8层工控 电脑主板PCB文件共享
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEATXPWR1CON5X2_165U_1MINI-ATXCONN/10PINCON5X2_165U_1ATXPWR2CON5X2_165U_1MINI-ATXCONN/10PINCON5X2_165U_1ATXPWR3CON5X2_165U_1MINI-ATXCONN/10PINCON5X2_165U_1AUDIO1PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180AUDIO2PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180AUTO1MYLAN_WAKE_UPPINHEADER 1X3_2.0MM_D180MYLAN_WAKE_UPA_USB1PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180A_USB2PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180A_USB3USBUSBX2_9_2.77MM_D90_USBUSBBAT1BAT3P_23D1X5D8BATTERYHOLDER CR2032LBAT3P_23D1X5D8BR1GBJ15_DGBJ1502/DIPGBJ15_DBZ1BZ_250BUZERBZ_250B_USB1USB-1USBX1_D90USB-1B_USB2USB-1USBX1_D90USB-1C632SM1206C0.001UF/2KV(1206)SM1206CCF1CF50_450XXW101CONNECTOR_CF/25X2P/SMDCF50_450XXW101CLR_CMOS1PH1X3_2D_D180PINHEADER 1X3_2.0MM_D180PH1X3_2D_D180COM1DCON9M-TCOM9M_DB9_D90DCON9M-TCOM2PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180COM3DCON9M-TCOM9M_DB9_D90DCON9M-TCOM4DCON9M-TCOM9M_DB9_D90DCON9M-TCOM5DCON9M-TCOM9M_DB9_D90DCON9M-TCOM6DCON9M-TCOM9M_DB9_D90DCON9M-TC_USB1PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180C_USB2PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180C_USB3USBUSBX2_9_2.77MM_D90_USBUSBD11N5817A1N58171N5817AD2BAT54C_132BAT54C_SOT23BAT54C_132D3BAT54_132BAS19_SOT23BAT54_132D4SM1206D_AC1N4148SM1206D_ACD51N5817A1N58171N5817AD6BAT54C_132BAT54C_SOT23BAT54C_132D71N5817A1N58171N5817AD8BAT54C_132BAT54C_SOT23BAT54C_132D9BAT54C_132BAT54C_SOT23BAT54C_132D101N5817ASM260A_DO214AC1N5817AD111N5817A1N58171N5817AD12BAT54S_132BAT54S_SOT23BAT54S_132D13BAT54S_132BAT54S_SOT23BAT54S_132D14BAT54C_132BAT54C_SOT23BAT54C_132D15SM1206D_AC1N4148SM1206D_ACD16SM1206D_AC1N4148SM1206D_ACD17BAT54C_132BAT54C_SOT23BAT54C_132D18SM1206D_AC1N4148/NCSM1206D_ACD19BAT54S_132BAT54S_SOT23BAT54S_132DC12V_IN1KDJACK_POWERPOWER_JACK2X2PINKDJACK_POWERDC48V_IN1KDJACK_POWERPOWER_JACK2X2PINKDJACK_POWERDVI1KDCON12X2_1D27MFEMALEHEADER2X12_1.27MM_S180KDCON12X2_1D27MDVI2FH2X12-HD-1P27MPINHEADER2X12_1.27MM_D180FH2X12-HD-1P27MDVI_D1DVI30ADVI-D/NCDVI30AEC1EC_10X12D547UF/100V(DIP)EC_10X12D5EC2EC_10X12D547UF/100V(DIP)EC_10X12D5FAN1MYFAN_LFAN_CONN/NCMYFAN_LFP1PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180FP2PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180FS1FUSE_SMDFUSE_1.1AFUSE_SMDFS2FUSE_SMDFUSE_1.1AFUSE_SMDFS3FUSE_SMDFUSE_1.1AFUSE_SMDGAS1TS-DO201CNR-GAS_C8G75/DIPTS-DO201GAS2TS-DO201CNR-GAS_C8G75/DIPTS-DO201GPIO1PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180H1MTH360_157157DRILL / 360PADMTH360_157IDE1PH2X22_2D_S180PINHEADER 2X22_2.0MM_S180PH2X22_2D_S180INV1CON5_BWAFER1X5_2.0MM_D180CON5_BJP1KDCON26X2_1D27MFEMALEHEADER2X26_1.27MM_S180KDCON26X2_1D27MJP2PH1X2_2D_D180PINHEADER 1X2_2.0MM_D180PH1X2_2D_D180JP3PH1X2_2D_D180PINHEADER 1X2_2.0MM_D180PH1X2_2D_D180JP4KDCON4X2_2MPINHEADER 2X4_2.0MM_D180KDCON4X2_2MJP5PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180JP6PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180JP7PH2X4_2D_S180PINHEADER 2X4_2.0MM_S180PH2X4_2D_S180JP8PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180JP9PH2X5_2D_S180PINHEADER 