老吴 发表于 2017-12-29 16:53:33
PCIE接口+UPD720201+CY7C68014A+SL9002i+RFMD2080+RDA2032ZSR &nbs
REFDESCOMP_DEVICE_TYPECOMP_VALUESYM_NAMEAGND1TP_TH_0_TP_62_36_TP_THTP_THTP_62_36CN1CN-USB_4_CON_USB_B_F_5P_CN-USBCN-USBCON_USB_B_F_5PCN10CON_4PIN_M_TH_1.96MM_BERG_1X4_24-PinBERG_1X4_2P54CN12CONN JACKPWR_CON_DCPJACK_PDCJ0CONN JACK PWRCON_DCPJACK_PDCJ01-01CON1PCIE-CARD-EDGE_0_CONN_PCI_EDGE_PCIE-CARD-EDGECONN_PCI_EDGE_1MM_36PIND1DO-219ABSL03DO-219-ABD20BAV99W_0_SOT-323_BAV99WBAV99WSOT-323D35ZC2800E/SOT_0_DI_SMA_B2220A-13-B2220A-13-FDI_SMAD36ZC2800E/SOT_0_DI_SMA_B2220A-13-B2220A-13-FDI_SMADGND1TP_TH_0_TP_62_36_TP_THTP_THTP_62_36J1MMCX_CON_0_CON_COAX_RT_RFRFCON_COAX_RTL1INDUCTOR_100NH_SMD_COIL_L0805_4470nHL0805L2INDUCTOR_100NH_SMD_COIL_L0805_4470nHL0805L9INDUCTOR_100NH_SMD_COIL_IND_X_11.0uHIND_XAL40L10INDUCTOR_L0402_1UH1uHL0402L11INDUCTOR_L0402_1UH1uHL0402L13INDUCTOR_L0402_1UH1uHL0402L14INDUCTOR_L0402_1UH1uHL0402L15INDUCTOR_100NH_SMD_COIL_IND_XAL2.2uHIND_XAL40L16INDUCTOR_100NH_SMD_COIL_IND_X_11.0uHIND_XAL40U1HX2VL_QFN_28L_0P5MM_CY7C65632CY7C65632QFN_28L_0P5MMU2SN74AUP1G08_3_SOT-533_SN74AUP1GSN74AUP1G08SOT-533U324C128N-108U-2.7AT24C128C-MASOIC_8L_UDFN_0P5U5AT25640_0_SOP_8L_150W_50P_MX25LMX25L5121EMC-20GSOP_8L_150W_50PU6CY7C68014A-56LFXC_0_HVQFN56_0P5CY7C68014AHVQFN56_0P5U724C128N-108U-2.7AT24C128C-MASOIC_8L_UDFN_0P5U8SL9002I_0_BGA_176_0P8MM_WOSOC_SSL9002iBGA_176_0P8MM_WOSOCU15RFMD2080_QFN32_0P5_5X5_RFMD2080RFMD2080QFN32_0P5_5X5U16RFXF8553_0_S20_5P_RFXF8553RFXF8553S20_5PU17CY7C68014A-56LFXC_0_HVQFN56_0P5CY7C68014AHVQFN56_0P5U1824C128N-108U-2.7AT24C128C-MASOIC_8L_UDFN_0P5U19SL9002I_0_BGA_176_0P8MM_WOSOC_SSL9002iBGA_176_0P8MM_WOSOCU26RFMD2080_QFN32_0P5_5X5_RFMD2080RFMD2080QFN32_0P5_5X5U27RFXF8553_0_S20_5P_RFXF8553RFXF8553S20_5PU28CY7C68014A-56LFXC_0_HVQFN56_0P5CY7C68014AHVQFN56_0P5U2924C128N-108U-2.7AT24C128C-MASOIC_8L_UDFN_0P5U30SL9002I_0_BGA_176_0P8MM_WOSOC_SSL9002iBGA_176_0P8MM_WOSOCU31TPS71701DCKR_SC70_5P_TPS71701DCTPS71701DCKRSC70_5PU32TPS71701DCKR_SC70_5P_TPS71701DCTPS71701DCKRSC70_5PU33TLV1117-33CDCYR_0_SOT_223_TLV11TLV1