRSOT_323
Q5601MOSFETN_SOT_323_WNM6002-3/TRWNM6002-3/TRSOT_323
Q5602MOSFETN_SOT_323_WNM6002-3/TRWNM6002-3/TRSOT_323
Q5603MOSFETN_SOT_323_WNM6002-3/TRWNM6002-3/TRSOT_323
Q5604MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q5605MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q5606MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q5607MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q5608MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q6400NPN_SOT_23_S8050S8050SOT_23
Q6401NPN_SOT_23_S8050S8050SOT_23
Q7000MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23
Q7001MOSFETN_SOT_23_WNM2016-3/TRWNM2016-3/TRSOT_23
Q8000MOSFETN_SOT_323_2SK30182SK3018SOT_323
Q8100MOSFETP_SOT_23_WPM3407-3/TRWPM3407-3/TRSOT_23
Q8101NPN_SOT_23_S8050S8050SOT_23
Q9500NPN_SOT_23_S8050S8050SOT_23
Q9900MOSFETN_SOT_23_WNM3003-3/TRWNM3003-3/TRSOT_23
S1700DIAL_SWITCH_1_SW2_2R88X5R40X2R30_DIAL_SWITCH_1Dial_Switch_1SW2_2R88X5R40X2R30
S2000BR-11C-11P6KCD1-11-3P-WSW3_KCD1-11-3P-W
SMTSO4600SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4601SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4602SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4603SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4700SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4701SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4702SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO4703SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO6500SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO6501SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO7700SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SMTSO7701SMTSO_SMTSO_M3_C4R1_C6R0_L5R0_SMTSO3050CTJSMTSO3050CTJSMTSO_M3_C4R1_C6R0_L5R0
SW1800DIAL_SWITCH_4_SW8_5R68X5R40X2R30_DIAL_SWITCH_4Dial_Switch_4SW8_5R68X5R40X2R30
SW1801DIAL_SWITCH_4_SW8_5R68X5R40X2R30_DIAL_SWITCH_4Dial_Switch_4SW8_5R68X5R40X2R30
SW9000KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125STS-1125SSW5_6R20X6R20X2R50
SW9001KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125STS-1125SSW5_6R20X6R20X2R50
SW9002KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125STS-1125SSW5_6R20X6R20X2R50
SW9003KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125STS-1125SSW5_6R20X6R20X2R50
SW9004KEY_4PIN_SW4_6R50X7R00X7R10_TS-1138V1TS-1138V1SW4_6R50X7R00X7R10
SW9005KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125STS-1125SSW5_6R20X6R20X2R50
SW9006KEY_5PIN_SW5_6R20X6R20X2R50_TS-1125STS-1125SSW5_6R20X6R20X2R50
U1000SOC_RK3576_BGA698_16R1X17R2X1R08_RK3576RK3576BGA698_16R1X17R2X1R08
U1300SWITCH_FSUSB30MUX_MSOP10_3R00X3R00X1R10_FSUSB30MUXFSUSB30MUXMSOP10_3R00X3R00X1R10
U1301SWITCH_FSUSB30MUX_MSOP10_3R00X3R00X1R10_FSUSB30MUXFSUSB30MUXMSOP10_3R00X3R00X1R10
U1302SWITCH_FSUSB30MUX_MSOP10_3R00X3R00X1R10_FSUSB30MUXFSUSB30MUXMSOP10_3R00X3R00X1R10
U1700GMA340_QFN18L_2R00X2R80X0R567_T_GMA340GMA340QFN18L_2R00X2R80X0R567_T
U2000TMI3255S_SOT_23_6_TMI3255STMI3255SSOT_23_6
U2001TMI3253SH_SOT_23_6_TMI3253SHTMI3253SHSOT_23_6
U2300PMIC_RK806S-5_QFN68_7R00X7R00X0R80_T_RK806S-5RK806S-5QFN68_7R00X7R00X0R80_T
