老吴 发表于 2023-5-16 20:17
全志V853 allwinner V853 AI开发板PCB 原理图 程序等所有资料
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT1T_POINT_R_0_WIFI-ANT-SD73412-01ANTWIFI-ANT-SD73412-011H1_3ABAT1BAT_6_BAT-XH414HG-C4_8H1_85A_XHXH414HG-IV01EBAT-XH414HG-C4_8H1_85ABATT1FPC10-PT05A_1_CON3-PT2_3PIN3PINCON3-PT2CN1FPC10-PT05A_2_CON4-PT1_25-3_2X64pinCON4-PT1_25-3_2X6_85H4_8A-UPCN2FPC10-PT05A_2_CON4-PT1_25-3_2X64pinCON4-PT1_25-3_2X6_85H4_8A-UPCN3FPC10-PT05A_24_CON2-PT1_25-3_2X2PINCON2-PT1_25-3_2X4_35H4_8B-UPCN4FPC10-PT05A_24_CON2-PT1_25-3_2X2PINCON2-PT1_25-3_2X4_35H4_8B-UPCON1FPC23_0_CON25-PT0_6-3_6X9H1B_LCLCD2CON25-PT0_6-3_6X9H1BCON2LCD-TD043MGEB1_1_CON40_PT1-2X25CON40CON40_PT1-2X25_6H3ACON3FPC10-PT05A_21_FPC6-PT05-H2_0B_FPC06-PT0.5FPC6-PT05-H2_0BCON4TD030673_7_CON40_PT1-2X25_6H3A_OV4689CON40_PT1-2X25_6H3AD1DIODE_SCHOTTKY_0_SOD123H14A_NC/NC/IN5819SOD123H14AD2D_0_SOD-523H0_7A_1N58191N5819SOD-523H0_7AD3DIODE_SOD123H14A_1N58191N5819SOD123H14AD5D_0_SOD-523H0_7A_1N58191N5819SOD-523H0_7AD6DIODESCHOTTKY_D0402_RB521C30_RRB521C30D0402D7D_0_SOD-523H0_7A_1N58191N5819SOD-523H0_7AD8DIODESCHOTTKY_0_D0402_RB521C30RB521C30D0402D9DIODESCHOTTKY_D0402_RB521C30_RRB521C30D0402D10DIODE_SCHOTTKY_0_SOD123H14A_IN5IN5819SOD123H14ADL1DIO-SS16F_0_SOD123H14A_1N58191N5819SOD123H14ADP1LED-0603-G_LED0603_LED-0603-RLED-0603-RLED0603DP2LED-0805_LED0603_BLUEBLUELED0603DP3LED-0603-G_LED0603_LED-0603-GLED-0603-GLED0603EC1CAPACITOR_POL_SCAP2-PT3_5-8X25HNC/5F/2.7VSCAP2-PT3_5-8X25H8AEC2CAPACITOR_POL_SCAP2-PT3_5-8X25HNC/5F/2.7VSCAP2-PT3_5-8X25H8AFB1INDUCTOR_0_L0603_NC/600R-100MNC/600R-100ML0603FB6INDUCTOR_0_L0603_0R0RL0603FB10INDUCTOR_L0603_600R/100M600R/100ML0603HOLE1T_POINT_R_PAD5D3_3_B5B5PAD5D3_3HOLE2T_POINT_R_PAD5D3_3_B5B5PAD5D3_3HOLE3T_POINT_R_PAD5D3_3_B5B5PAD5D3_3HOLE4T_POINT_R_PAD5D3_3_B5B5PAD5D3_3HP1PHONOJACK_5_PJ_242-5_1X12H3_2A_HXQKPJ-242APJ_242-5_1X12H3_2AHP2PHONOJACK_3_PJ-320C-6_1X14H5A_HHXQKPJ-242APJ-320C-6_1X14H5AJ1FPC10-PT05A_1_H2X2-PT2_54H2A_4P4PINH2X2-PT2_54H2AJ2DC-33_0_DC-HXQKDC-051H10_8A_HXQHXQKDC-051DC-HXQKDC-051H10_8AJ32X16P_H16X2-PT2_2X16P2x16pH16X2-PT2J7FPC10-PT05A_1_H2X2-PT2_54H2A_4P4PINH2X2-PT2_54H2AJ8FPC10-PT05A_0_CON2X7-PT2-5_5X2114PINCON2X7-PT2-5_5X21_45H5_6AJ9FPC10-PT05A_15_H2X5-PT2_54H2A_110PINH2X5-PT2_54H2AK1SW_PUSH_8_SW4-HXQKTS-045-4_5X4_VOL+SW4-HXQKTS-045-4_5X4_5H3_8AK2SW_PUSH_8_SW4-HXQKTS-045-4_5X_1VOL-SW4-HXQKTS-045-4_5X4_5H3_8AK3SW_PUSH_8_SW4-HXQKTS-045-4_5X_2MENUSW4-HXQKTS-045-4_5X4_5H3_8AK4SW_PUSH_8_SW4-HXQKTS-045-4_5X_3ENTERSW4-HXQKTS-045-4_5X4_5H3_8AK5SW_PUSH_8_SW4-HXQKTS-045-4_5X_4HOMESW4-HXQKTS-045-4_5X4_5H3_8AK6SW_PUSH_8_SW4-HXQKTS-045-4_5X_5UBOOTSW4-HXQKTS-045-4_5X4_5H3_8AK7SW_PUSH_8_SW4-HXQKTS-045-4_5X_6PWRONSW4-HXQKTS-045-4_5X4_5H3_8AK8SW_PUSH_8_SW4-HXQKTS-045-4_5X_7RESETSW4-HXQKTS-045-4_5X4_5H3_8AL1INDUCTORX_0_L0805X2_ICMF212P900ICMF212P900MFRL0805X2L2INDUCTOR_0_L0805_0R0RL0805L3INDUCTOR_1_L3518_4.7UH@1.1ADCR4.7uH@1.1ADCR<0.1RL3518L4INDUCTOR_L3X3H1_7A_NC/4.7UH@0.7NC/4.7uH@0.7ADCR<0.1RL3X3H1_7ALCD_ID1T_POINT_R_TP40_SMD_NCNCTP40_SMDLL1L-L2520_L4018_4.7UH-DCR<0.1R-1.4.7uH-DCR<0.1R-1.7AL4018LP1L-L3225_L3X3H1_7A_1UH-2A1uH-2AL3X3H1_7ALP2L-L3225_L3X3H1_7A_1UH-2A1uH-2AL3X3H1_7ALP3L-L3225_L3X3H1_7A_NC-1UH-2ANC-1uH-2AL3X3H1_7ALP4L-L3225_L3X3H1_7A_1UH-2A1uH-2AL3X3H1_7ALP5L-L3225_L3X3H1_7A_1UH-2A1uH-2AL3X3H1_7ALS1L-L8080_L2D6X6H2A_6.8UH-3A-DCR<6.8uH-3A-DCR<0.031RL2D6X6H2AMIC1MICPHONE_1_MIC-EAO-4013-MBAH1_4LSY4013S423-GPMIC-EAO-4013-MBAH1_4AMIC5MICPHONE_1_MIC-EAO-4013-MBAH1_4LSY4013S423-GPMIC-EAO-4013-MBAH1_4AQ1NPN_SOT-23_MMBT3904MMBT3904SOT-23Q2PMOS_SOT-23_WPM2087WPM2087SOT-23Q3NMOS_SOT-23_NC/WNM6001NC/WNM6001SOT-23Q4NMOS_SOT-23_NC/WNM6001NC/WNM6001SOT-23Q5NMOS_SOT-23_NC/WNM6001NC/WNM6001SOT-23QC1PMOS-STS2301_SOT-23_NC-STS2301NC-STS2301SOT-23TF1SDMMCSLOT_0_TF_CARDH1_7A_MICROMICROSD/TF_SLOTTF_CARDH1_7AU1MCP-BGA169_5_BGA169-PT0_5-12X16EMMCBGA169-PT0_5-12X16H1AU2DS8008_0_SOT23-5_WL2801E28-5/TRWL2801E28-5/TRSOT23-5U3RT9266PE_0_SOT23_5H14A_LPW5210LPW5210SOT23_5H14AU4MMA7660_1_SOP10-PT05-MMA7660FC-DA380BSOP10-PT05-MMA7660FC-H1AU5MMA7660_3_QFN12-BMA250E-0_5-2X2NC/SC7A20QFN12-BMA250E-0_5-2X2H1AU8IP101GR_0_QFN33-4X4PT0_4H1A_IP1IP101GRQFN33-4X4PT0_4H1AU9SY8088_0_SOT23-5_LP3220SAB5FLP3220SAB5FSOT23-5U10DS8008_0_SOT23-5_NC/WL2801E28-5NC/WL2801E28-5/TRSOT23-5U11LY8006_0_MSOP-8_CS8302CS8302MSOP-8UD1DDR3-FBGA96_FBGA96C80P10X13_DDRDDR3-FBGA96FBGA96C80P10X13UL1SY7200A_SOT23-6_STI9287CSTI9287CSOT23-6UM2SPI-NOR-SOP8_SOP8-PT1_27-4_45X5NC/MX25L25645GSOP8-PT1_27-4_45X5H1_75AUM3SPI-NOR-SOP16_SOIC16-PT1_27-10_NC/S25FL128SSOIC16-PT1_27-10_3X10_3H2_65UP1AXP2101_0_QFN40-PT0_4-5X5H0_8A_AXP2101QFN40-PT0_4-5X5H0_8AUS1SY8105_SOT23-6_SY8105SY8105SOT23-6USB1USB_MINI_SOCKET_1_USB-C-8_65X8_HXQK-TYPE-C-3.1USB-C-8_65X8_94H3_1AUU1V853_0621_BGA318-V853-PT0_5-12XV853BGA318-V853-PT0_5-12X12H1_2AUW1AP6XXX_1_QFN44-AP6476-12X12H1_6XR829QFN44-AP6476-12X12H1_6AX1CRY-32.768KHZ-3215-SMD_CRYSTAL-32.768K-12.5pFCRYSTAL-2P-3215-H0_85AY1CRY-24MHZ-3225-SMD_CRYSTAL-4P-324M-16pF-10ppmCRYSTAL-4P-3225-H1AYW1CRY-37.4MHZ-3225-SMD_CRYSTAL-4PNC/40M-15pF-10PPMCRYSTAL-4P-3225-H1A
老吴 发表于 2023-5-16 20:21
所有资料都在下面了
317 发表于 2023-5-17 00:00
谢谢分享!
kanxue_nmg 发表于 2023-5-17 05:10
·风来了 发表于 2023-5-17 08:09
ilpuyi 发表于 2023-5-17 08:19
jackychen456 发表于 2023-5-17 08:23
回 老吴 的帖子
老吴:所有资料都在下面了
 (2023-05-16 20:21) images/back.gif
zxy20099 发表于 2023-5-17 08:24
chinachen 发表于 2023-5-17 08:25
lf2k2022 发表于 2023-5-17 08:31
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 全志V853 allwinner V853 AI开发板PCB 原理图 程序等所有资料