117LV30DCYRSOT_223U37RFMD2080_QFN32_0P5_5X5_RFMD2080RFMD2080QFN32_0P5_5X5U38RFXF8553_0_S20_5P_RFXF8553RFXF8553S20_5PU39CY7C68014A-56LFXC_0_HVQFN56_0P5CY7C68014AHVQFN56_0P5U4024C128N-108U-2.7AT24C128C-MASOIC_8L_UDFN_0P5U41SL9002I_0_BGA_176_0P8MM_WOSOC_SSL9002iBGA_176_0P8MM_WOSOCU48RFMD2080_QFN32_0P5_5X5_RFMD2080RFMD2080QFN32_0P5_5X5U49RFXF8553_0_S20_5P_RFXF8553RFXF8553S20_5PU50MACOOMMAPD-007246-ES4700_SM-46-MAPD-007246-ES4700SM-46-8PINU51RDA2032ZSR_QFN32_0P5_5X5_RDA203RDA2032ZSRQFN32_0P5_5X5U52UPD720201_QFN_68L_0P4MM_UPD7202UPD720201QFN_68L_0P4MMU53LMR10530Y_1_WSON_10L_0P5_LMR105LMR10530YSDWSON_10L_0P5U54LMR10530Y_1_WSON_10L_0P5_LMR105LMR10530YSDWSON_10L_0P5U56P3LP_COILCRAFT_2_RF_FIL_SAAN_P3P3LPRF_FIL_SAANU58TPS62140_0_QFN_16P_0P5MM_TPS621TPS62130AQFN_16P_0P5MMU59LP38691_0_WSON_6P_LP38691SDLP38691SDWSON_6PU60TPS720105_PSON_6P_TPS720105DRVTPS720105DRVPSON_6PY2CRYSTAL_SMD_25MHZ_EPSON_10_OS_124MHzOSC_SMD4Y3CRYSTAL_SMD_1_OSC_SMD4_XRCGB_2424MHzOSC_SMD4_XRCGBY4CRYSTAL_SMD_25MHZ_EPSON_10_OSC_27MHzOSC_SMD4Y5OSC_SMD_12_OSC_887_CW662CT_26MH26MHz, CW659CT-NDOSC_887_CW662CTY6CRYSTAL_SMD_1_OSC_SMD4_XRCGB_2424MHzOSC_SMD4_XRCGBY7CRYSTAL_SMD_25MHZ_EPSON_10_OSC_27MHzOSC_SMD4Y8OSC_SMD_12_OSC_887_CW662CT_26MH26MHz, CW659CT-NDOSC_887_CW662CTY9CRYSTAL_SMD_1_OSC_SMD4_XRCGB_2424MHzOSC_SMD4_XRCGBY10CRYSTAL_SMD_25MHZ_EPSON_10_OSC_27MHzOSC_SMD4Y11OSC_SMD_12_OSC_887_CW662CT_26MH26MHz, CW659CT-NDOSC_887_CW662CTY12CRYSTAL_SMD_1_OSC_SMD4_XRCGB_2424MHzOSC_SMD4_XRCGBY13CRYSTAL_SMD_25MHZ_EPSON_10_OSC_27MHzOSC_SMD4Y14OSC_SMD_12_OSC_887_CW662CT_26MH26MHz, CW659CT-NDOSC_887_CW662CTY15CRYSTAL_SMD_25MHZ_EPSON_10_CRY_12MHzCRY_FQ3225B
老吴 发表于 2017-12-29 16:54:57
只有PCB文件。 太穷了。赚10个金币吧。
xnima_irumei 发表于 2017-12-29 17:01:29
带刀的老鼠 发表于 2017-12-29 20:39:53
zhifang88 发表于 2017-12-29 21:49:29
不知道这个什么信号
为明天努力 发表于 2017-12-29 23:20:07
单枪舞九州 发表于 2017-12-30 08:18:31
加油
带刀的老鼠 发表于 2017-12-30 12:24:11
chess2006 发表于 2017-12-30 12:49:05
perfect
chess2006 发表于 2017-12-30 12:49:49
perfect
页: [1] 2 3 4
查看完整版本: PCIE接口+UPD720201+CY7C68014A+SL9002i+RFMD2080+RDA2032ZSR  4通道
