老吴 发表于 2013-9-29 14:18
“土豪金”版iPhone 5S完全拆解
 ifixit小组的成员花了17个小时前往澳洲拿到了第一批土豪金iPhone 5s,并且在当地朋友的办公室里拆了这部手机。他们给这部手机的可修复打了6分。
  我们已经看了AnandTech对于iPhone 5s的专业评测,接下来上场的应该是著名拆解网站ifixit对iPhone 5s的拆解。ifixit小组的成员似乎是花了17个小时前往澳洲拿到了第一批土豪金iPhone 5s,并且在当地朋友的办公室里拆了这部手机。http://www.eechina.com/data/attachment/forum/201309/29/1325144dupupcfkssj44ws.jpg
http://www.eechina.com/data/attachment/forum/201309/29/13251494znlzlq909xxl64.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132514b0uceafcqild1dfl.jpg
http://www.eechina.com/data/attachment/forum/201309/29/1325150y7vql7lyvytql07.jpg
苹果使用的是特制的Pentalobular螺丝,也就是五角星螺丝
http://www.eechina.com/data/attachment/forum/201309/29/132515y0w10ysfwu8x3y63.jpg
似乎这种螺丝很脆弱,拆解之后会遭受破坏
http://www.eechina.com/data/attachment/forum/201309/29/13251568gb978oo76bjjcy.jpg
ifixit提供更换样品,一颗50美刀,暂时没有土豪金,只有银色和黑色(不要骗小编没拆过iPhone好么)
http://www.eechina.com/data/attachment/forum/201309/29/132516ma8xqlsl4sfvlwh1.jpg
组装方式和iPhone 5如出一辙,使用吸盘把屏幕吸下
http://www.eechina.com/data/attachment/forum/201309/29/132516n5wszzu5eluclp1c.jpg
当然还得借助撬棒的帮助
http://www.eechina.com/data/attachment/forum/201309/29/132516049g524ks22g86kg.jpg
Home键包括指纹识别传感器和主板的连接排线,如果你想还原的话,最好别把线扯断
http://www.eechina.com/data/attachment/forum/201309/29/1325165l9u36z1u679ufb4.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132517iyoo88wyu7n5wion.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132517gur6agfnucnb2igz.jpg
http://www.eechina.com/data/attachment/forum/201309/29/13251718uozftjiz1zutnn.jpg
没有了像iPhone 5上面的那种可以帮助拉出电池的卡片,只能撬下,也注意不要捅漏了
http://www.eechina.com/data/attachment/forum/201309/29/132518zwuiw6pmpdxdux1u.jpg
电池同样使用胶水固定
http://www.eechina.com/data/attachment/forum/201309/29/1325187lgte6wz1veutdes.jpg
iPhone 5s的电池,1560mAh/5.92Wh
http://www.eechina.com/data/attachment/forum/201309/29/1325186xd6ocflpglqdgtf.jpg
惠州德赛电子制造
http://www.eechina.com/data/attachment/forum/201309/29/132518ww716cwdjzvwuojj.jpg
另外一部太空灰的电池则由新世电子制造
  相比之下,Android阵营的Galaxy S4有2600mAh/9.88Wh,Moto X有2200mAh/8.4Wh,iPhone 5s用的电池小得多,不过续航时间嘛。http://www.eechina.com/data/attachment/forum/201309/29/132519zozfg1c0excgezxz.jpg
屏幕的连接排线
http://www.eechina.com/data/attachment/forum/201309/29/132519q5yt5cc5qzzt24ya.jpg
一共有3个排线接头需要断开
http://www.eechina.com/data/attachment/forum/201309/29/132519ffjf10sj5i5iq6dd.jpg
Home键和Touch ID指纹识别系统
http://www.eechina.com/data/attachment/forum/201309/29/1325200szf1n9rv1pcsy0p.jpg
可想而知以后坏了一个Home键修复可就不止50块这么简单
http://www.eechina.com/data/attachment/forum/201309/29/132520uyy1id1zk44jyyd1.jpg
Touch ID使用一个CMOS芯片来处理指纹,这种技术来自苹果一年前收购的AuthenTec公司
http://www.eechina.com/data/attachment/forum/201309/29/132520zs9tz759579yftk3.jpg
摄像头模组,背部标识DNL333 41WGRF 4W61W,
http://www.eechina.com/data/attachment/forum/201309/29/132520nn12fwzm2m2k5vx5.jpg