2X5_2.0MM_S180PH2X5_2D_S180JP10PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180JP11PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180JP12PH2X3_2D_S180PINHEADER 2X3_2.0MM_S180PH2X3_2D_S180JP13FH2X26-HD-1P27MPINHEADER2X26_1.27MM_D180FH2X26-HD-1P27ML1SM0603LBEAD30SM0603LL2SM0603LBEAD30SM0603LL3SM0603LBEAD30SM0603LL4SM0603LBEAD30SM0603LL5GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KSL6SM0603LBEAD30SM0603LL7GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KSL8TYL17X1012UH/9.6A(DIP)TYL17X10L9SM0805L10UH(0805)SM0805LL10GTLQH2510UH/190MA_GTLQH25-100K(SMD)GTLQH25L11GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KSL12GTLQH2510UH/190MA_GTLQH25-100K(SMD)GTLQH25L13SM0805L10UH(0805)SM0805LL14GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KSL15WQPC0302100NH/5A_WQPC0302-R10N(SMD)WQPC0302L16SM0805L0.1UH(0805)SM0805LL17TYL17X1012UH/9.6A(DIP)TYL17X10L18TYL17X103UH/10ATYL17X10L19TYL17X1012UH/9.6A(DIP)TYL17X10L20SM0805LBEAD120(0805)SM0805LL21SM0603LBEAD30SM0603LL22GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KSL23GSD0735KS1UH/12A_GSD0735KS(SMD)GSD0735KSL24SM0603LBEAD30SM0603LL25SM0603LBEAD30SM0603LL26TYL17X1012UH/9.6A(DIP)TYL17X10LAN1KDRJ45RJ-45KDRJ45LAN2KDRJ45RJ-45KDRJ45LCD_PWR1PH1X3_2D_D180PINHEADER 1X3_2.0MM_D180PH1X3_2D_D180LED1LED-504LED(BLUE)LED-504LED2LED-525LEDHOLDER(/BLUE/ORG)_5MM_D180LED-525LINE_IN1AUDIO_JACK_1LPHONEJACKSTEREO SW(BLUE)AUDIO_JACK_1LLINE_OUT1AUDIO_JACK_1LPHONEJACKSTEREO SW(GREEN)AUDIO_JACK_1LLPT1CON13X2_2MCBOXHEADER 2X13_2.0MM_D180CON13X2_2MCLVDS1CON15X2_1D25_01036WAFER2X15_1.25MM_S180CON15X2_1D25_01036MIC1AUDIO_JACK_1LPHONEJACKSTEREO SW(PINK)AUDIO_JACK_1LPCI1DP-PC104PLUSA_BD_D35PCI104DP-PC104PLUSA_BD_D35POE_PWR1CON2_42X55_9359WPWR_CONN/2PINCON2_42X55_9359WPS_1PS2_6P_T_1MINIDIN6(BLACK/THIN)PS2_6P_T_1PWR_IN1CON2L_5M_5EHDRPOWERCONNECTOR_2PIN(5EHDR-02P)CON2L_5M_5EHDRPWR_SW1PTA-118CBTACKSWITCHPTA-118CBQ12N7002B2N7002/SOT232N7002BQ2MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ3MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ4MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ52N7002B2N7002/SOT232N7002BQ62N7002B2N7002/SOT232N7002BQ7MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ8MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ9MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ10MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ11MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ12MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ13MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ14MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ152N7002B2N7002/SOT232N7002BQ16SOT23_QA2N3904/SOT23SOT23_QAQ172N7002B2N7002/SOT232N7002BQ18MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ192N7002B2N7002/SOT232N7002BQ20SOT23_QA2N3904/SOT23SOT23_QAQ21SOT223_GDSAPM2054NVC_SOT223_GDSSOT223_GDSQ22MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ23SOIC8APM4461AKC-TRL_SOIC8SOIC8Q24MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ25MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ26MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ27MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ282N7002B2N7002/SOT232N7002BQ29MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ30SOT23_QA2N3904/SOT23SOT23_QAQ31MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ32MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ33MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ34SOIC8APM4435KC-TRL_SOIC8SOIC8Q35MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ36MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ37MYSMDTO252_GDSSTU5025NLS_TO252MYSMDTO252_GDSQ38SOT23_QA2N3906/SOT23SOT23_QAQ39MYSMDTO252_GDSAP9974AGH_TO252MYSMDTO252_GDSQ40SOT23_QA2N3904/SOT23/NCSOT23_QAQ41SOT23_QA2N3904/SOT23SOT23_QAQ42SOT23_QA2N3904/SOT23SOT23_QAQ43SOT23_QA2N3904/SOT23SOT23_QAQ44SOT23_QA2N3904/SOT23SOT23_QART1SM0603RTHERS_10K1%/NCSM0603RSATA1SATA7P_MOLEXSATA_SATA7P_MOLEXSATA7P_MOLEXSATA2SATA7P_MOLEXSATA_SATA7P_MOLEXSATA7P_MOLEXSATA_PWR1CON5_BWAFER1X5_2.0MM_D180CON5_BSC1MYEC138_350270UF/16VMYEC138_350SC2MYEC200_400470UF/16VMYEC200_400SC3MYEC200_400470UF/16VMYEC200_400SC4MYEC138_350270UF/16VMYEC138_350SC5MYEC200_400470UF/16VMYEC200_400SC6MYEC138_350270UF/16VMYEC138_350SC7MYEC138_350270UF/16VMYEC138_350SC8MYEC138_350270UF/16VMYEC138_350SMBUS1MYLAN_WAKE_UPWAFER1X3_2.0MM_D180/NCMYLAN_WAKE_UPSODIMM1DDR_SODIMM_HLDDR2SODIMM 200PIN_9.2MMDDR_SODIMM_HLSPDIF1MYLAN_WAKE_UPWAFER1X3_2.0MM_D180/NCMYLAN_WAKE_UPU1SSOP28ZT213_SSOP28SSOP28U2SOT23-5HIP1020_SOT23-5SOT23-5U3TSSOP64F-240IC-SICS9LP505-1HGLFT_TSSOP64TSSOP64F-240U4SSOP28ZT213_SSOP28SSOP28U5TSSOP16_D65_GNDALT3800EFE_TSSOP16TSSOP16_D65_GNDAU6QFN64_9X9RTL8111C_QFN64_9X9QFN64_9X9U7QFN64_9X9RTL8111C_QFN64_9X9QFN64_9X9U8SOIC14ISL6522CBSOIC14U9SOIC893C46_SOIC8SOIC8U10SOIC14ISL6522CBSOIC14U11DIAMONDVILLE_BGA437INTELN270DIAMONDVILLE_BGA437U12DIP4PC817C/DIPDIP4U1382945GSE_BGA998945GSE82945GSE_BGA998U14BGA652-ICH7MICH7-MBGA652-ICH7MU15SOIC8APW7120KE-TRL_SOIC8SOIC8U16MAX8796-QFN32MAX8796GTJ+_TQFN32_5X5MAX8796-QFN32U17SOP8B-209SST25VF016B-50-4C-S2AF_SOP8B-209SOP8B-209U18SOIC1474HCT14_SOIC14SOIC14U19ISL6537-QFN28PISL6537ACRZ-TISL6537-QFN28PU20LQFP48CH7307C_LQFP48LQFP48U21SOIC1474F125_SOIC14SOIC14U22SOIC1474HC08_SOIC14SOIC14U23HN2436G_24HN2436G_HN2436G_24HN2436G_24U24HN2436G_24HN2436G_HN2436G_24HN2436G_24U25TYQFP128_D5W83627UHG_TYQFP128_D5TYQFP128_D5U26EPSOIC8ISL6506BCBZ-TEPSOIC8U27SOIC893C46_SOIC8SOIC8U28SOIC8-1ISL6612ACB-T_SOIC8-1SOIC8-1U29SOT23-5HIP1020_SOT23-5SOT23-5U30MYSMDTO252_GOIAPL1084-ADJ/TO252MYSMDTO252_GOIU31MYSOT223_GOIAPL1117-ADJ_SOT223MYSOT223_GOIU32SOIC8APW7120KE-TRL_SOIC8SOIC8U33SOT23_OIGAPR3001-30AI-TRL_SOT-23/NCSOT23_OIGU34SOT23_OIGAPR3001-30AI-TRL_SOT-23SOT23_OIGU35SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U36SOT23-5SN74LVC1G14DBVR_SOT23-5SOT23-5U37LQFP48VT1708A_LQFP48LQFP48U38SOIC1474F125_SOIC14SOIC14U39SOIC8LTC485_SOIC8SOIC8U40SOIC8LTC485_SOIC8SOIC8U41SSOP28ZT213_SSOP28SSOP28U42SOIC1474HCT14_SOIC14SOIC14U43SSOP28ZT213_SSOP28SSOP28U44SSOP28ZT213_SSOP28SSOP28U45SSOP28ZT213_SSOP28SSOP28U46SOIC8LTC485_SOIC8SOIC8U47SOIC8LTC485_SOIC8SOIC8VGA1VGACON15_S_KD-TDSUB_VGA_PORT(BLUE/THIN)VGACON15_S_KD-TX1SMD_49_CRYSTAL25MHZ/SMDSMD_49_CRYSTALX2SMD_49_CRYSTAL25MHZ/SMDSMD_49_CRYSTALX3XTALS32.768KHZ/DIPXTALSX4SMD_49_CRYSTAL14.318MHZ/SMDSMD_49_CRYSTAL PCB文件。回复可见下载
**** Hidden Message ***** 感谢分享的8层板子
