layout 发表于 2018-11-1 21:28
L5973D+MIC38C45YM做的20KW功率电源板 原理图和PCB封装共享&nb
PADS VX2格式
NamePart TypePCB DecalValueC1MPP_0.22UF630VMPP_16.7/8.8_P15MM0.22UF630VC2Y1_4.7NF400VY1_14/6_P10MM4.7NF400VC3Y1_4.7NF400VY1_14/6_P10MM4.7NF400VC4Y1_4.7NF400VY1_14/6_P10MM4.7NF400VC5Y1_4.7NF400VY1_14/6_P10MM4.7NF400VC6C3D_18UF600VC3D18UF600V_33/23MM18UF600VC7CAP08058051UF25VC8CAP08058051UF25VC9CAP08058051uF25VC13NCC_470UF500VNCC_470UF500V470UF450VC14CAP08058050.1UF50VC15CAP08058051UF25VC16CAP_DIP-1000UF25VDIP10-23_1000UF25V1000UF25VC17CAP_DIP-1000UF25VDIP10-23_1000UF25V1000UF25VC18MPP_0.68UF630VMPP_17.6/12.5_P15MM0.68UF630VC19CAP1210121010UF25VC20CAP12061206100PF1KVC21Y1_4.7NF400VY1_14/6_P10MMNCC22Y1_4.7NF400VY1_14/6_P10MMNCC23CAP08058052.2nF50VC24CAP08058050.1UF50VC25CAP1210121010UF25VC26CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC27CAP0805805220PF200VC28CAP-220UF16VSMD8-10_16V_220UF220UF35VC29CAP-220UF16VSMD8-10_16V_220UF220UF35VC44CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC45CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC46CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC47CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC48CAP1210121010UF25VC49CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC50CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC51CAP1210121010UF25VC52CAP08058054.7nF50VC53CAP12061206100PF1KVC54CAP08058054.7nF50VC55CAP12061206100PF1KVC56CAP08058054.7nF50VC57CAP12061206100PF1KVC58CAP08058054.7nF50VC59CAP12061206100PF1KVC60CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC61CAP-100UF35VSMD6.3-8_35V_100UF100UF35VC63MPP_0.22UF630VMPP_16.7/8.8_P15MM0.22UF630VC64MPP_0.22UF630VMPP_16.7/8.8_P15MM0.22UF630VC65MPP_0.22UF630VMPP_16.7/8.8_P15MM0.22UF630VC66MPP_0.22UF630VMPP_16.7/8.8_P15MM0.22UF630VC72CAP0805805470PF50VC76CAP08058051NF50VC77CAP_DIP-1000UF25VDIP10-23_1000UF25V1000UF25VC79CAP08058051uF25VC80CAP_DIP-1000UF25VDIP10-23_1000UF25V1000UF25VC81CAP08058050.22uF25VC82CAP_DIP-1000UF25VDIP10-23_1000UF25V1000UF25VC85C6A_4.7UF300VACC6A_32/22_P27.5MM3.3UF300VACC86CAP-220UF16VSMD8-10_16V_220UF220UF35VC87CAP-220UF16VSMD8-10_16V_220UF220UF35VC88CAP-220UF16VSMD8-10_16V_220UF220UF35VC89X1_0.68UF330VACXCAP_32/11_P27.5MM0.68