以下内容由管理员 @老吴 整理补充
| Name | PCB Decal | Value | Part Type |
| ANT1501 | RF_3PIN_3X3 | RF_3PIN_3X3 | |
| CON1 | DIP-PH-1X4P-L | DIP-PH-1X4P-L | DIP-PH-1X4P-L |
| CON19 | DIP-PH-1X6P-L | DIP-PH-1X6P-L | DIP-PH-1X6P-L |
| CON1602 | SIM_016-7P | SIM_CARD | SIM-016-P7 |
| CON3302 | RF_TEST_PAD_4MM | RF_TEST_PAD_4MM_A_1 | |
| CON3303 | RF_3PIN_3X3 | RF_3PIN_3X3 | |
| CON3401 | RF_TEST_PAD_4MM | RF_TEST_PAD_4MM_A_1 | |
| CON6404 | FFC-6PIN-0.5MM | FFC-6PIN-0.5MM | FFC-6PIN-0.5MM |
| CON9005 | COAXIAL/SMD/TA-RF02-001-03-811 | TA-RF02-001-03-811 | CON_/_4_/_TP-RF005-001-03-815_1 |
| D1 | DO-214AC | SS34 | D_SS34_DO214AC |
| D2 | 1N4148 | IN4148 | D_IN4148_LL34 |
| D3 | SUP4059W | B5819W | SUP4059W |
| D4 | SUP4059W | B5819W | SUP4059W |
| D5 | SUP4059W | B5819W | SUP4059W |
| D7 | DO-214AC | SS34 | D_SS34_DO214AC |
| D13 | DO-214AC | SMAJ15CA | B340A-E3/61T |
| D21 | LED0603 | BLUE | DLED_0603_BYS |
| D22 | LED0603 | RED | DLED_0603_RYS |
| D601 | SOT23 | BAT54S | BAT54S |
| D602 | SOD323 | SUP38N20V | DIODE_SCHOTTKY_3 |
| D603 | SOT23 | BAT54S | BAT54S |
| D604 | SOD323 | SUP38N6V | DIODE_SCHOTTKY_3 |
| D605 | SOD123 | B5819W | DIODE_SCHOTTKY_3 |
| D2024 | SOD323 | NC | DIODE_SCHOTTKY_3 |
| ED25 | D0402 | ESD0402V24C03 | ESD0402V24C03 |
| F1 | F-1210 | 0R | SMD1210P150TF/16 |
| F5002 | DIPLEXER/6P/SMD/DPX165950DT | RFDIP160806BLM5T62 | BL1608-05K2450_0 |
| FD9101 | FD | TP / 40 / mil | TP_R_1MM |
| FD9102 | FD | TP / 40 / mil | TP_R_1MM |
| FD9103 | FD | TP / 40 / mil | TP_R_1MM |
| FD9104 | FD | TP / 40 / mil | TP_R_1MM |
| J1 | FPC30P_05 | FPC30PIN_0.5MM_R | FPC30PIN_0.5MM_R |
| J2 | USB_A | USB-4S4 | USB_A |
| J3 | CON2X11PIN_2_0MM | NC | CON2X11PIN_2_0MM |
| J5 | CON2X17PIN_2_0MM | PHB-200217SCU8-05 | CON2X17PIN_2_0MM |
| J3401 | RF_3PIN_3X3 | RF_3PIN_3X3 | |
| L1 | R0603 | 0R | ZR0603 |
| L2 | L-8040S | 1.5uH | SWPA8040S1R5NT |
| L3 | L-6028S | 2.2uH | SMDRH8D43 |
| L4 | L/IND/SMD/LVS252010-2R2 | 4.7uH | INDUCTOR |
| L6 | GRC0603-A | 1K | 600OHM/1A/SMD0805 |
| L602 | L4X4N | 10uH | INDUCTOR_0_2 |
| L1801 | L0402 | 1K/100MHz | FB_/_BLM15AG121SN1 |
| L2001 | L/IND/SMD/VLS201610E | 330nH | L_/_MDMK2020TR68MM_/_SMD2520 |
| MIC2- | 1PIN-1.2X2 | TEST POINT | TEST_POINT_DIP0_4.6 |
| NTC2000 | R0402 | ERTJ0ER104F | NTC_/_NCP15WF104F03RC_/_0402__0 |
| NTC3201 | R0201 | ERTJ0ER104F | NTC_/_NCP15WF104F03RC_/_0402_ |
| PA402 | PAD2_60 | X | CAPACITOR_2 |
| Q1 | SOT23 | 3904 | Q_3904_SOT23 |
| Q2 | SOT23 | 2N7002L | NMOS |
| Q3 | SOT23 | 3904 | Q_3904_SOT23 |
| Q4 | SOT23 | NC | NMOS |
| Q5 | SOT23 | NC | NMOS |
| Q6 | SOT23 | 2N7002L | NMOS |
| Q20 | SOT23 | 3904 | Q_3904_SOT23 |
| Q1512 | SOT23 | SI2301 | Q_SI2301_SOT23 |
| Q1513 | SOT23 | 3904 | Q_3904_SOT23 |
| Q1528 | SOT23 | SI2301 | Q_SI2301_SOT23 |
| Q1529 | SOT23 | NC | Q_3904_SOT23 |