U2400DCDC_ETA3409_SOT_23_5_TMI3112HTMI3112HSOT_23_5
U2401DCDC_ETA3409_SOT_23_5_TMI3112HTMI3112HSOT_23_5
U2402CW3301_LOADSWITCH_WLCSP4_0R80X0R80X0R50_CW3301CW3301WLCSP4_0R80X0R80X0R50
U2403SWITCH_SY6280_SOT_23_5_SGM2590DSGM2590DSOT_23_5
U2404LDO_PT5108_SOT_23_5_TMI6050-33TMI6050-33SOT_23_5
U2405RTC_HYM8563_TSSOP8_3R10X3R10X1R10_HYM8563TSHYM8563TSTSSOP8_3R10X3R10X1R10
U2500USB_FUSB302B_MLP14_2R50X2R50X0R80_HUSB311HUSB311MLP14_2R50X2R50X0R80
U2501WS3221_CSP6L_1R25X0R77X0R63_WS3221CWS3221CCSP6L_1R25X0R77X0R63
U2502SWITCH_SY6280_SOT_23_5_SGM2590DSGM2590DSOT_23_5
U2503SWITCH_SY6280_SOT_23_5_SGM2590DSGM2590DSOT_23_5
U3800LPDDR4_1_BGA200_15R00X10R00X0R90_LPDDR4_200PLPDDR4_200PBGA200_15R00X10R00X0R90
U4000INAND_EMMC_153_2L_BGA153_13RX11R5X0R9_2L_EMMC_B153_2LEMMC_B153_2LBGA153_13RX11R5X0R9_2L
U4100NANDFLASH_UFS_153P_FBGA153_11R5X13R0X1R00_UFS_B153UFS_B153FBGA153_11R5X13R0X1R00
U4101DCDC_ETA3409_SOT_23_5_TMI3112HTMI3112HSOT_23_5
U4102DCDC_ETA3409_SOT_23_5_TMI3112HTMI3112HSOT_23_5
U4200SWITCH_SY6280_SOT_23_5_SGM2590DSGM2590DSOT_23_5
U4300SPI_FLASH_8PIN_T_0_WSON8_8R00X6R00X0R80_T_NC/SPI_NAND_FLASHNC/SPI_Nand_FlashWSON8_8R00X6R00X0R80_T
U4700UM3212M8_MSOP8_3R00X3R00X1R10_UM3212M8UM3212M8MSOP8_3R00X3R00X1R10
U6400MODULE_AP627XP_MD55_WIFI_AP6276P_AP6275PAP6275PMD55_WIFI_AP6276P
U6700ETHERNET_RTL8211F_QFN40_5R00X5R00X0R90_T_RTL8211F-CGRTL8211F-CGQFN40_5R00X5R00X0R90_T
U6800ETHERNET_RTL8211F_QFN40_5R00X5R00X0R90_T_RTL8211F-CGRTL8211F-CGQFN40_5R00X5R00X0R90_T
U7000AUDIO_ES8388_QFN28_4R00X4R00X0R90_T_ES8388ES8388QFN28_4R00X4R00X0R90_T
U7400AMPLIFIER_TCS7191A_MSOP8_3R10X3R10X1R10_TCS7191A_MHTCS7191A_MHMSOP8_3R10X3R10X1R10
U7401AMPLIFIER_TCS7191A_MSOP8_3R10X3R10X1R10_TCS7191A_MHTCS7191A_MHMSOP8_3R10X3R10X1R10
U7402AUDIO_ES7202_QFN16_3R00X3R00X0R80_T_ES7202ES7202QFN16_3R00X3R00X0R80_T
U8000CG_PI6C557-05B_TSSOP20_6R50X4R40X1R20_NC/RS2CG5705BLENC/RS2CG5705BLETSSOP20_6R50X4R40X1R20
U8001LDO_PT5108_SOT_23_5_TMI6050-33TMI6050-33SOT_23_5
U8100PCIEX4_0_PCIE64_X4_SMT_PCIE-SMT-64PINPCIe-SMT-64PINPCIE64_X4_SMT
U8101TMI3253SH_SOT_23_6_TMI3253SHTMI3253SHSOT_23_6
U9100U/ ITG-1010_0_LGA14_3R00X2R50X0R86_ICM-42607-C_U05-ITG-10100-0000ICM-42607-CLGA14_3R00X2R50X0R86
U9300TJA1051T_0_SOP8_5R00X4R00X1R75_TCAN1044V-Q1TCAN1044V-Q1SOP8_5R00X4R00X1R75
U9800INTERFACE_FT232RL_SSOP28_10R20X5R30X2R00_FT232RLFT232RLSSOP28_10R20X5R30X2R00
Y1100CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHZ24MHzCRY4_3R20X2R50X0R80
Y1300CRYSTAL_4P_CRY4_3R20X2R50X0R80_26MHZ26MHzCRY4_3R20X2R50X0R80
Y2400CRYSTAL_2P_CRY2_3R20X1R50X0R90_32.768KHZ32.768KHzCRY2_3R20X1R50X0R90
Y6400CRYSTAL_4P_CRY4_3R20X2R50X0R80_37.4MHZ37.4MHzCRY4_3R20X2R50X0R80
Y6401CRYSTAL_OSC_CRY4_3R20X2R50X1R20_32.768KHZ32.768KHzCRY4_3R20X2R50X1R20
Y6700CRYSTAL_4P_CRY4_3R20X2R50X0R80_NC/25MHZNC/25MHzCRY4_3R20X2R50X0R80
Y6800CRYSTAL_4P_CRY4_3R20X2R50X0R80_NC/25MHZNC/25MHzCRY4_3R20X2R50X0R80
Y8000CRYSTAL_4P_CRY4_3R20X2R50X0R80_25MHZ25MHzCRY4_3R20X2R50X0R80
:(:(:( :D lf2k2022 发表于 2024-7-14 14:44
学习学习 :Q:o:o:P:Q:Q:L:funk::Q:P:P 好资料,学习学习! 几层版??????????????????????? 好资料,学习学习! 好资料,谢谢分享