UF330VACC90CAP08058050.1U50VC91Y2_4.7NF250VY2_12/5_P7.5MM4.7NF250VC92Y2_4.7NF250VY2_12/5_P7.5MM4.7NF250VC95CAP_DIP-1000UF25VDIP10-23_1000UF25V1000UF25VC96CAP_DIP-100UF25VDIP6.3-11_100UF25V100UF25VC97CAP_DIP-470UF25VDIP8-20_470UF25V220UF25VC98CAP1210121010UF25VC99CAP1210121010UF25VC100X1_0.33UF330VACXCAP_26.5/8.5_P22.5MM0.33UF330VACC101Y2_4.7NF250VY2_12/5_P7.5MM1NF250VC102Y2_4.7NF250VY2_12/5_P7.5MM1NF250VC105CAP08058051uF25VC106CAP-220UF16VSMD8-10_16V_220UF220UF35VC137CBB-0.1UF630VCBB_17.5/6_P15MM0.1UF630VCN3CON2.54-2PCON2.54_2PCON2.54-2PCT1TA125-1TA125-1TA125-1D1DIODE-3P-TO247IGBT-TO247STPSC20H65CWD2ZENER-DIODE-SOD123SOD-12312VD3DIODE_DO214ACDO-214ACES1JD4DIODE_SOD123SOD-123MBR0540T1D5DIODE_SOD123SOD-123MBR0540T1D6DIODE_HDIODE-HUF3004D7ZENER-DIODE-SOD123SOD-123LBZT52C2V7T1GD8ZENER-DIODE-SOD123SOD-12315VD9DIODE_SOD323SOD-323MMDL914T1GD10DIODE_SOD323SOD-323MMDL914T1GD11ZENER-DIODE-SOD123SOD-12312VD12DIODE_DO214ACDO-214ACES1DD13ZENER-DIODE-SOD123SOD-12315VD14DIODE_HDIODE-HMUR420D15DIODE_DO214ACDO-214ACES1DD16DIODE_SOD123SOD-123MBR0540T1D17DIODE_SOD123SOD-123MBR0540T1D19DIODE_SOD123SOD-123MBR0540T1D21DIODE_SOD123SOD-123MBR0540T1D22DIODE_DO214ACDO-214ACES1DD24DIODE_SOD123SOD-1231N4148WD25DIODE_DO214ACDO-214ACES1JD26ZENER-DIODE-SOD123SOD-123LBZT52C2V7T1GD27DIODE_SOD323SOD-323MMDL914T1GD28DIODE_SOD123SOD-123MBR0540T1D29DIODE_SOD123SOD-1231N4148WD31DIODE_SOD323SOD-323MMDL914T1GD32DIODE_SOD323SOD-323MMDL914T1GD33ZENER-DIODE-SOD123SOD-12330VD34ZENER-DIODE-SOD123SOD-12315VD35ZENER-DIODE-SOD123SOD-12312VD36DIODE_SOD323SOD-323MMDL914T1GD37DIODE_SOD123-FLSOD-123-FLLMBR140FT1GD38DIODE_DO214ACDO-214ACES1DD40DIODE_DO214ACDO-214ACUS1MD41DIODE_SOD323SOD-323MMDL914T1GD42DIODE_SOD323SOD-323MMDL914T1GD45DIODE_SMBSMBB340BD47ZENER-DIODE-SOD123SOD-12315VD48ZENER-DIODE-SOD123SOD-1235.1VD49DIODE_SOD123-FLSOD-123-FLES1004FLD50DIODE_SOD123-FLSOD-123-FLES1004FLD51DIODE_DO214ACDO-214ACES1DD52DIODE_DO214ACDO-214ACES1DD53DIODE_DO214ACDO-214ACES1DD54DIODE_SOD323SOD-323BAT54HD55DIODE_SOD323SOD-323BAT54HD57ZENER-DIODE-SOD123SOD-12315VD60DIODE_DO214ACDO-214ACES1DD61DIODE_SOD323SOD-323BAT54HD62DIODE_SOD323SOD-323BAT54HD63DIODE_SOD123-FLSOD-123-FLES1004FLD64DIODE_SOD123-FLSOD-123-FLES1004FLD65DIODE_SOD323SOD-323MMDL914T1GDT18-2R600_2DT_9/7_P11MMAAA8-2R600DT28-2R600_2DT_9/7_P11MMAAA8-2R600HCT3LEM_CKSR50-NPLEM_CKSR50-NPLEM_CKSR 