armclub 发表于 2022-9-26 10:36
英特尔雷电扩展坞 PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMECON1USBCRECEPTACLE TOP_LINTES_8G_AUSB0494-P003A_USBC RECEPTACLEUSBCReceptacleAUSB0494-P003ACON2USB3.0_CON_13PIN_USB3_1-TYPEA-P13-WURTH_USB3.0_CON_13PINUSB3.0_CON_13PINUSB3_1-TYPEA-P13-WURTHCON3DC-JACK-42V-10A_JPD113D-LBA21-7H_DC-JACK-42V-10ADC-Jack-42V-10AJPD113D-LBA21-7HCON4DP_SOURCE_DISPPORT_DISPLAYPORT SOURCEDisplayPort SourceDISPPORTCON5DP_SOURCE_DISPPORT_DISPLAYPORT SOURCEDisplayPort SourceDISPPORTCON6USBCRECEPTACLE TOP_LINTES_8G_AUSB0494-P003A_USBC RECEPTACLEUSBCReceptacleAUSB0494-P003AD1LED_LED_0603_YELLOWYELLOWLED_0603D2LED_LED_0603_GREENGREENLED_0603D3LED_LED_0603_GREENGREENLED_0603D4LED_LED_0603_YELLOWYELLOWLED_0603D5LED_LED_0603_GREENGREENLED_0603D6ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD7ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD8ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD9ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD10LED_LED_0603_GREENGREENLED_0603D11LED_LED_0603_GREENGREENLED_0603D12LED_LED_0603_GREENGREENLED_0603D13LED_LED_0603_GREENGREENLED_0603D14LED_LED_0603_GREENGREENLED_0603D15DIODESCHOTTKY_SOD-323_NSR0240HNSR0240HSOD-323D16LED_LED_0603_GREENGREENLED_0603D17ESD_DIODE_SOD962-2_PESD5V0H1BSFPESD5V0H1BSFSOD962-2D38ESDDIODE_SOT-23_GSOT04CGSOT04CSOT-23D39ESD_DIODE_SOD962-2_PESD5V0H1BSFPESD5V0H1BSFSOD962-2D40ESDDIODE_SOT-23_GSOT04CGSOT04CSOT-23D41ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD42ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD43ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMD44ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB1DIODESCHOTTKY_DSN2_NSR20F30NXT5GNSR20F30NXT5GDSN2DB2ESDDIODE_SOT-23_GSOT05CGSOT05CSOT-23DB3ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB4ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB5ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB6ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB7ESD_DIODE_SOD962-2_PESD5V0H1BSFPESD5V0H1BSFSOD962-2DB8ESD_DIODE_SOD962-2_PESD5V0H1BSFPESD5V0H1BSFSOD962-2DB9ESD_DIODE_SOD962-2_PESD5V0H1BSFPESD5V0H1BSFSOD962-2DB10ESD_DIODE_SOD962-2_PESD5V0H1BSFPESD5V0H1BSFSOD962-2DB11HIGHCURRENT DIODE SCHOTTKY_TO-277A_V15PL50V15PL50TO-277ADB12ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB13ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB14ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB15ESD_DIODE_PNNP_DSN2_0P6X0P3X0P2MM_ESDL2011ESDL2011DSN2_0P6X0P3X0P2MMDB16DIODESCHOTTKY_DSN2_NSR20F30NXT5GNSR20F30NXT5GDSN2F1FIDUCIAL_FID60C120PM60_BOARDFIDUCIALBoardFiducialFID60C120PM60J2HEADER4X2 SMT_HEADER4X2_100_SMT_HEADER 4X2 SMTHEADER4X2 SMTHEADER4X2_100_SMTL1FERRITE_0402_330OHM,0.15OHM DCR, 1.2A IDC330Ohm,0.15Ohm DCR, 1.2A Idc402L2INDUCTOR_2726_2.2UH,17MOHM DCR, 12.0A IDC2.2uH,17mOhm DCR, 12.0A Idc2726L3FERRITE_0603_220OHM,0.040OHM DCR, 2.5A IDC220Ohm,0.040Ohm DCR, 2.5A Idc603L4FERRITE_0603_220OHM,0.040OHM DCR, 2.5A IDC220Ohm,0.040Ohm DCR, 2.5A Idc603L5INDUCTOR_2019_0.68UH,19MOHM DCR, 9.0A IDC0.68uH,19mOhm DCR, 9.0A Idc2019L6INDUCTOR_WURTH_IND_8X8X8MM_4.7UH,8.65MOHM DCR, 9.5A IDC4.7uH,8.65mOhm DCR, 9.5A IdcWURTH_IND_8X8X8MML7INDUCTOR_1210_4.7UH,157MOHM DCR, 2.3A IDC4.7uH,157mOhm DCR, 2.3A Idc1210L8FERRITE_0402_330OHM,0.15OHM DCR, 1.2A IDC330Ohm,0.15Ohm DCR, 1.2A Idc402L9FERRITE_0402_330OHM,0.15OHM DCR, 1.2A IDC330Ohm,0.15Ohm