Chipworks分析指出这个DNL标记和iPhone 4s和iPhone 5上的一致,同样是来自索尼的IMX145传感器
http://www.eechina.com/data/attachment/forum/201309/29/132521sb0ad8xcca9u0aa0.jpg
不过iPhone 5s使用的应该是一个新型号
http://www.eechina.com/data/attachment/forum/201309/29/132521xvgfgf90779dr1fq.jpg
拆卸主板
http://www.eechina.com/data/attachment/forum/201309/29/132521rh2jwhfjnn5wx2vq.jpg
iPhone 5s少了那些天线互联线缆的阻碍
http://www.eechina.com/data/attachment/forum/201309/29/132521wyj7ddbz7x7qz77d.jpg
村田制作所的339S0205 Wi-Fi模块基于博通BCM4334
http://www.eechina.com/data/attachment/forum/201309/29/132522qi2qfpkkynp3yfa2.jpg
16GB和64GB的版本PCB丝印层有不同的标记,可能来自不同的代工厂
http://www.eechina.com/data/attachment/forum/201309/29/132522mamwngzwsoavuauz.jpg
拆掉EMI屏蔽罩之后露出主板核心的部分:红色:SK Hynix海力士 H2JTDG8UD3MBR 128 Gb (16 GB) NAND闪存芯片
橙色:Qualcomm高通 PM8018 射频 电源管理IC
黄色:TriQuint TQM6M6224
绿色:苹果 338S1216
蓝色:博通BCM5976触屏控制器
粉色:德州仪器37C64G1
黑色:Skyworks 77810http://www.eechina.com/data/attachment/forum/201309/29/1325227q9zq9htn2hof1ng.jpg
接着还有:红色:Skyworks 77355
橙色:Avago A790720
黄色:Avago A7900
绿色:苹果338S120Lhttp://www.eechina.com/data/attachment/forum/201309/29/1325223p66bu37b7irvbok.jpg
主板的另外一面:红色:苹果A7处理器
橙色:高通MDM9615M LTE 基带
黄色:高通WTR1605L LTE/HSPA+/CDMA2000/TD-SCDMA/EDGE/GPS收发器http://www.eechina.com/data/attachment/forum/201309/29/132523f3p53r9r5uf23niv.jpg
苹果A7是首款64位移动处理器,基于ARMv8指令,整合了1GB LPDDR3 RAM
http://www.eechina.com/data/attachment/forum/201309/29/132523j03ra08a59nera00.jpg
http://www.eechina.com/data/attachment/forum/201309/29/1325251kkvnlkdrrblky4c.jpg
ifixit的拆解当时没提到M7协处理器,M7实际是在A7上方一堆排线接口中央,一颗NXP LPC1800
http://www.eechina.com/data/attachment/forum/201309/29/132525do2d9zdmd9t5ty27.jpg
120万像素的Facetime摄像头
http://www.eechina.com/data/attachment/forum/201309/29/132526oixynjxwp0nzyb5o.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132526j2ku5k7y1ud1ddkj.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132526zs5s25phz932995w.jpg
扬声器
http://www.eechina.com/data/attachment/forum/201309/29/1325271547k35050hf58a0.jpg
Lightning接口和3.5mm音频接口
http://www.eechina.com/data/attachment/forum/201309/29/132527arpppu2sf7a47pca.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132527w95m93mz9y5az1pa.jpg
True Tone闪光灯
http://www.eechina.com/data/attachment/forum/201309/29/132527efhf5blz5hf6mude.jpg
http://www.eechina.com/data/attachment/forum/201309/29/132528mo8jmej1m1kjmm07.jpg
  ifixit对于iPhone 5s的可修复打分是6分(10分满分),显示屏是一体化的,电池也是很容易就可以获得备件。但iPhone 5s的电池失去了方便的拉环,只能靠粘合剂安装,拆解需要暴力撬下。指纹传感器在拆解时可能会由于用力过猛扯断,iPhone 5s仍然使用订制的螺丝,可能会难以打开,另外由于使用了一体式的屏幕,维修成本可能会增加。
hueylee 发表于 2013-9-29 16:27
挺精致的,就是接受不了电池用胶水粘这种做法。
wspytu 发表于 2013-9-30 08:46
嗯,手机主板集成度越来越高啊
bgod1986414 发表于 2014-1-19 09:19
謝謝你的分享,讓我可知道手機的內部構造
5718366 发表于 2014-7-21 16:43
不愧为土豪金
1013649244 发表于 2014-9-24 21:13
苹果的就是不一样
jie514 发表于 2014-10-11 11:35
不错,学习一下
查看完整版本: “土豪金”版iPhone 5S完全拆解