15-NPHS1HEATSINK-23/20HEATSINK-23/20HEATSINKJ7ERTB5_9.525_2PERTB5_9.525_2PERTB5_9.525_2PJ8CON2.54-4P-WCON2.54-4P-WCON2.54-4PJ15CON2.54-4P-WCON2.54-4P-WCON2.54-4PK1RELAY_TX2-12VRLY_TX2-12VTX2-12VK2SCL-1-H-DPNO/12VDCSCL-1-H-DPNO/12VDCSCL-1-H-DPNO/12VDCK3SCL-1-H-DPNO/12VDCSCL-1-H-DPNO/12VDCSCL-1-H-DPNO/12VDCL1IND-1KW-AC-EMI1KW-AC-EMI_45/325mHL2IND-1KW-AC-EMI1KW-AC-EMI_45/325mHL3IND-LGB0810IND_LGB081022uHMOV7MOV_S20K320MOV_S20K320S20K320PCB6COM-BOARD_2COM-_BOARD_PCB_2COM. BoardPCB7CONTROL_BOARD_2CONTROL_BOARD-PCB_2CONTROL BoardQ1MOS-TO247IGBT-TO247STW48N60DM2Q3BC846BLT1SOT23BC846BLT1GQ4PNP_SOT23SOT23BC856BLT1GQ5NPN_TO220TO-2202SC3866Q6BC846BLT1SOT23BC846BLT1GQ7BCX56-16SOT89BCX56-16Q8BC846BLT1SOT232N7002LT1Q9BC846BLT1SOT23BC846BLT1GQ10BC846BLT1SOT23BC846BLT1GQ11MOS_TO220TO-220FQP4N90CQ16IGBTIGBT-TO247IKW30N65H5Q17IGBTIGBT-TO247IKW30N65H5Q19IGBTIGBT-TO247IKW30N65H5Q21IGBTIGBT-TO247IKW30N65H5Q22BCX56-16SOT89BCX56-16Q23BC846BLT1SOT232N7002LT1Q24BC846BLT1SOT23BC846BLT1GQ25MOS_TO247TO-247-H2SK1537Q27BC846BLT1SOT23BC846BLT1GQ28BC846BLT1SOT23BC846BLT1GQ29BC846BLT1SOT23BC846BLT1GQ30MOS_SOT23SOT232N7002Q31BCX56-16SOT89BCX56-16Q32BCX53-16SOT89BCX53-16T1EI30-12PEI30-12PINEI30T2EE19-10P-3EE19-10P-3EE19T3EE10-8PINEE10-8PINT5GFCI-5KW-2GFCITS1TESTTESTTS2TESTTESTTS3TESTTESTTS4TESTTESTTS5TESTTESTU1ACPL-W341ACPL-W341ACPL-W341-000EU3TL331IDBVRSOT-23-5TL331IDBVRU4PS8101-F3PS8101-F3PS8101-F3U5TL331IDBVRSOT-23-5TL331IDBVRU6PS8101-F3PS8101-F3PS8101-F3U7MIC38C45YMSOIC-8MIC38C45YMU8L5973DSOIC-8L5973DU9ACPL-W341ACPL-W341ACPL-W341-000EU10TL074IDRSO14NBU11LR431ALT1GSOT23LR431ALT1GU12LR431ALT1GSOT23LR431ALT1GU21ACPL-W341ACPL-W341ACPL-W341-000EU23ACPL-W341ACPL-W341ACPL-W341-000EU24ACPL-W341ACPL-W341ACPL-W341-000E
wangy2000 发表于 2018-11-2 07:30
好资料,学习,谢谢。
boo 发表于 2018-11-2 07:55
shenchengan 发表于 2018-11-2 07:56
20KW 天啦!功率超大啊!
到处走看 发表于 2018-11-2 08:03
学海无涯 发表于 2018-11-2 08:05
哇好大的功。
longxuekai 发表于 2018-11-2 08:21
学习一下吧
lqsgg 发表于 2018-11-2 08:33
ilpuyi 发表于 2018-11-2 08:41
龙凯1989 发表于 2018-11-2 08:45
谢谢分享
页: [1] 2 3
查看完整版本: L5973D+MIC38C45YM做的20KW功率电源板 原理图和PCB封装共享 &
