armclub 发表于 2024-4-22 15:08
XC7A100T-2FGG676I PCB和原理图
NamePCB DecalPart TypeValueCOM1RDB9M_277-ENG_CD_1734023_1HEADER-DB9_RIGHT-MDMR-9PD1LED0805LEDLED 0805 GreenD2LED0805LEDLED 0805 GreenD3LED0805LEDLED 0805 GreenD4DIOMELF559X711N_PJ-SK32DIODESK38D5DIOMELF559X711N_PJ-SK32DIODESK38D6DIOMELF559X711N_PJ-SK32DIODESK38D7DIOMELF559X711N_PJ-SK32DIODESK38D8DIOMELF559X711N_PJ-SK32DIODESK38D9DIOMELF559X711N_PJ-SK32DIODESK38J1SIP6CON_SIP-1_6-00-2.54-MCON_SIP-1*6-00-2.54mmJ2SIP4_5-08CON_SIP-1_4-00-5.08-M(ATX)SIP-1*4-00-5.08-M(ATX)L1L0805INDUCTOR80Ω 100MHz 3AL27L0805INDUCTOR80Ω 100MHz 3AQ1SOT-23BSS138BSS138SW1PUSH_BUTTONSW_PUSHBUTTON-SPST-2/SM_ZHISHI6×6×4.3U1BGA676_100-26X26R2700X2700XC7A100T-2FGG676IXC7A100T-2FGG676IU2SOP56-20-720S29GL01GS10TFI010S29GL01GS10TFI010U3SOT143MAX811TEUS-TMAX811TEUS-TU4SOP16-26-208MAX3221EEAE_2MAX3221EEAEU5SOP8_127-620X500_HS213X300TPS54331DDATPS54331DDAU6SOP8_127-620X500_HS213X300TPS54331DDATPS54331DDAU7SOP8_127-620X500_HS213X300TPS54331DDATPS54331DDAU8SOP8_127-620X500_HS213X300TPS54331DDATPS54331DDAU9SOP8_127-620X500_HS213X300TPS54331DDATPS54331DDAU10SOP8_127-620X500_HS213X300TPS54331DDATPS54331DDAU11SOP20_065-640X660CY2DL1504ZXITCY2DL1504ZXITU12BGA96_080-9X16R900X1400MT41K256M16HA-125_ITEMT41K256M16HA-125 ITEU13BGA96_080-9X16R900X1400MT41K256M16HA-125_ITEMT41K256M16HA-125 ITEU14SON10_050-300X300_HS165X240TPS51200DRCTTPS51200DRCTX1PCI64_200-MOL-87715-6100PCIE_CONNECTOR_X4PCIE-064-02-F-D-THX2SFP-ESFP-003-01MECT-110-01-M-D-RA1MECT-110-01-M-D-RA1X3SFP-ESFP-001-01-CAGESFPC-SLSFPC-SLX4SFP-ESFP-003-01MECT-110-01-M-D-RA1MECT-110-01-M-D-RA1X5SFP-ESFP-001-01-CAGESFPC-SLSFPC-SLX6SFP-ESFP-003-01MECT-110-01-M-D-RA1MECT-110-01-M-D-RA1X7SFP-ESFP-001-01-CAGESFPC-SLSFPC-SLX8SFP-ESFP-003-01MECT-110-01-M-D-RA1MECT-110-01-M-D-RA1X9SFP-ESFP-001-01-CAGESFPC-SLSFPC-SLY1OSCS6_500X700-XO75PXO75L106.25MHzY2OSCS6_500X700-XO75PXO75L200MHZY3X4-0705OSC-D36A-ZPB100MHzY4OSCS6_500X700-XO75PXO75L125MHz
armclub 发表于 2024-4-22 15:10
PCB文件和原理图。回复可见
**** Hidden Message *****
nwq301 发表于 2024-4-22 15:24
lf2k2022 发表于 2024-4-22 15:59
631530490 发表于 2024-4-22 16:00
fcwy03 发表于 2024-4-22 16:12
神话2013 发表于 2024-4-22 16:55
回 armclub 的帖子
armclub:PCB文件和原理图。回复可见
[内容隐藏]
 (2024-04-22 15:10) images/back.gif
谢谢分享
hellotxdpj 发表于 2024-4-22 17:57
janqy123 发表于 2024-4-22 18:06
cat 发表于 2024-4-22 18:23
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: XC7A100T-2FGG676I PCB和原理图
