QCN9074 and QCA9892 chips-Detailed explanation of the different wireless stan
Detailed explanation of the different wireless standards of QCN9074 and QCA9892 chips
QCN9074 and QCA9892 are both wireless communication chips produced by Qualcomm and are used in different types of equipment and application scenarios. Here are the main differences between each of them:
Application areas:
QCN9074 is mainly used in IoT (Internet of Things) devices and applications, including smart homes, smart cities, smart industries, etc. It is designed as a low-power chip suitable for connecting a large number of low-power devices.
QCA9892 is mainly used in Wi-Fi routers and network equipment. It supports higher network speeds and greater bandwidth for devices that require high-performance Wi-Fi connections.
Wireless standards:
QCN9074 supports Wi-Fi standards (such as 802.11b/g/n) and low-power Bluetooth (Bluetooth Low Energy, BLE) connections.
QCA9892 supports more Wi-Fi standards, including 802.11a/b/g/n/ac, and higher-speed Wi-Fi connections.
Performance and bandwidth:
The QCN9074 is generally optimized for low power consumption and connection density, so it has lower power consumption but relatively low bandwidth.
Wi-Fi bands: Typically supports 2.4 GHz and 5 GHz bands, including 802.11b/g/n and 802.11a/n/ac.
Bluetooth band: Supports Bluetooth Low Energy (BLE) at 2.4 GHz.
The QCA9892 offers higher bandwidth and performance for applications requiring faster data transfer speeds.
use:
QCN9074 can be used in various IoT devices, such as sensors, smart home devices, industrial automation, etc., to provide long-term low-power connectivity.
QCA9892 is mainly used in Wi-Fi routers, wireless access points and other devices that require high-speed Wi-Fi connections.
Wi-Fi Bands: Typically supports 2.4 GHz and 5 GHz bands, including 802.11a/b/g/n/ac.
Additional bands, such as the 5 GHz DFS (Dynamic Band Selection) band, can also be supported depending on the specific design and configuration to provide additional Wi-Fi channel options.
Please note that the specific supported frequency bands may vary between different products and configurations. When selecting these chips and designing their products, manufacturers typically configure them based on market needs and regulatory requirements. If specific band support is required, you should check the documentation or contact the chip vendor to ensure the chip you select meets your needs.
Wallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.Hardware technology advantages:We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.Clients: TIP,Facebook, Openwrt, etcEmail:sales@wallystech.comWEB:https://www.wallystech.com/ 谢谢分享! 谢谢分享!