DCR, 1.2A Idc402L10FERRITE_0402_330OHM,0.15OHM DCR, 1.2A IDC330Ohm,0.15Ohm DCR, 1.2A Idc402L11INDUCTOR_2726_2.2UH,17MOHM DCR, 12.0A IDC2.2uH,17mOhm DCR, 12.0A Idc2726L12FERRITE_0402_330OHM,0.15OHM DCR, 1.2A IDC330Ohm,0.15Ohm DCR, 1.2A Idc402L13COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L14COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L15COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L16COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L17COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L18COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L19COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L20COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605L21FERRITE_0603_220OHM,0.040OHM DCR, 2.5A IDC220Ohm,0.040Ohm DCR, 2.5A Idc603L22FERRITE_0603_220OHM,0.040OHM DCR, 2.5A IDC220Ohm,0.040Ohm DCR, 2.5A Idc603LB1COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605LB2COMMON_CHOKE_VX_CHOKE_4P_0605_COMMON_CHOKE,100OHMCommon_Choke,100OhmVX_CHOKE_4P_0605Q1PFET_SOIC8_150_SOIC8_150MIL_FDS6679AZFDS6679AZSOIC8_150MILQ2NFET_3PINS_SOT883_1P0X0P6X0P5MM_PMZ550UNEPMZ550UNESOT883_1P0X0P6X0P5MMQ3NFET_3PINS_SOT883_1P0X0P6X0P5MM_PMZ550UNEPMZ550UNESOT883_1P0X0P6X0P5MMQ4NFET_3PINS_SOT883_1P0X0P6X0P5MM_PMZ550UNEPMZ550UNESOT883_1P0X0P6X0P5MMQ5NFET_8PINS_8-WDFN_3_3X3_3_NTTFS4C06NNTTFS4C06N8-WDFN_3_3X3_3Q6NFET_8PINS_8-WDFN_3_3X3_3_NTTFS4C06NNTTFS4C06N8-WDFN_3_3X3_3Q7NFET_8PINS_SON8_3P3X3P3X0P65MM_FDMC7678FDMC7678SON8_3P3X3P3X0P65MMQ8NFET_3PINS_SOT883_1P0X0P6X0P5MM_PMZ550UNEPMZ550UNESOT883_1P0X0P6X0P5MMU1INA181_SOT23-6_INA181A2INA181A2SOT23-6U2TUSB212_X2QFN12_1P6X1P6MM_TUSB212TUSB212X2QFN12_1P6X1P6MMU3SPI_8P_208MIL_SMT_SOCKET_AP-ACA-SPI-004-K01_170718_SPI_8P_208MIL_SMT_SOCKETSPI_8P_208mil_SMT_SOCKETAP-ACA-SPI-004-K01_170718U4SPI_SOIC8_SOIC8_150MIL_W25Q16JVW25Q16JVSOIC8_150MILU5MP2229_QFN14_3X3MM_MP2229MP2229QFN14_3X3MMU6ECLAMP8052P_SGP1917N5_ECLAMP8052PECLAMP8052PSGP1917N5U7MP4247_MP4247_QFN20_3X5MM_MP4247MP4247MP4247_QFN20_3X5MMU8TPS2546_WQFN16-050-0303LH_TPS2546TPS2546WQFN16-050-0303LHU9MP2182_SOT583_MP2182MP2182SOT583U10OR_SOT23_SOT23-5_NC7S32NC7S32SOT23-5U11SPI_SOIC8_SOIC8_150MIL_W25Q16JVW25Q16JVSOIC8_150MILU12GOSHENRIDGE_BGA337_10P7X10P7_046MM_HOOVER_RIDGE_B0Hoover_Ridge_B0BGA337_10P7X10P7_046MMU13MP2229_QFN14_3X3MM_MP2229MP2229QFN14_3X3MMU14INA181_SOT23-6_INA181A2INA181A2SOT23-6U15MP5016H_QFN10_1P5X2MM_MP5016HMP5016HQFN10_1P5X2MMU16TPS2553_SOT-23_DBV_TPS2553DBVTPS2553DBVSOT-23_DBVU17TPS2553_SOT-23_DBV_TPS2553DBVTPS2553DBVSOT-23_DBVUB1ECLAMP8052P_SGP1917N5_ECLAMP8052PECLAMP8052PSGP1917N5UB274HC541_TSSOP20_6P5X4P4X1P2MM_74HC541PW74HC541PWTSSOP20_6P5X4P4X1P2MMUB3CCG5_BGA-96_CCG5_6X6MM_CCG5_CCG5CCG5BGA-96_CCG5_6X6MMUB4FL5801-1Q2_QFN48_6X6_0P75MM_FL5801-2Q2FL5801-2Q2QFN48_6X6_0P75MMUB5ECLAMP8052P_SGP1917N5_ECLAMP8052PECLAMP8052PSGP1917N5Y1CRYSTAL_4_PADS_XTAL_2_0X1_6_4PIN_25MHZ,30PPM, 20PF25MHz,30ppm, 20pFXTAL_2_0X1_6_4PINYB1CRYSTAL_4_PADS_XTAL_2_0X1_6_4PIN_25MHZ,30PPM, 20PF25MHz,30ppm, 20pFXTAL_2_0X1_6_4PIN
armclub 发表于 2022-9-26 10:39
PCB文件。回复可见下载
**** Hidden Message *****
17637875026 发表于 2022-9-26 15:01
感谢分享~我争取早日到2级,好下载这个文件
cctv1 发表于 2022-9-26 15:09
datou1 发表于 2022-9-26 15:56
bidezhi7777 发表于 2022-9-26 15:57
cat 发表于 2022-9-26 16:14
麻球 发表于 2022-9-26 16:15
麻球 发表于 2022-9-26 16:16
986720 发表于 2022-9-26 16:39
页: [1] 2 3 4 5 6 7 8 9 10
查看完整版本: 英特尔雷电扩展坞 PCB文件共享
