一个ALLEGRO 板子封装库共享 有需要的下载
ALLEGRO16.6格式
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEBT1BATTERY_1_BS1220_BATTERYBATTERYBS1220D1DIODESCHOTTKY_3_DO-214AA_SMBJ6SMBJ6.5CADO-214AAD8ZC2800E/SOT_1_DO-214AA_SS35SS35DO-214AAD9BAT54C/SOT_SOT23_BAT54CBAT54CSOT23D10BAT54A/SOT_1_SOT23_BAT54CBAT54CSOT23D11DIODE_SOD-323_ESD05V32D-LCESD05V32D-LCSOD-323D19LED_LED0805_LEDLEDLED0805D20DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D21DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D22LED_LED0805_LEDLEDLED0805D23DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D24DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D25ZC2800E/SOT_1_SOD_123_B0520B0520SOD_123D26ZC2800E/SOT_1_SOD_123_B0520B0520SOD_123D27DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D29DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D30DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D31DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323D32DIODE_SOD-323_ESD05V32D-LCESD05V32D-LCSOD-323D33DIOD,CLMP,PGB001,0603,ESDSUPRS_ESD05V32D-LCSOD-323F1FUSE_1812R_SMD1812P020TFSMD1812P020TF1812RF2FUSE_1812R_SMD1812P020TFSMD1812P020TF1812RF3FUSE_PPTC_S_5A/16V5A/16VPPTC_SF4FUSE_1812R_SMD1812P050TFSMD1812P050TF1812RFB3INDUCTOR_0805R_FBFB0805RFB4FB,120OHM,2A,25%,0603,0.05DCR_120 OHM/2A@100MHz0805LG1DIODESCHOTTKY_2_3R_6_3RM090M-63RM090M-63R_6G2DIODESCHOTTKY_3_GDT-1812_UN181UN1812-90CSMDGDT-1812G3DIODESCHOTTKY_3_GDT-1812_UN181UN1812-90CSMDGDT-1812J2CON12-LN_1_381-S-4-EAR_CON4-LN3CON4-LN381381-S-4-EARJ3CONN PCB8_4_SIP4_127_PIN4-127PIN4-127SIP4_127J4CONN PCB8_6_SIP4_127_PIN4-127PIN4-127SIP4_127J5CONN PCB8_23_JC4_200_PIN4-200PIN4-200JC4_200J6CONN PCB8_21_JC4_200_PIN4-200PIN4-200JC4_200J7CONN PCB8_20_JC4_200_PIN4-200PIN4-200JC4_200J8MICROUSB_0_MICRO_USB_180_MICROUMICROUSBMICRO_USB_180J9MICROUSB_0_MICRO_USB_180_MICROUMICROUSBMICRO_USB_180J10CON14A_8_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-HJ13CON14A_8_RF-51-3612-50-H_51-3_151-3612-50-H_NCRF-51-3612-50-HJ14CON10A_6_NANOSIM_TF_NANOSIM+TFNANO SIM+TFNANOSIM_TFJ15CON10A_6_NANOSIM_TF_BACK_NANOSNANO SIM+TFNANOSIM_TF_BACKJ16CONN PCB8_7_SIP4_254_O_PIN4-25PIN4-254SIP4_254_OJ17CONN