瑞芯微 RK3566 平板电脑PCB和原理图共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEANT6100ANT_1P1G_WIFIANTA_ANT4411DRANT4411DRWIFIANTAANT6101ANT_0_MM4829-2702B_ANT_JACKANT_JACKMM4829-2702BBT2100BATT3_BAT3_2R54_BAT3_2R54BAT3_2R54BAT3_2R54CON2405CON/ 10 / AXE510127_11_TDWC06PNC/6pin_0.5TDWC06P-05CON5300CON/ 10 / AXE510127_3_TDWC06P-DNP/6pin_0.5TDWC06P-05CON7001CON/ 10 / AXE510127_2_TDWC06P-6pin_0.5TDWC06P-05-LCON9000CON/ 10 / AXE510127_3_STK3171-DNP/STK3311-ASTK3171-018CON9001CON/ 10 / AXE510127_4_TDWC06P-6pin_0.5TDWC06P-05CON9101CON/ 10 / AXE510127_12_TDWC010DNP/6pin_0.5TDWC010P-05-LCON9200CON/ 10 / AXE510127_0_TDWC06P-6pin_0.5TDWC06P-05D2500DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2504DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2513DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2514DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D2515DIODEBI_DIR TRIG_E0603_PSUR161PSUR1610DNV07/RSD8535MA/BTRD06B800AE0603D4200DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D4201DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D4202DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D4203DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D4204DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D4205DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D4206DIODEBI_DIR TRIG_ESD0402_ESD53ESD5341NESD0402D5000DIODE_SOD_323_B5819WSB5819WSSOD_323D5001DIODE_SOD_323_B5819WSB5819WSSOD_323D5002DIODE_SOD_123_B5819WB5819WSOD_123D5200DIODE_SOD_123_B5819WB5819WSOD_123D5201DIODEZENER1_SOD_123_BZT52B6V8BZT52B6V8SOD_123D5202DIODEDOUBLE F_SOT_23_BAT54SBAT54SSOT_23D5203DIODEZENER1_SOD_123_BZT52B18BZT52B18SOD_123D5204DIODEDOUBLE F_SOT_23_BAT54SBAT54SSOT_23D5205DIODE_SOD_123_B5819WB5819WSOD_123ED9108DIODEBI_DIR TRIG_E0402N_ST0561ST0561D4E0402NFB2100BEAD_L0603_120R-100MHZ120R-100MHzL0603FB7001BEAD_L0603_180R-100M180R-100ML0603FB7002BEAD_L0603_180R-100M180R-100ML0603J2501USB31_TYPE_C_1_USB16-3190016-CFUSB_TYPEC_115H0USB16-3190016-CF059-RAJ4200TFCARD_SOCKET_TF9_TFP09-2-12B_TTFP09-2-12BTF9_TFP09-2-12BJ4700FH26-25S-0_0.3SHW-05_CON39-06-1FH26-25S-0.3SHW(05)CON39-06-1329-105J4701FH26-25S-0_1.3SHW-05_FLASH-LED_SPEAK1FLASH-LEDJ5000HDMI_C_HDMI-MINI-19PIN-COR_HDMIHDMI_CHDMI-MINI-19PIN-CORJ5200CLAP070LF02CW_1_CON30PIN-0R5MM_30PIN-DOWNCON30PIN-0R5MMJ530033PIN_1_CON51_ZF0R6A_CON0.6/51PCON0.6/51PCON51_ZF0R6AJ5301BL509-06G31-TAH1_1_CON30-0R5-H1CON0.5/30PCON30-0R5-H1R2AJ7001TOUCH-4PIN_7.25MM_CON2_0R8_2PIN2PIN_0.5mmCON2_0R8J7002TOUCH-4PIN_5.25MM_CON2_0R8_2PIN2pin_0.5CON2_0R8J7003TOUCH-4PIN_5.25MM_CON2_0R8_2PIN2pin_0.5CON2_0R8JP7001LS_JAF00-05382-0304PJ301-6PJ18-05AB03-XXL1700INDUCTORCOM_RP2_0405_NC/MCZ121NC/MCZ1210DH900L2TA0GRP2_0405L2100INDUCTORSOF FERRITE_IND_252010470nHIND_252010L2101INDUCTORSOF FERRITE_IND_252010470nHIND_252010L2102INDUCTORSOF FERRITE_IND_252010470nHIND_252010L2103INDUCTORSOF