szhj14e 发表于 2020-8-14 11:05
PCB快速掌握:AD如何生成Gerber文件
打开Altium designer软件,打开设计好的pcb文件,在PCB 的文件环境中,左键点击 file-fabrication outputs-Gerber Files,进入Gerber setup 界面.
https://exp-picture.cdn.bcebos.com/e57a258602214f570a535908732064fb960b7358.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
在“General”选项 里面,“Units”选择“inches”,Format选择2:5 ,这个尺寸精度比较高。
https://exp-picture.cdn.bcebos.com/54a89daee8d7592a46eaeacb9f31dfb6326c6758.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
在“Layers”里面,选中“include unconnected mid-layer pads”,在“Plot Layers” 下拉菜单里面选择“used on”,要检查一下,不要丢掉层。在“mirror layers” 下拉菜单里面选择 “all off”,右边的机械层都不要选。
https://exp-picture.cdn.bcebos.com/332d496699cf0253826629366b36e29147e85f58.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
在“Apertures”里面,打勾选中“Embeded apertures(RS274X) ”在“advanced”里面,在“Leading/Trailing Zeroes” 区域,选中“Suppress leading zeroes”,点击“ok”按键,进行第一次输出。
https://exp-picture.cdn.bcebos.com/22c4fe36e29147e881e533c1b603bbea3e865858.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1https://exp-picture.cdn.bcebos.com/32a127723d03bbea88833afbea43d7d448315458.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
https://exp-picture.cdn.bcebos.com/baab2086304861436ed142828febf6a75f0f5358.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
在PCB 的文件环境中,再次file-fabrication outputs-Gerber Files进入Gerber setup 界面, 在“layers”里面 ,在左边的“plotlayers/ mirrorlayers” 都all off,“include unconnected mid-layer pads”也不打勾, 只选中有关板子外框的机械层。
https://exp-picture.cdn.bcebos.com/49701aebf6a75f0f3c2e7e5d97324b18512c4c58.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
在“Drill Drawing”里面,选择你要导出的层对。一般选择“Plot all used layer pairs”,“mirror plots”不用选中。Drill Drawing plots 和 Drill Guide Plots做同样的选择,点击“ok”按键,进行第二次输出。
https://exp-picture.cdn.bcebos.com/75af02324b18512c4ff4d214ad334884cde34958.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1https://exp-picture.cdn.bcebos.com/4a594f2c8cf1d8a7e336423746e34b2c56ee4758.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
在PCB 的文件环境中,左键点击 file-fabrication outputs-NC Drill Files,进入NC Drill Setup 界面,units选择“inches”,format选择2:5 。 在“Leading/Trailing Zeroes” 区域,选中“Suppress trailing zeroes”,和之前Gerber Setup 的“advanced”里面要保持一致,其他默认选项不变。
https://exp-picture.cdn.bcebos.com/27725684cde34b2c9feb71cc0d0e7c75e5f44358.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
点击ok按键,进行第三次输出。在弹出来的“import Drill Data” 界面里左键点击“ok”按键,进行输出。
https://exp-picture.cdn.bcebos.com/4a6d48ee7b7f860eb070ef4777f5ee0d3acebe58.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1https://exp-picture.cdn.bcebos.com/7a3e980e7c75e5f432f0e4beb1ceaad7726bbc58.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
把当前工程目录下的Out 文件夹中的所有的文件进行打包压缩,送到加PCB工厂进行加工。
https://exp-picture.cdn.bcebos.com/1562a0b9763e21c260d3eb63e6e89a618625b158.jpg?x-bce-process=image%2Fresize%2Cm_lfit%2Cw_500%2Climit_1
END
注意事项
关于尺寸精度,Leading/Trailing Zeroes等许多细节可以和厂家协商后根据厂家的工艺水平等条件确定
szhj14e 发表于 2020-8-14 11:06
zsizcdz 发表于 2020-8-14 12:29
chenweigang 发表于 2020-8-14 12:43
li198998 发表于 2020-8-14 20:02
cybi1861 发表于 2020-8-15 08:49
yyc668 发表于 2020-8-15 08:51
mao20602130 发表于 2020-8-15 20:34
bidinghong 发表于 2020-8-16 09:09
学习学习
shakencity 发表于 2020-8-16 21:47
查看完整版本: PCB快速掌握:AD如何生成Gerber文件
