RTL8367N
RTL8367N :5 port switchbom:
Comment Description Designator Footprint LibRef Quantity
"LED-0603_R" "" "1V1, 3V3" "LED0603_RED" "LED0603_RED" "2"
"18PF" "" "C1, C2" "C0402" "C0402" "2"
"10nf" "" "C3, C4, C5, C7, C8" "C0603" "C0603" "5"
"0.1u" "" "C6, C9, C10, C11, C12, C13, C14, C15, C16" "C0603" "C0603" "9"
"10n" "" "C17, C21" "C0603" "C0603" "2"
"100uF" "" "C18, C19" "CAP-SMD_BD6.3-L6.6-W6.6-FD" "CAP-SMD_BD6.3-L6.6-W6.6-FD" "2"
"100n" "" "C20" "C0603" "C0603" "1"
"SI2302" "" "Q1" "SOT-23(SOT-23-3)" "SOT-23(SOT-23-3)" "1"
"2.5k" "" "R1" "R0603" "R0603" "1"
"4.7k" "" "R2, R3, R6" "R0603" "R0603" "3"
"470R" "" "R4, R5, R7, R8, R9" "R0603" "R0603" "5"
"10K" "" "R10" "R0603" "R0603" "1"
"1K" "" "R11, R12" "R0603" "R0603" "2"
"0R" "" "R13" "R0603" "R0603" "1"
"HR911130A" "" "RJ1, RJ2, RJ3, RJ4, RJ5" "RJ45-TH_HR911130A" "RJ45-TH_HR911130A" "5"
"4.7k" "" "RN1, RN2, RN3" "RES-ARRAY-SMD_0603-8P-L3.2-W1.6-BL" "RES-ARRAY-SMD_0603-8P-L3.2-W1.6-BL" "3"
"TS-1101VS-C-A-A" "" "SW-1" "KEY-SMD_4P-L7.8-W2.8-P4.20-EH" "KEY-SMD_4P-L7.8-W2.8-P4.20-EH" "1"
"RTL8367N-VB-CG" "" "U1" "MQFN-88_L10.0-W10.0-P0.40-BL-EP8.5" "MQFN-88_L10.0-W10.0-P0.40-BL-EP8.5" "1"
"UZ1084G-3.3V-TN3-R" "" "U2" "TO-252-3_L6.5-W5.8-P4.58-TL" "TO-252-3_L6.5-W5.8-P4.58-TL" "1"
"AP7361-10D-13" "" "U4" "TO-252-2_L6.6-W6.1-P4.57-LS9.9-BR-CW" "TO-252-2_L6.6-W6.1-P4.57-LS9.9-BR-CW" "1"
"" "" "Un0" "Pad_1.60mm" "Pad_1.60mm" "1"
"" "" "Un1, Un2, Un3, Un4" "MountingHole_2.00mm" "MountingHole_2.00mm" "4"
"TYPE-C 6P" "" "USB1" "TYPE-C-SMD_TYPE-C-6P" "TYPE-C-SMD_TYPE-C-6P" "1"
"25MHz" "" "X1" "OSC-SMD_4P-L3.2-W2.5-BL" "OSC-SMD_4P-L3.2-W2.5-BL" "1" 支持