| SC9185 | CABLE_CLIP/3P/SMD/PCV1003 | SC / PCV1003 | CON/CABLE_CLIP/PCV1003 |
| SH901 | CON_PAD_DOT | NO PAD 0402 | CON_PAD_DOT |
| SH902 | CON_PAD_DOT | NO PAD 0402 | CON_PAD_DOT |
| SH5001 | R0402 | 0R | ZR0402 |
| SH5002 | R0402 | 0R | ZR0402 |
| SHR1 | RFSHORT | RFSHORT | |
| SHR2 | RFSHORT | RFSHORT | |
| TP6506 | TP1MM | TP | TP-1.0MM |
| U1 | TSOT23-8 | MP1495 | MP1495 |
| U2 | GL850G-SSOP28 | GL850G | GL850G-SSOP28 |
| U3 | SOT23-5 | AF6221-33C | RT9179_1 |
| U4 | SOT23-5 | AF6221-33C | RT9179_1 |
| U7 | TSOT23-6 | MP1470 | MP1470 |
| U9 | BISS0001 | BISS0001 | RT9167-NNCB_8_4 |
| U25 | EXC14CE_0302 | NC | TLSDCW_1 |
| U47 | SOT23-5 | AF6221-33C | RT9179_1 |
| U401 | SOT23_6 | SY7200A | MP3202 |
| U603 | SOT23-5 | TCS23351_E | MP3202_0 |
| U902 | DFN2X2_6L_PNMT6N1 | PNMT6N1 | PNMT6N1 |
| U1001 | MT8665/VFBGA641/P0.4/B0.25/12.6X12.6 | IC-MT8665-LP3-SBS | IC-MT8735_0 |
| U1011 | EXC14CE_0302 | NC | TLSDCW_1 |
| U1012 | EXC14CE_0302 | NC | TLSDCW_1 |
| U1013 | EXC14CE_0302 | NC | TLSDCW_1 |
| U1014 | EXC14CE_0302 | NC | TLSDCW_1 |
| U1015 | EXC14CE_0302 | NC | TLSDCW_1 |
| U1401 | SDMMC_SLOT_11 | SDMMC_SLOT_11 | MS110-C10B-C13-A_2 |
| U1601 | UTQFN10L | HR1532TQFN | DSPDT_1 |
| U2001 | MT6328/VFBGA205/P0.4/B0.25/6.6X6.6 | MT6328E1 | IC/MT6328-E1/XXXMM_0 |
| U3101 | MT6169/VFBGA175/P0.4/B0.25/6.2X5.4 | MT6169 | 60118A_22 |
| U3102 | TCXO/SMD/2.5X2.0/KT2520F | 26MHZ | KT2520F26000DCW28QAK |
| U3203 | SKY77643 | PA_/_SKY77590_9 | |
| U3210 | BALUN/SMD/HHM22112A2 | RFLPF16082G5WM0T29 | LF1608-B2R5KCB |
| U3215 | FILTER/SMD/885049 | SAFEA2G35MF0F0A | SAW_3 |
| U3216 | FILTER/SMD/LFB212G49CG7D755 | NC | DEA102700LT-6307_0 |
| U3224 | FILTER/SMD/885049 | SAFEA2G60MA0F0A | SAW_3 |
| U3301 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | NC | DPX_/_SAYFH1G74BA0B0A_0 |
| U3302 | RF1628 | HS8728 | SPDT_/_BGS12SL6_2 |
| U3303 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | NC | DPX_/_SAYFH1G74BA0B0A_0 |
| U3304 | RF1628 | NC | SPDT_/_BGS12SL6_2 |
| U3305 | SAWFILTER/SMD/SAWFD1G90BH0F0A | SAWFD1G90BK0F0A | SAWFD1G90BH0F0A_0 |
| U3306 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | SAYEY1G95HA0F0A | SAW-DPX-RX-BAL_1 |
| U3307 | SKY77910 | HS8916 | ASM_/_SKY13492_7 |
| U3308 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | NC | SAW-DPX-RX-BAL_1 |
| U3309 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | SAYEY1G74BC0B0A | DPX_/_B8627_0 |
| U3310 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | NC | DPX_/_B8627_0 |
| U3311 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | NC | SAW-DPX-RX-BAL_1 |
| U3313 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | HDDB05NSB-B11 | SAW-DPX-RX-BAL_1 |
| U3314 | DUPLEXER/8P/SMD/SAYEY710MBA0F0A | SAYEY897MCA0B0A | SAW-DPX-RX-BAL_1 |
