rjheng2024 发表于 2024-1-12 14:15:04
Allegro 实用快捷键
# F1 is normally reserved by the system for Help so we don't use it
#取消
alias Esc cancel
#查看属性
alias F1 show element
#测量
alias F2 Show Measure
#drc检查
alias F3 status
#镜像
alias F4 mirror
#颜色层图
alias F5 color192
#撤回上一个点
alias F6 oops
#显示和隐藏铺铜。没有边框
alias F7 'settoggle no_etch_shape_display;redraw'
#显示和隐藏铺铜 还有边框
alias F8 'settoggle no_shape_fill;redraw'
#格点设置
alias F9 define grid
#高亮选择
alias F10 hilight pick
#颜色设置
alias F11 Assign Color
#取消颜色,选择
alias F12 dehilighalias SF2 property edit
alias SF3 slide
alias SF4 show measure
alias SF5 copy
alias SF6 move
alias SF7 dehilight all
alias SF8 hilight pick
alias SF9 vertex
alias SF10 save_as temp
alias SF11 zoom previous
alias SF12 zoom world
#alias CF2 next
#alias CF5 color192
alias CF6 layer priority
alias CSF5 status
#新建
alias ~N new
alias ~n new
#打开
alias ~O open
alias ~o open
#保存
alias ~S save
alias ~s save
#删除
alias ~D delete
alias Del delete
alias ~d delete
#撤回
alias ~Z undo
alias ~z undo
# 隐藏飞线
funckeyzu unrats all
# 显示飞线
funckeyzy rats all
#更改原点
funckey spd chg origin
#放大
alias Pgdown zoom out
#缩小
alias Pgup zoom in
#打孔换层
funckey = subclass -+
funckey - subclass --
#添加铜皮
funckey ry shape add
#方形铜箔
funckey re shape add rect
#修改铜皮边界
funckey rt shape edit boundary
# 铜皮选中
funckey rr shape select
# 关闭所有颜色显示
#alias zo color -globvis off
#结束
funckey 1 done
#移动
funckey 2 move
#拷贝
funckey 3 copy
#旋转90度
funckey 4 angle 90
#改宽度
funckey 5 change
#居中
funckey 6 Spread Between Voids
#对齐
funckey 7 align components
#交换元件
funckey 8 swap components
#暗色显示
funckey 9 shadow toggle
#调整线
funckey e slide
#走线
funckey w add connect
#蛇形走线
funckey q delay tune
#全图
funckey b zoom fit
#光标
funckey t 'settoggle pcb_cursor infinite cross;redraw'
#改变布线方向
funckey ' ' Toggle
# OTHER ALIASES
alias edps padedit
alias rps "replace padstack"
alias unplrp report unplaced
#坐标
alias x pick
alias y pick l
alias ix ipick
alias iy ipick 0
alias reopen 'open -q $module'
alias revert 'open -q $module'
alias zc zoom center
# autoroam
alias sar set pcb_autoroam
alias uar unset pcb_autoroam
alias bubset 'settoggle shove_mode Off "Hug preferred" "Shove preferred"; options bubble_space $shove_mode'
alias ~B bubset
alias smoothset 'settoggle smooth_mode Off Minimal Full; options smooth_level $smooth_mode'
alias ~C smoothset
ljd1994 发表于 2024-1-12 16:33:14
海上生明月 发表于 2024-1-13 21:04:43
海上生明月 发表于 2024-1-14 11:06:43
linhaizeng 发表于 2024-1-15 01:37:01
为所欲为 发表于 2024-1-15 10:12:15
kingllii 发表于 2024-1-16 08:25:31
回 ljd1994 的帖子
ljd1994:    (2024-01-12 16:33) images/back.gif
海上生明月 发表于 2024-1-18 18:35:58
海上生明月 发表于 2024-1-20 09:48:16
wddz 发表于 2024-1-24 08:02:54
Allegro 实用快捷键
查看完整版本: Allegro 实用快捷键