PCB8_7_SIP4_254_O_PIN4-25PIN4-254SIP4_254_OJ18IMX6UL-CM-FCI_6_IMX6UL_200N-FCIIMX6UL_200N-FCI_10142990C_AIMX6UL_200N-FCI-2PJ19CON14A_8_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-HJ20CON5-LN_1_LORA-RA-02_LORA-RA-02LoRa-Ra-02LORA-RA-02J21CON5-LN_0_ET100_ET100ET100ET100J25CON14A_0_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-HJ26CON14A_0_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-HJ27CON10A_0_GF15_200_TFTFGF15_200J28CON10A_1_GF6_254_NANOSIMNANO SIMGF6_254J29CON14A_8_RF-51-3612-50-H_51-36151-3612-50-HRF-51-3612-50-HJC1CONN PCB8_8_JC2_254_JC2_254JC2_254JC2_254JC2CONN PCB8_8_JC2_200_JC2_200JC2_200JC2_200JC3CONN PCB8_4_JC3_254_JC3_254JC3_254JC3_254JC5CONN PCB8_8_PH2X1-254_JC2_254JC2_254PH2X1-254JC6CONN PCB8_8_PH2X1-254_JC2_254JC2_254PH2X1-254L1INDUCTOR_8MMX7R5MM-L_744777004_744777004_4.7uH8MMX7R5MM-LL2INDUCTOR_8MMX7R5MM-L_744777004_744777004_4.7uH8MMX7R5MM-LL3INDUCTOR_8MMX7R5MM-L_744777004_744777004_4.7uH8MMX7R5MM-LL4INDUCTOR_0603L_56NH_NC56nH_NC0603LL5DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2L6INDUCTOR_0603R_2.7NH2.7nH0603RL7INDUCTOR_0603R_2.7NH2.7nH0603RL8DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2L9DLW21HN900HQ2_SOP4-EMI-2_DISCREDLW21HN900HQ2SOP4-EMI-2LED1LED_LED0805_LEDLEDLED0805LED9LED_LED0805_LED_GREENLED_GREENLED0805Q1PNP BCE_1_SOT23_S8550S8550SOT23Q2MPF6660_0_SOT23_2N7002K2N7002KSOT23Q3MPF6660_0_SOT23_2N7002K2N7002KSOT23Q4MPF6660_0_SOT23_2N7002K2N7002KSOT23Q5IRF4905/TO_7_SOT23_BSS84BSS84SOT23Q6IRF4905/TO_7_SOT23_BSS84BSS84SOT23Q7IRF4905/TO_7_SOT23_BSS84BSS84SOT23Q8IRF7104/SO_6_SO8_IRF7328IRF7328SO8Q9MPF6660_0_SOT23_2N7002K2N7002KSOT23Q10MPF6660_0_SOT23_2N7002K2N7002KSOT23Q11IRF7104/SO_6_SO8_IRF7328IRF7328SO8Q12MPF6660_0_SOT23_2N7002K2N7002KSOT23Q132N7002_0_SOT23_2N7002K2N7002KSOT23Q142N7002_0_SOT23_2N7002K2N7002KSOT23Q152N7002_0_SOT23_2N7002K2N7002KSOT23Q16IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23Q17MPF6660_0_SOT23_2N7002K2N7002KSOT23Q18IRF7104/SO_6_SO8_IRF7328IRF7328SO8Q19MPF6660_0_SOT23_2N7002K2N7002KSOT23Q20MPF6660_0_SOT23_2N7002K2N7002KSOT23Q21MPF6660_0_SOT23_2N7002K2N7002KSOT23Q222N7002_0_SOT23_S8050S8050SOT23Q232N7002_0_SOT23_S8050S8050SOT23Q242N7002_0_SOT23_S8050S8050SOT23Q25IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23Q26MPF6660_0_SOT23_2N7002K2N7002KSOT23Q27IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23Q28IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23Q29IRF4905/TO_6_SOT23_IRLML6401IRLML6401SOT23Q30MPF6660_0_SOT23_2N7002K2N7002KSOT23Q372N7002_0_SOT23_S8050S8050SOT23RA1RN_33RX4_0_0603RA_49R949R90603RARA2RN_33RX4_0_0603RA_49R949R90603RAT1TESTPOINT_4_TESTPOINT_TESTPOINTtestpointTESTPOINTU2SP3485_SOIC8_MAX3485ESAMAX3485ESASOIC8U3TPS5430_0_SO8-TPS5430_TPS54340TPS54340SO8-TPS5430U4TPS5430_0_SO8-TPS5430_TPS54340BTPS54340BSO8-TPS5430U5TPS5430_0_SO8-TPS5430_TPS54340BTPS54340BSO8-TPS5430U6HEF4521B_0_SO16_HEF4521BHEF4521BSO16U774HC05PW_6_TSSOP-14_74HC05PW74HC05PWTSSOP-14U8CON3_3_SOT-23-5_ME6214C33M5GME6214C33M5GSOT-23-5U9MPU-6881A_0_QFN24_MPU6881_MPU-6MPU-6881AQFN24_MPU6881U10MPU-6881A_4_SCL3300-DO1_SCL3300SCL3300-D01SCL3300-DO1U11CN301_13_BMP180_BMP180BMP180BMP180U12SP-4_0_ET_SWITCH-S6_SP-6SP-6ET_SWITCH-S6U13MAX3387ECUG_25_SOT23_MAX809STR/MAX809STR/2.9VSOT23U14STM8L151C8TX_1_LQFP48_STM8L151CSTM8L151C8TxLQFP48U15MIC2526-2BM_0_SO8_MIC2526-1BMMIC2526-1BMSO8U16IC_AU6259-JBL_LQFP_1_LQFP48_AU6AU6268-JBLLQFP48U17MIC2526-2BM_2_SO8_MIC2526-1BMMIC2526-1BMSO8U18ET-SWITCH-8_ET_SWITCH-S8_SP-4SP-4ET_SWITCH-S8U19CH340G_0_SO8_CH340NCH340NSO8U20SP-4_6_ET_SWITCH-S4_SP-4SP-4ET_SWITCH-S4U21EC20_EC20_EC20EC20EC20U22SIM_13_TSSOP-14_TXS0104EPWRTXS0104EPWRTSSOP-14U23ESDA6V1SC6_SOT23-6_UDT26A05L05UDT26A05L05SOT23-6U25SIM_0_NANO_SIM_SIMSIMNANO_SIMU26ESDA6V1SC6_SOT23-6_UDT26A05L05UDT26A05L05SOT23-6U27RT9261_0_QFN-24_LAN8720ALAN8720AQFN-24U28SP-4_1_SO-8_SLVU2.8-4SLVU2.8-4SO-8U29PM44-11BP_PM44-11BP_PM44-11BPPM44-11BPPM44-11BPU30RT9261_0_QFN-24_LAN8720ALAN8720AQFN-24U31SP-4_1_SO-8_SLVU2.8-4SLVU2.8-4SO-8U32PM44-11BP_PM44-11BP_PM44-11BPPM44-11BPPM44-11BPU33DS3231-M_SOP8-50-150_DS3231MDS3231MSOP8-50-150U34MAX3387ECUG_25_SOT23_MAX809STR/MAX809STR/2.9VSOT23U35BL-R8723BT1_1_BL-R8723BT1_BL-R8BL-R8723BT1BL-R8723BT1U36SIM_7_MSOP10_FSUSB30FSUSB30MSOP10U37CON6_2_ET_SWITCH-S4_SP-4SP-4ET_SWITCH-S4U38SIM_12_TSSOP-14_TXS0104EPWRTXS0104EPWRTSSOP-14U40EC_20_PCIE_7_CX6600_CX6600CX6600CX6600U41TF_TF-DRAWER_TFTFTF-DRAWERU42SIM_0_NANO_SIM_SIMSIMNANO_SIMU43EC20_EC20_EC20EC20EC20W1CONN PCB8_0_TO-92_DS18B20DS18B20TO-92W2CONN PCB8_0_PH3_200_DS18B20DS18B20PH3_200W3CONN PCB8_0_PH3_200_DS18B20DS18B20PH3_200X1XTAL_XTAL4-3225_40MHZ/3.3V40MHz/3.3VXTAL4-3225Y1CRYSTAL_8_SMD5032_NEW_8MHZ8MHZSMD5032_NEWY2CRYSTAL_8_SMD5032_NEW_12MHZ12MHZSMD5032_NEW 谢谢分享!!! 谢谢分享 感谢楼主分享 等我升到二级回来下载
收下了,谢谢分享 谢谢分享 感谢分享 谢谢谢谢