| U3315 | TSLP10/SMD/P0.4/BGS22WL10 | MXD8650 | XM0860SH-DL0601_21 |
| U3320 | FILTER/SMD/TFSL06050915-4108B1 | NC | SAW_0 |
| U3323 | BALUN/SMD/TFSZ06052460-3310A2 | RFBLN06052G5WM9T16 | TDK-BALUN_0 |
| U3324 | BALUN/SMD/TFSZ06051897-3317A1 | RFBLN06051G8DM1T69 | BAL_/_TFSZ06051897-3317A1 |
| U3325 | BALUN/SMD/TFSZ06052460-3310A2 | NC | TDK-BALUN_0 |
| U3332 | SKY13489 | NC | SPDT_/_BGS12SL6_0 |
| U3402 | RF1628 | HS8728 | SPDT_/_BGS12SL6_2 |
| U3403 | QFN14_2X2X06 | HS8718 | XM0860SH-DL0601_1 |
| U3404 | RF1628 | HS8728 | SPDT_/_BGS12SL6_2 |
| U3405 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAFFB2G35AA0F0A | SAW_7 |
| U3406 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAFFB1G84FL0F0A | SAW_3_3 |
| U3407 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAFFB1G90FB0F0A | SAW_2 |
| U3408 | SAWFILTER/SMD/F6QB2G595P2BS | HDFB07RSB-B5 | SAW_1_2 |
| U3409 | BALUN/SMD/TFSZ06051897-3317A1 | RFBLN06052G5WM9T16 | BAL_/_TFSZ06051897-3317A1 |
| U3410 | SAWFILTER/SMD/F6QB2G595P2BS | SAFFB2G14FA0F0A | SAW_4_2 |
| U3411 | RF1628 | HS8728 | SPDT_/_BGS12SL6_2 |
| U3412 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAFFB740MAA0F0A | SAW_5 |
| U3413 | SAWFILTER/SMD/SAFFB1G90FB0F0A | SAFFB806MAA0F0A | SAW_6 |
| U3414 | FILTER/SMD/TFSL06050915-4108B1 | RFLPF06050G9D0T | SAW_0 |
| U3415 | BALUN/SMD/TFSZ06051897-3317A1 | RFBLN0605040YM9T16 | BAL_/_TFSZ06051897-3317A1 |
| U3416 | SAWFILTER/SMD/SAFFB1G90FB0F0A | NC | SAW_3_3 |
| U3417 | SAWFILTER/SMD/F5QB2G595P2BS | HDFB05RSB-B5 | SAW_1 |
| U3418 | SAWFILTER/SMD/F6QB2G595P2BS | SAFFB2G60AA1F0A | SAW_6_2 |
| U3419 | SAWFILTER/SMD/F5QB2G595P2BS | SAFFB942MFL0F0A | SAW_2_2 |
| U3420 | QFN14_2X2X06 | HS8713 | XM0860SH-DL0601_1 |
| U3424 | TSLP10/SMD/P0.4/BGS22WL10 | MXD8650 | XM0860SH-DL0601_21 |
| U4102 | FBGA178/SMD | K4E6E304E3-EGCE | LP_DDR2(JEDEC_162B)_5 |
| U5001 | MT6625/SQFN40/SMD/P0.4/5X5 | MT6625L | MT6611_SMD_WLCSP-61_0 |
| U5002 | TCXO/SMD/2.5X2.0/IT2205BE | 26MHz | TCXO_RAKON_SMD_4P |
| U5005 | FILTER/SMD/ACPF-7124 | HDF2442E-B2 | SAFEB1G57KA0F00 |
| U5102 | SAW_42X53 | HDF1588E-B2 | GPS-FILTER_0 |
| U5103 | QFN6_15_10_08 | HS1100 | MAX2657_0 |
| U6316 | BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA | KLMAG2GEND-B031 | 169_BALL_EMMC_1 |
| U6317 | LQFP48-7X7 | STM8S005C6T6 | STM8S005C6 |
| U6320 | SOT23-5 | NC | RT9179_1 |
| U6443 | TSLP6/SMD/P0.4/BGA725L6/S | BGA729N6 | NJG1107HB3_0 |
| VD401 | SOD123 | B5819W | DIODE_0_2 |
| VD704 | SOD123 | SUP58N5V1 | DIODE_0 |
| VD707 | SOD123 | SUP58N2V4 | DIODE_0 |
| VR1521 | R0402 | NC/EZJZ0V500AA | VR0402 |
| VR1552 | R0402 | NC/EZJZ0V500AA | VR0402 |
| X1 | OSC3225 | 12M | CRYSTAL-4_0 |
| X2001 | CRYS/SMD/3.2X1.5/9H032000XX/TXC | 32.768KHz | CM7V-T1A |
| X2002 | OSC3225 | NC | CRYSTAL-4_0 |