FERRITE_IND_252010470nHIND_252010L2104INDUCTORSOF FERRITE_IND_252010470nHIND_252010L2200INDUCTORSOF FERRITE_IND_2520120.24uHIND_252012L2500INDUCTORCOM_RP2_0405_DNPDNPRP2_0405L2502INDUCTORCOM_RP2_0405_DNPDNPRP2_0405L4700BEAD_L0603_180R-100M180R-100ML0603L5200INDUCTORSOF FERRITE_IND_40403010uHIND_404030L5201INDUCTORSOF FERRITE_IND_3030152.2uHIND_303015L6101INDUCTOR_L0402_DNPDNPL0402L6102INDUCTOR_L0402_DNPDNPL0402L6103INDUCTORSOF FERRITE_IND_3030124.7uHIND_303012L7002BEAD_L0603_180R-100M180R-100ML0603L7003INDUCTOR_L0402_600R-100M600R-100ML0402L7004INDUCTOR_L0402_600R-100M600R-100ML0402M9900MARK_MARK_MARKMARKMARKQ2204MOSFETP_SOT_23_DNP/WPM2341-3/TDNP/WPM2341-3/TRSOT_23Q4203MOSFETP_SOT_23_WPM3407-3/TRWPM3407-3/TRSOT_23Q4700MOSFETP_SOT23_TCS1401-CTCS1401-CSOT23Q5000MOSFETN_SOT_323_2SK30182SK3018SOT_323Q5001MOSFETN_SOT_323_2SK30182SK3018SOT_323Q5002MOSFETN_SOT_323_2SK30182SK3018SOT_323Q5200MOSFETP_SOT_23_WPM3407-3/TRWPM3407-3/TRSOT_23Q5201NPN_SOT_23_S8050S8050SOT_23Q5202NPN_SOT_23_S8050S8050SOT_23Q6102MOSFETP_SOT23_DNP/WPM2026DNP/WPM2026SOT23SHIELD10CON5_0_YZT24_CON5CON5YZT24TP1301TP_TP_0R70_GNDGNDTP_0R70TP1302TP_TP_0R70_EMMC_D0/FLASH_D0eMMC_D0/FLASH_D0TP_0R70TVS2501DIODE_TVS_BIDIR_ESD0402__B72590B72590D0050H160ESD0402U1000SOC_RK3566_BGA565_15R5X14R4X0R9RK3566BGA565_15R5X14R4X0R90U2100PMIC_RK817_5_QFN68_7R00X7R00X0RPMIC_RK817_5QFN68_7R00X7R00X0R80_TU2200DCDC_SY827_CSP20_1R96X1R56X0R66TCS4525CSP20_1R96X1R56X0R66U2300LDO_PT5108_SOT_23_5_RT9193-18GBRT9193-18GBSOT_23_5U3900LPDDR4_200P_0_BGA200_15R00X10R0LPDDR4_200pBGA200_15R00X10R00X0R90U3901LDO_PT5108_SOT_23_5_DNP/PT5108EDNP/PT5108E23E-18SOT_23_5U4000INAND_EMMC_153_2L_BGA153_13R00XEMMC_B153_2LBGA153_13R00X11R50X0R90_2LU4100NANDFLASH_TSOP48_TSOP48_18R40X1NAND_FLASHTSOP48_18R40X12R10X1R20U4700BCT642_QFN24_2R50X3R40X0R90_BCTBCT642QFN24_2R50X3R40X0R90U4701LDO_PT5108_SOT_23_5_PT5108E23E-PT5108E23E-12SOT_23_5U4702BCT642_QFN24_2R50X3R40X0R90_BCTBCT642QFN24_2R50X3R40X0R90U5000ESD_ESD5304D_SON10_2R50X1R00X0RESD5304DSON10_2R50X1R00X0R50U5001ESD_ESD5304D_SON10_2R50X1R00X0RESD5304DSON10_2R50X1R00X0R50U5002SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACSOT_23_5U5200DCDC_MP1488_SOT26_TCS5226TCS5226SOT26U5201RT9271_0_SOT26_TCS3256TCS3256SOT26U5202LDO_PT5108_SOT_23_5_PT5108E23_1PT5108E23E-18SOT_23_5U5300GT800_1_GSL3675_GSL3676GSL3676GSL3675U5301GT800_0_QFN5X5-40PINA_CST21680SCST21680SEQFN5X5-40PINAU6100MODULE_AP6XXX_MD44_AP6XXX_AP625AP6255MD44_AP6XXXU7005AMPLIFIER_PT1505_MSOP8_TT8642TT8642MSOP8U9001U/ AK09918C_AK09918_DNP/AK0991DNP/AK09918CAK09918U9002U/ ITG-1010_0_LGA14-2R5X3_DNP/DNP/ICM-20600LGA14-2R5X3U9003MC3413-P-HF_0_MC3433_SC7A20SC7A20MC3433Y1200CRYSTAL_4P_CRY4_3R20X2R50X0R80_24MHzCRY4_3R20X2R50X0R80Y2100CRYSTAL_2P_1G_CRY2_6R90X1R40X1R32.768KHzCRY2_6R90X1R40X1R30Y6100CRYSTAL_4P_CRY4_3R20X2R50X0R8_137.4MHzCRY4_3R20X2R50X0R80 PCBALLEGRO格式,原理图ORCAD格式。
回复可见
**** Hidden Message *****
